Hi !
I tried to use the new MRG32k3a PRNG. As there is no example on how to use it and as the CURAND docuimentation does not make any differences between XORWOW and MRG32K3a, I assumed that one just need to change the type of the curandState from curandStateXORWOW_t to curandStateMRG32k3a_t.
However, by doing this, curand_init causes unspecified launch failure.
Studying the code, I found that the scratch pointer of curandStateMRG32k3a_t is used before being set:
void curand_init(unsigned long long seed,
unsigned long long subsequence,
unsigned long long offset,
curandStateMRG32k3a_t *state)
int i;
for ( i=0; i<3; i++ ) {
state->s1[i] = 12345.;
state->s2[i] = 12345.;
if (seed != 0ull) {
unsigned int x1 = ((unsigned int)seed) ^ 0x55555555UL;
unsigned int x2 = (unsigned int)((seed >> 32) ^ 0xAAAAAAAAUL);
state->s1[0] = curand_MRGmodMul(x1, state->s1[0], MRG32K3A_MOD1);
state->s1[1] = curand_MRGmodMul(x2, state->s1[1], MRG32K3A_MOD1);
state->s1[2] = curand_MRGmodMul(x1, state->s1[2], MRG32K3A_MOD1);
state->s2[0] = curand_MRGmodMul(x2, state->s2[0], MRG32K3A_MOD2);
state->s2[1] = curand_MRGmodMul(x1, state->s2[1], MRG32K3A_MOD2);
state->s2[2] = curand_MRGmodMul(x2, state->s2[2], MRG32K3A_MOD2);
skipahead_subsequence( subsequence, state );
skipahead( offset, state );
void skipahead_subsequence(unsigned long long n, curandStateMRG32k3a_t *state)
double t[3][3];
struct sMRG32k3aSkipSubSeq * pSkip;
pSkip = ((curandMRG32k3aPtrs_t *)state->scratch)->subSeqM1;
curand_MRGmatPow3x3( pSkip->m, t, MRG32K3A_MOD1, n);
curand_MRGmatVecMul3x3( t, state->s1, MRG32K3A_MOD1);
pSkip = ((curandMRG32k3aPtrs_t *)state->scratch)->subSeqM2;
curand_MRGmatPow3x3( pSkip->m, t, MRG32K3A_MOD2, n);
curand_MRGmatVecMul3x3( t, state->s2, MRG32K3A_MOD2);
changing curand_init to
int i;
if (seed != 0ull) {
curandMRG32k3aPtrs_t scratch;
sMRG32k3aSkipUnits_t unitsM1;
sMRG32k3aSkipUnits_t unitsM2;
sMRG32k3aSkipSubSeq_t subSeqM1;
sMRG32k3aSkipSubSeq_t subSeqM2;
sMRG32k3aSkipSeq_t seqM1;
sMRG32k3aSkipSeq_t seqM2;
scratch.seqM1 = &seqM1;
scratch.seqM2 = &seqM2;
scratch.subSeqM1 = &subSeqM1;
scratch.subSeqM2 = &subSeqM2;
scratch.unitsM2 = &unitsM2;
scratch.unitsM1 = &unitsM1;
state->scratch = &scratch;
solve this problem but only partially : the data pointed by the acratch pointer are allocated but not initialized.
I suppose that scratch should be a memory space common to all the threads and hence pointed at by the curandstate of each thread. However, I do not understand how it is to be initialized.
Can anyone provide an example of usage of this PRNG ?
Thank you.
Reagrds,
Wilfried K.
