Build onnxruntime 1.19.2 fail due to API HardwareCompatibilityLevel
It seems onnxruntime 1.19.2 used setHardwareCompatibilityLevel,but CUDA 11.8 don’t have this API implemented.
Please tell me which version is OK to support build onnxruntime 1.19.2 on L4T 36.5 Jetpack 5.1.4?
[ 80%] Building CXX object CMakeFiles/onnx_test_runner.dir/home/daniel/Work/onnxruntime/onnxruntime/test/onnx/main.cc.o
[ 81%] Built target onnxruntime
[ 81%] Building CXX object CMakeFiles/onnxruntime_perf_test.dir/home/daniel/Work/onnxruntime/onnxruntime/test/perftest/command_args_parser.cc.o
[ 81%] Building CXX object CMakeFiles/onnxruntime_perf_test.dir/home/daniel/Work/onnxruntime/onnxruntime/test/perftest/main.cc.o
[ 81%] Building CXX object CMakeFiles/onnxruntime_perf_test.dir/home/daniel/Work/onnxruntime/onnxruntime/test/perftest/performance_runner.cc.o
[ 81%] Building CXX object CMakeFiles/onnxruntime_perf_test.dir/home/daniel/Work/onnxruntime/onnxruntime/test/perftest/ort_test_session.cc.o
/home/daniel/Work/onnxruntime/onnxruntime/core/providers/tensorrt/tensorrt_execution_provider.cc: In member function ‘onnxruntime::common::Status onnxruntime::TensorrtExecutionProvider::CreateNodeComputeInfoFromGraph(const onnxruntime::GraphViewer&, const onnxruntime::Node&, std::unordered_map<std::__cxx11::basic_string<char>, long unsigned int>&, std::unordered_map<std::__cxx11::basic_string<char>, long unsigned int>&, std::vector<onnxruntime::NodeComputeInfo>&)’:
/home/daniel/Work/onnxruntime/onnxruntime/core/providers/tensorrt/tensorrt_execution_provider.cc:3053:17: error: ‘class nvinfer1::IBuilderConfig’ has no member named ‘setHardwareCompatibilityLevel’
 3053 |     trt_config->setHardwareCompatibilityLevel(nvinfer1::HardwareCompatibilityLevel::kAMPERE_PLUS);
/home/daniel/Work/onnxruntime/onnxruntime/core/providers/tensorrt/tensorrt_execution_provider.cc:3053:57: error: ‘nvinfer1::HardwareCompatibilityLevel’ has not been declared
/home/daniel/Work/onnxruntime/onnxruntime/core/providers/tensorrt/tensorrt_execution_provider.cc: In lambda function:
/home/daniel/Work/onnxruntime/onnxruntime/core/providers/tensorrt/tensorrt_execution_provider.cc:3644:21: error: ‘class nvinfer1::IBuilderConfig’ has no member named ‘setHardwareCompatibilityLevel’
 3644 |         trt_config->setHardwareCompatibilityLevel(nvinfer1::HardwareCompatibilityLevel::kAMPERE_PLUS);
/home/daniel/Work/onnxruntime/onnxruntime/core/providers/tensorrt/tensorrt_execution_provider.cc:3644:61: error: ‘nvinfer1::HardwareCompatibilityLevel’ has not been declared
[ 82%] Building CXX object CMakeFiles/onnxruntime_perf_test.dir/home/daniel/Work/onnxruntime/onnxruntime/test/perftest/posix/utils.cc.o
[ 82%] Building CXX object CMakeFiles/onnxruntime_perf_test.dir/home/daniel/Work/onnxruntime/onnxruntime/core/platform/path_lib.cc.o
make[2]: *** [CMakeFiles/onnxruntime_providers_tensorrt.dir/build.make:149: CMakeFiles/onnxruntime_providers_tensorrt.dir/home/daniel/Work/onnxruntime/onnxruntime/core/providers/tensorrt/tensorrt_execution_provider.cc.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:2779: CMakeFiles/onnxruntime_providers_tensorrt.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
[ 82%] Linking CXX executable onnxruntime_perf_test
