cuSPARSE generic procedure could not be resolved NVFORTRAN-S-0155
I have a symmetric matrix that I store just the upper part of it in the csr format. Since the symmetric matrices in the cuSPARSE library are not usually recommended, I convert the upper triangular stored csr matrix to a general csr format in the first part of the code. Then I multiplied it with a matrix in the shape of N=3, P=1 in this example.
Although the conversion part is not optimal, it worked fine and gave the correct result for the matrix. However, the second part of the code (matrix matrix multiplication) gave the following errors.
NVFORTRAN-S-0155-Could not resolve generic procedure cusparsecreatecsr (csr.f90: 122)
NVFORTRAN-S-0155-Could not resolve generic procedure cusparsespmm_buffersize (csr.f90: 127)
NVFORTRAN-S-0155-Could not resolve generic procedure cusparsespmm (csr.f90: 139)
0 inform, 0 warnings, 3 severes, 0 fatal for sptoden
The code is as follows:
program sptoden
use openacc
use cusparse
implicit none
! CUDA API variables
type(cusparseHandle) :: h
type(cusparseMatDescr) :: descrA
INTEGER(8) :: bsize
type(c_devptr) :: buffer
type(cusparseSpMatDescr) :: matA
type(cusparseDnMatDescr) :: matZ
type(cusparseDnMatDescr) :: matY
type(cusparseDnMatDescr) :: matV
INTEGER :: status
DOUBLE PRECISION :: alpha, beta
INTEGER, dimension(3) :: nnzPerRowZ
INTEGER :: nna
DOUBLE PRECISION, dimension(5) :: csrValA
INTEGER, dimension(5) :: csrColIndA
INTEGER, dimension(4) :: csrRowPtrA
DOUBLE PRECISION, allocatable :: csrValZ(:)
INTEGER, allocatable :: csrColIndZ(:)
INTEGER, allocatable :: csrRowPtrZ(:)
DOUBLE PRECISION, dimension(3,3) :: Z
DOUBLE PRECISION, dimension(3) :: Y, V
INTEGER :: M,I
INTEGER :: N,P
N = 3
P = 1
Y = (/ 1.0d0, 2.0d0, 3.0d0 /)
csrValA = (/ 1.0d0, 3.0d0, -2.0d0, 5.0d0, -1.0d0 /)
csrRowPtrA = (/ 1, 4, 5, 6 /)
csrColIndA = (/ 1, 2, 3, 2, 3 /)
!  The expansion of the sparse matrix A (It is supposed to be upper triangular symmetric.)
!  1.0   3.0  -2.0
!  0.0   5.0   0.0
!  0.0   0.0  -1.0
Z = 0.0d0
! Transformation from symmetric to general matrix-----------------------------------------
status = cusparseCreate(h)
if (status /= CUSPARSE_STATUS_SUCCESS) &
  write(*,*) 'cusparseCreate error for transformation: ', status
status = cusparseCreateMatDescr(descrA)
status = cusparseSetMatType(descrA, CUSPARSE_MATRIX_TYPE_GENERAL)
status = cusparseSetMatIndexBase(descrA, CUSPARSE_INDEX_BASE_ONE)
status = cusparseSetStream(h, acc_get_cuda_stream(acc_async_sync))
!$ACC data copyin(csrValA, csrRowPtrA, csrColIndA) copy(Z)
!$acc host_data use_device(csrValA, csrRowPtrA, csrColIndA, Z)
