I created a code in order to have an understanding of the library use of cuSPARSE with OpenACC directives. It has two files: one of them the main file in which a subroutine of the other file is called. When it is compiled it gives the error:
NVFORTRAN-S-0155-Could not resolve generic procedure cusparsednvecgetvalues (csrsymmv.f90: 93)
0 inform, 0 warnings, 1 severes, 0 fatal for csrsymmv
I suppose I will get the results of the multiplication in the vector V(:,K) for each loop. When I do not add the cusparseDnVecGetValues directive, it does not give an error.
If you have any other recommendation for the code, it would be helpful.
The main file:
PROGRAM MAIN
IMPLICIT NONE
! FORTRAN arrays start at 1
INTEGER N ! The number of rows of Y (the same as the columns of the dense A)
INTEGER P ! The number of columns of Y
INTEGER NNA ! The number of nonzero elements in the matrix
DOUBLE PRECISION, DIMENSION(5,3) :: Y ! The matrix multipled by the CSR matrix
DOUBLE PRECISION, DIMENSION(11) :: A ! Vector that holds all nonzero values
INTEGER, DIMENSION(6) :: IA ! CSR row indices
INTEGER, DIMENSION(11) :: JA ! CSR column indices
N = 5 ! 1,2,3,4,5
P = 3 ! 1,2,3
NNA = 9
Y(1,1:P) = (/ 1.0, 2.0, 3.0 /)
Y(2,1:P) = (/ 0.0, 1.0, 5.0 /)
Y(3,1:P) = (/ 1.0, 4.0, 9.0 /)
Y(4,1:P) = (/ 1.0, 1.0, 0.0 /)
Y(5,1:P) = (/ 0.0, 2.0, 8.0 /)
! 5X5 matrix
A = (/ 1.0, 4.0, 2.0, 3.0, 5.0, 7.0, 8.0, 9.0, 6.0, 8.0, 3.0/)
IA = (/ 1, 3, 5, 8, 10, 12 /)
JA = (/ 1, 2, 2, 3, 1, 4, 5, 3, 5, 1, 4 /)
CALL CSRSYMMV(N,P,NNA,IA,JA,A,Y)
END PROGRAM
The other file:
SUBROUTINE CSRSYMMV(N,P,NNA,IA,JA,A,Y)
! This code aims to multiply matrix A, which is in csr format with A, and indices IA
! and JA, with Y(:,K) vector in each loop. Then takes the results as V(N,P).
! In other words, multiplication of CSR matrix A with Y(:,K) at each loop.
USE openacc
USE cusparse
!$ USE OMP_LIB
IMPLICIT NONE
type(cusparseHandle) :: h
type(cusparseMatDescr) :: descrA
#if CUDA_VERSION >= 11000
integer(8) :: bsize
type(c_devptr) :: buffer
type(cusparseSpMatDescr) :: matA
type(cusparseDnVecDescr) :: vecY, vecV
#endif
integer :: status
! parameters
REAL(8) :: alpha, beta
INTEGER N ! Rows of Y
INTEGER P ! Columns of Y
INTEGER NNA ! # of non-zero values
! sparse CSR arrays
INTEGER IA(N+1) ! csrRowPtrA
INTEGER JA(NNA) ! csrColIndA
DOUBLE PRECISION A(NNA)
INTEGER K
DOUBLE PRECISION Y(N,P)
DOUBLE PRECISION V(N,P)
!initialize CUSPARSE and matrix descriptor
status = cusparseCreate(h)
if (status /= CUSPARSE_STATUS_SUCCESS) &
write(*,*) 'cusparseCreate error: ', status
status = cusparseCreateMatDescr(descrA)
status = cusparseSetMatType(descrA, CUSPARSE_MATRIX_TYPE_GENERAL)
status = cusparseSetMatIndexBase(descrA, CUSPARSE_INDEX_BASE_ONE)
status = cusparseSetStream(h, acc_get_cuda_stream(acc_async_sync))
alpha = 1.0
beta = 0.0
!!$OMP PARALLEL DO DEFAULT(NONE) &
!!$OMP PRIVATE(K) &
!!$OMP SHARED(A,IA,JA,N,P,V,Y)
!$acc data copyin(IA, JA, A, Y) create(vecY, vecV, V) copyout(vecV)
DO K = 1,P
write(*,*) "K", K
! vecY = vecX in the documentation
! vecV = vecY in the documentation
! Multiplier vector
status = cusparseCreateDnVec(vecY, N, Y(:,K), CUDA_R_64F)
IF (status.ne.CUSPARSE_STATUS_SUCCESS) PRINT *,"cusparseCreateDnVec: ",status
! Return vector of the multiplication
status = cusparseCreateDnVec(vecV, N, V(:,K), CUDA_R_64F)
status = cusparseCreateCsr(matA, N, N, NNA, IA, JA, A, &
CUSPARSE_INDEX_32I, CUSPARSE_INDEX_32I, &
CUSPARSE_INDEX_BASE_ONE, CUDA_R_64F)
IF (status.ne.CUSPARSE_STATUS_SUCCESS) print *,"cusparseCreateCsr: ",status
status = cusparseSpMV_buffersize(h, CUSPARSE_OPERATION_NON_TRANSPOSE, alpha, &
matA, vecY, beta, vecV, CUDA_R_64F, CUSPARSE_CSRMV_ALG1, bsize)
IF (status.ne.CUSPARSE_STATUS_SUCCESS) print *,"cusparseSpMV_buffersize: ",status
print *,"SpMV buffersize required: ",bsize
IF (bsize .GT. 0) buffer = acc_malloc(bsize)
status = cusparseSpMV(h, CUSPARSE_OPERATION_NON_TRANSPOSE, alpha, &
matA, vecY, beta, vecV, CUDA_R_64F, CUSPARSE_CSRMV_ALG1, buffer)
IF (status.ne.CUSPARSE_STATUS_SUCCESS) PRINT *,"cusparseSpMV: ",status
status = cusparseDnVecGetValues(vecV, V(:,K))
IF (status.ne.CUSPARSE_STATUS_SUCCESS) PRINT *,"cusparseDnVecGetValues: ",status
IF (bsize.gt.0) CALL acc_free(buffer)
! CALL MKL_DCSRSYMV('U', N, A, IA, JA, Y(:,K), V(:,K))
END DO
!$acc end data
!!$OMP END PARALLEL DO
END SUBROUTINE CSRSYMMV
The Makefile:
Copyright (c) 2017, NVIDIA Corporation. All rights reserved.
Please refer to the NVIDIA end user license agreement (EULA) associated
with this source code for terms and conditions that govern your use of
this software. Any use, reproduction, disclosure, or distribution of
this software and related documentation outside the terms of the EULA
is strictly prohibited.
TEST = document
ADD = csrsymmv
FC = nvfortran
EXE = exe
FCFLAGS = -Mpreprocess -fast -acc=gpu -cuda -Mcudalib=cusparse
all: build run verify
build: $(TEST).f90 $(ADD).f90
$(FC) $(FCFLAGS) -o $(TEST).$(EXE) $(ADD).f90 $<
run: $(TEST).$(EXE)
$(RUN) ./$(TEST).$(EXE)
verify:
clean:
@echo ‘Cleaning up…’
@rm -rf *.$(EXE) *.dwf *.pdb *.mod prof
Thanks,
Y
