I’m very interested by cuBlasLt because it should work with strided matrices in row-order format.
I’ve found the example provided by M. Nicely at https://github.com/mnicely/cublasLt_examples/tree/master/cublasLt_sgemm.
The example works nicely with matrices in row-order format. But it fails when the matrices are non-square…
in the example, changing:
calculate( i, i, i );
to:
calculate( i, i, i+1 );
leads to the error:
CUDA error at cublasLt_sgemm.cu:172 code=7(CUBLAScublasLt_STATUS_INVALID_VALUE)
"cublasLtMatmulAlgoGetHeuristic( ltHandle, operationDesc, Adesc, Bdesc, Cdesc, Cdesc, preference, 1, &heuristicResult, &returnedResults )"
I’ve read the example code and I think it’s perfectly fine.
I’ve also done the same test using column-order format and in this case, the modified test works.
Is it a cuBlasLt bug?