status = cusparseDcsr2dense(h, 3, 3, descrA, csrValA, csrRowPtrA, csrColIndA, Z, 3)
!$acc end host_data
!$acc end data
! Conversion from non-symmetrical to symmetrical------------------------------------------
DO M = 2,3
  DO I = 1,(M-1)
    Z(M,I) = Z(I,M)
  END DO
END DO
!$acc data copyin(Z) create(nnzPerRowZ) copyout(nnzPerRowZ)
!$acc host_data use_device(Z, nnzPerRowZ)
status = cusparseDnnz_v2(h, CUSPARSE_DIRECTION_ROW, &
	          3, 3, descrA, Z, 3, nnzPerRowZ, nna)
!$acc end host_data
!$acc end data
ALLOCATE(csrValZ(nna))
ALLOCATE(csrRowPtrZ(4))
ALLOCATE(csrColIndZ(nna))
!$acc data copy(Z, nnzPerRowZ) create(csrValZ, csrRowPtrZ, csrColIndZ) copyout(csrValZ, csrRowPtrZ, csrColIndZ)
!$acc host_data use_device(Z, nnzPerRowZ, csrValZ, csrRowPtrZ, csrColIndZ)
status = cusparseDdense2csr(h, 3, 3, descrA, Z, 3, &
!$acc end host_data
!$acc end data
write(*,*) csrValZ
write(*,*) csrRowPtrZ
write(*,*) csrColIndZ
DO M = 1,3
  DO N = 1,3
    write(*,*) Z(M,N)
  END DO
END DO
! 2nd part of the code-----------------Matrix-Matrix Multiplication
!$acc data copyin(csrValZ, csrRowPtrZ, csrColIndZ) copy(Y,V)
!$acc host_data use_device(csrValZ, csrRowPtrZ, csrColIndZ,Y,V)
status = cusparseCreateDnMat(matY, N, P, N, Y, CUDA_R_64F, CUSPARSE_ORDER_COL)
status = cusparseCreateDnMat(matV, N, P, N, V, CUDA_R_64F, CUSPARSE_ORDER_COL)
status = cusparseCreateCsr(matZ, N, N, nna, csrRowPtrZ, csrColIndZ, csrValZ, &
                   CUSPARSE_INDEX_32I, CUSPARSE_INDEX_32I, &
                   CUSPARSE_INDEX_BASE_ONE, CUDA_R_64F)
status = cusparseSpMM_buffersize(h, CUSPARSE_OPERATION_NON_TRANSPOSE, CUSPARSE_OPERATION_NON_TRANSPOSE, &
                 alpha, matZ, matY, beta, matV, CUDA_R_64F, CUSPARSE_CSRMM_ALG1, bsize)
IF (bsize .GT. 0) buffer = acc_malloc(bsize)
status = cusparseSpMM(h, CUSPARSE_OPERATION_NON_TRANSPOSE, CUSPARSE_OPERATION_NON_TRANSPOSE, &
                 alpha, matZ, matY, beta, matV, CUDA_R_64F, CUSPARSE_CSRMM_ALG1, buffer)
IF (bsize.gt.0) CALL acc_free(buffer)
!$acc end host_data
!$acc end data
write(*,*) V
DEALLOCATE(csrValZ)
DEALLOCATE(csrRowPtrZ)
DEALLOCATE(csrColIndZ)
end program sptoden
The Makefile is as follows:
FC=nvfortran
TIMER=/usr/bin/time
OPT=
NOPT=-fast -Minfo=opt $(OPT)
FCFLAGS = -Mpreprocess -fast -acc=gpu -cuda -cudalib=cusparse
csr: csr.o
$(TIMER) ./csr.o $(STEPS)
csr.o: csr.f90
$(FC) $(FCFLAGS) -o $@ $< $(NOPT) -Minfo=accel -acc
clean:
rm -f *.o *.exe *.s *.mod a.out
I could not figure out why it does not work.
In fact, the transformation from symmetric sparse to general sparse is pointless in the problem. I just explained it what I wanted to do. I suppose that the problem is related to the matrix matrix multiplication.
