#0 0x0000007fb6f233f4 in find_notify (object=0x7fa8ff850e, object=0x7fa8ff850e, data=0x0, notify=0x0, match_notify=0, quark=2577) at gstminiobject.c:369
#1 0x0000007fb6f233f4 in gst_mini_object_set_qdata (object=0x7fa8ff850e, quark=2577, data=0x0, destroy=0x0) at gstminiobject.c:672
#2 0x0000007fb7853948 in () at /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvarguscamerasrc.so
#3 0x0000007fb75bb98c in () at /usr/lib/aarch64-linux-gnu/libglib-2.0.so.0
#4 0x0000007fa8ff8598 in ()
I’ve revert the code snippet that trigger segmentation fault,
please replace the argus library with devtalk1070455_Feb10.tar.gz for your temporary solution.
we’ll also investigate the fix, thanks devtalk1070455_Feb10.tar.gz (29 KB)
I am having the same problem as Caspari, I tried your temporary solution. Indeed nvarguscamerasrc no loger segfaults but it seems I am getting black images (empty buffers) from gstreamer after I set the pipeline again to play. The pipeline I am using for testing is:
I’ve tried locally to confirm gst pipeline and also the python script in comment #1 works with temporary approach.
could you please share the failure messages, may I also know what’s the sensor you’re used.
thanks
So this is very similar if not the exact issue I complained about in R32.1. It seems it still exists in R32.3.1.
What is the time table for a fix for this?
EDIT: Note that in R32.1 not only did nvargus-daemon segfault and/or hang, but there were spurious bus messages that would occur if you restarted a pipeline using GStreamer.
One work around I found is to recreate the pipeline from scratch on every retry (that sorta works).
so tx2 r32.3.1 I get this
Mar 31 13:16:17 BaseSystem_0_5 nvargus-daemon[6724]: === VideoSystem.notStripped[6771]: Connection closed (7FA53811D0)=== VideoSystem.notStripped[6771]: WARNING: CameraProvider was not destroyed before client connection terminated.=== VideoSystem.notStripped[6771]: The client may have abnormally terminated. Destroying CameraProvider…=== VideoSystem.notStripped[6771]: CameraProvider destroyed (0x7fa078f780)=== VideoSystem.notStripped[6771]: WARNING: Cleaning up 1 outstanding requests…=== VideoSystem.notStripped[6771]: WARNING: Cleaning up 1 outstanding streams…SCF: Error InvalidState: 4 buffers still pending during EGLStreamProducer destruction (propagating from src/services/gl/EGLStreamProducer.cpp, function freeBuffers(), line 305)
Mar 31 13:16:17 BaseSystem_0_5 nvargus-daemon[6724]: SCF: Error InvalidState: (propagating from src/services/gl/EGLStreamProducer.cpp, function ~EGLStreamProducer(), line 50)
Mar 31 13:16:17 BaseSystem_0_5 nvargus-daemon[6724]: === VideoSystem.notStripped[6771]: WARNING: Cleaning up 1 outstanding stream settings…=== VideoSystem.notStripped[6771]: WARNING: Cleaning up 1 outstanding sessions…(NvCameraUtils) Error InvalidState: Mutex not initialized (/dvs/git/dirty/git-master_linux/camera/core_scf/src/services/gl/EGLStreamProducer.cpp:497) (in Mutex.cpp, function lock(), line 79)
Mar 31 13:16:17 BaseSystem_0_5 nvargus-daemon[6724]: SCF: Error BadParameter: Buffer is not pending (in src/services/gl/EGLStreamProducer.cpp, function presentBufferInternal(), line 501)
Mar 31 13:16:17 BaseSystem_0_5 nvargus-daemon[6724]: (NvCameraUtils) Error InvalidState: Mutex has not been initialized (in Mutex.cpp, function unlock(), line 88)
Mar 31 13:16:17 BaseSystem_0_5 nvargus-daemon[6724]: SCF: Error BadParameter: (propagating from src/services/gl/EGLStreamProducer.cpp, function presentBuffer(), line 486)
Mar 31 13:16:17 BaseSystem_0_5 nvargus-daemon[6724]: SCF: Error BadParameter: (propagating from src/components/CaptureContainerImpl.cpp, function returnBuffer(), line 447)
Mar 31 13:16:17 BaseSystem_0_5 nvargus-daemon[6724]: SCF: Error BadParameter: (propagating from src/components/stages/BufferReturnStage.h, function doExecute(), line 43)
Mar 31 13:16:17 BaseSystem_0_5 nvargus-daemon[6724]: SCF: Error BadParameter: Sending critical error event (in src/api/Session.cpp, function sendErrorEvent(), line 990)