  • Yunus
Hi Yunus,
Check that your argument types match the function signature. In particular, “matZ” should be a “cusparseSpMatDescr” type. See: NVIDIA Fortran CUDA Library Interfaces Version 22.7 for ARM, OpenPower, x86
-Mat
Now I comment on the cusparseDnMatGetValue(MatV, V) part, it still gave an error:
NVFORTRAN-S-0155-Could not resolve generic procedure cusparsednmatgetvalues (csr.f90: 147)
I reposted the code as follows:
program sptoden
use openacc
use cusparse
implicit none
INTEGER(8) :: bsize
type(cusparseSpMatDescr) :: matZ
INTEGER :: status
INTEGER :: nna
INTEGER :: M,I
INTEGER :: N,P
N = 3
P = 1
!  | 1.0   3.0  -2.0 |   |1.0| | 1.0|
!  | 3.0   5.0   0.0 | X |2.0|=|13.0|
!  |-2.0   0.0  -1.0 |   |3.0| |-5.0|
Z = 0.0d0
!$acc end host_data
!$acc end data
DO M = 2,3
  DO I = 1,(M-1)
    Z(M,I) = Z(I,M)
  END DO
END DO
!$acc end host_data
!$acc end data
!$acc end host_data
!$acc end data
write(*,*) csrValZ
DO M = 1,3
  DO N = 1,3
    write(*,*) Z(M,N)
  END DO
END DO
write(*,*) "value of nnz ", nna
!IF (status.ne.CUSPARSE_STATUS_SUCCESS) PRINT *,"cusparseCreateDnMat: ",status
!IF (status.ne.CUSPARSE_STATUS_SUCCESS) print *,"cusparseCreateCsr: ",status
!IF (status.ne.CUSPARSE_STATUS_SUCCESS) print *,"cusparseSpMM_buffersize: ",status
!print *,"SpMM buffersize required: ",bsize
!status = cusparseSpMM_preprocess(h, CUSPARSE_OPERATION_NON_TRANSPOSE, CUSPARSE_OPERATION_NON_TRANSPOSE, &
!                 alpha, matZ, matY, beta, matV, CUDA_R_64F, CUSPARSE_CSRMM_ALG1, buffer)
!IF (status.ne.CUSPARSE_STATUS_SUCCESS) PRINT *,"cusparseSpMM: ",status
status = cusparseDnMatGetValues(matV, V)
IF (status.ne.CUSPARSE_STATUS_SUCCESS) PRINT *,"cusparseDnMatGetValues: ",status
!$acc end host_data
!$acc end data
write(*,*) V
DEALLOCATE(csrValZ)
end program sptoden
I added dnMatGetValues for (matV, V) because the multiplication is supposed to give the results {1.0, 13.0, -5.0}.
||! | 1.0 3.0 -2.0 | |1.0| | 1.0||
||! | 3.0 5.0 0.0 | X |2.0|=|13.0||
||! |-2.0 0.0 -1.0 | |3.0| |-5.0||
But it gave {0,0,0}. So I added the dnmatgetvalues. It does not work.
The link you shared above says to use a c_devptr type instead of V but I do not know how to convert that type into a usable matrix.
  • Yunus
I think in this case, you can use “acc_deviceptr(V)” to grab the device C pointer:
status = cusparseDnMatGetValues(matV, acc_deviceptr(V))
Though “V” still produces zeros. Let me ask Brent to take a look to see why you may be getting incorrect results.
-Mat
In cusparseSpMM(), the result is a dense matrix. A dense device matrix. It is easiest just to read the device values from the underlying dense matrix, which in this case is V.
The cusparseDnMatGetValues can return a type(c_devptr) to the device values, which should just be a pointer to V, on the device. You have to go through gyrations though to convert the type(c_devptr) to something easy to work with in Fortran, so just access V.
IN other words, cusparseDnMatGetValues needs a **ptr argument to return a pointer. That’s why you have to pass it a type(c_devptr).
I understood your point but I cannot implement it.
I did following
type(c_devptr), dimension(:), pointer :: vptr
DOUBLE PRECISION, dimension(3), target :: V
vptr => V
then keep copy V using ACC routines and added cusparseDnMatGetValues(matV, vptr).
Still does not work. Can you show how to do it?
!$acc end host_data
!$acc end data
write(,) V
You’ve already setup V to be the matrix beneath the dense matrix descriptor, so just read from V after the end data. You also have bugs in your code, need to set alpha and beta, and don’t use M and N as loop indices.
Thanks, it fixed it.