Mar 31 13:16:17 BaseSystem_0_5 nvargus-daemon[6724]: (NvCameraUtils) Error InvalidState: Mutex not initialized (/dvs/git/dirty/git-master_linux/camera/core_scf/src/services/gl/EGLStreamProducer.cpp:399) (in Mutex.cpp, function lock(), line 79)
Mar 31 13:16:18 BaseSystem_0_5 kernel: [357375.709000] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 49 (15700000.vi_2) clientid 390311, HW thresh 239841, done 239842
Mar 31 13:16:18 BaseSystem_0_5 kernel: [357375.721066] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 48 (15700000.vi_1) clientid 390311, HW thresh 239848, done 239848
Mar 31 13:16:18 BaseSystem_0_5 kernel: [357375.733222] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 47 (15700000.vi_0) clientid 390311, HW thresh 242617, done 242617
Mar 31 13:16:18 BaseSystem_0_5 kernel: [357375.745298] ---- mlocks ----
Mar 31 13:16:18 BaseSystem_0_5 kernel: [357375.745326]
Mar 31 13:16:18 BaseSystem_0_5 kernel: [357375.745329] ---- syncpts ----
Mar 31 13:16:18 BaseSystem_0_5 kernel: [357375.745340] id 2 (disp_a) min 199687 max 199687 refs 1 (previous client : )
Mar 31 13:16:18 BaseSystem_0_5 kernel: [357375.745346] id 3 (disp_b) min 210233 max 210233 refs 1 (previous client : )
Mar 31 13:16:18 BaseSystem_0_5 kernel: [357375.745352] id 5 (disp_d) min 40 max 40 refs 1 (previous client : )
Mar 31 13:16:18 BaseSystem_0_5 kernel: [357375.745357] id 6 (disp_e) min 1 max 1 refs 1 (previous client : )
Mar 31 13:16:18 BaseSystem_0_5 kernel: [357375.745362] id 7 (disp_f) min 1 max 1 refs 1 (previous client : )
Mar 31 13:16:18 BaseSystem_0_5 kernel: [357375.745367] id 8 (vblank0) min 21493670 max 0 refs 1 (previous client : )
Mar 31 13:16:18 BaseSystem_0_5 kernel: [357375.745374] id 11 (dsi) min 120 max 0 refs 1 (previous client : )
Mar 31 13:16:18 BaseSystem_0_5 kernel: [357375.745379] id 12 (vblank1) min 21441121 max -4 refs 1 (previous client : )
Mar 31 13:16:18 BaseSystem_0_5 kernel: [357375.745396] id 23 (gp10b_507) min 2516690 max 2516690 refs 1 (previous client : )
Mar 31 13:16:18 BaseSystem_0_5 kernel: [357375.745401] id 24 (gp10b_506) min 490 max 490 refs 1 (previous client : )
Mar 31 13:16:18 BaseSystem_0_5 kernel: [357375.745407] id 25 (gp10b_505) min 1478384 max 1478384 refs 1 (previous client : gp10b_505)
Mar 31 13:16:18 BaseSystem_0_5 kernel: [357375.745414] id 28 (gp10b_504) min 6 max 6 refs 1 (previous client : )
Mar 31 13:16:18 BaseSystem_0_5 kernel: [357375.745426] id 35 (15600000.isp_nvargus-daemon_0) min 479708 max 479708 refs 3 (previous client : 15600000.isp_nvargus-daemon_0)
Mar 31 13:16:18 BaseSystem_0_5 kernel: [357375.745432] id 36 (15600000.isp_nvargus-daemon_1) min 247352 max 247352 refs 3 (previous client : 15600000.isp_nvargus-daemon_1)
Mar 31 13:16:18 BaseSystem_0_5 kernel: [357375.745438] id 37 (15600000.isp_nvargus-daemon_2) min 250819 max 250819 refs 3 (previous client : 15600000.isp_nvargus-daemon_2)
Mar 31 13:16:18 BaseSystem_0_5 kernel: [357375.745443] id 38 (15600000.isp_nvargus-daemon_3) min 239842 max 239842 refs 3 (previous client : 15600000.isp_nvargus-daemon_3)
Mar 31 13:16:18 BaseSystem_0_5 systemd[1]: nvargus-daemon.service: Main process exited, code=killed, status=11/SEGV
Mar 31 13:16:18 BaseSystem_0_5 systemd[1]: nvargus-daemon.service: Failed with result ‘signal’.
Mar 31 13:16:18 BaseSystem_0_5 systemd[1]: nvargus-daemon.service: Service hold-off time over, scheduling restart.
Mar 31 13:16:18 BaseSystem_0_5 systemd[1]: nvargus-daemon.service: Scheduled restart job, restart counter is at 1.
Mar 31 13:16:18 BaseSystem_0_5 systemd[1]: Stopped Argus daemon.
Mar 31 13:16:18 BaseSystem_0_5 systemd[1]: Started Argus daemon.
Mar 31 13:17:01 BaseSystem_0_5 CRON[6930]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
after consulting with Lumenera if it is there camera driver problem my gstreamer app is not reliable. When is nvargus-daemon going to be fixed?