[ 82%] Built target onnxruntime_perf_test
[ 82%] Linking CXX executable onnx_test_runner
[ 82%] Built target onnx_test_runner
make: *** [Makefile:146: all] Error 2
  File "/home/daniel/Work/onnxruntime/tools/ci_build/build.py", line 2971, in <module>
    sys.exit(main())
  File "/home/daniel/Work/onnxruntime/tools/ci_build/build.py", line 2861, in main
    build_targets(args, cmake_path, build_dir, configs, num_parallel_jobs, args.target)
  File "/home/daniel/Work/onnxruntime/tools/ci_build/build.py", line 1729, in build_targets
    run_subprocess(cmd_args, env=env)
  File "/home/daniel/Work/onnxruntime/tools/ci_build/build.py", line 860, in run_subprocess
    return run(*args, cwd=cwd, capture_stdout=capture_stdout, shell=shell, env=my_env)
  File "/home/daniel/Work/onnxruntime/tools/python/util/run.py", line 49, in run
    completed_process = subprocess.run(
  File "/usr/lib/python3.8/subprocess.py", line 516, in run
    raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command '['/usr/local/bin/cmake', '--build', '/home/daniel/Work/onnxruntime/build/Linux/Release', '--config', 'Release', '--', '-j6']' returned non-zero exit status 2.
We have upgrade to cuda 12.3.107, and still got setHardwareCompatibilityLevel issue.
When did CUDA implement this API?
[ 78%] Building CXX object CMakeFiles/onnxruntime_providers_tensorrt.dir/home/daniel/Work/onnxruntime/onnxruntime/core/providers/tensorrt/tensorrt_provider_factory.cc.o
[ 79%] Building C object CMakeFiles/onnxruntime.dir/generated_source.c.o
[ 79%] Linking CXX shared library libonnxruntime.so
[ 79%] Linking CXX static library libabsl_flags_parse.a
[ 79%] Built target absl_flags_parse
[ 79%] Building CXX object CMakeFiles/onnx_test_runner.dir/home/daniel/Work/onnxruntime/onnxruntime/test/onnx/main.cc.o
[ 79%] Building CXX object _deps/googletest-build/googletest/CMakeFiles/gtest.dir/src/gtest-all.cc.o
[ 79%] Built target onnxruntime
[ 79%] Building CXX object CMakeFiles/onnxruntime_perf_test.dir/home/daniel/Work/onnxruntime/onnxruntime/test/perftest/main.cc.o
[ 79%] Building CXX object CMakeFiles/onnxruntime_perf_test.dir/home/daniel/Work/onnxruntime/onnxruntime/test/perftest/ort_test_session.cc.o
[ 79%] Building CXX object CMakeFiles/onnxruntime_perf_test.dir/home/daniel/Work/onnxruntime/onnxruntime/test/perftest/command_args_parser.cc.o
[ 79%] Building CXX object CMakeFiles/onnxruntime_perf_test.dir/home/daniel/Work/onnxruntime/onnxruntime/test/perftest/performance_runner.cc.o
[ 80%] Building CXX object CMakeFiles/onnxruntime_perf_test.dir/home/daniel/Work/onnxruntime/onnxruntime/test/perftest/posix/utils.cc.o
[ 80%] Building CXX object CMakeFiles/onnxruntime_perf_test.dir/home/daniel/Work/onnxruntime/onnxruntime/core/platform/path_lib.cc.o
[ 80%] Linking CXX executable onnx_test_runner
[ 80%] Linking CXX executable onnxruntime_perf_test
[ 80%] Built target onnxruntime_perf_test
[ 80%] Built target onnx_test_runner
[ 80%] Linking CXX static library ../../../lib/libgtest.a
[ 80%] Built target gtest
    sys.exit(main())
Was introduced on onnxruntime version 1.18.1
1.18.0 doesn’t have it. Search here for nvinfer1::HardwareCompatibilityLevel
it exists from 1.18.1 on (lines 3517 and 4125):
Which is only supported from TensorRT 8.6+
I’m using an Orin with JP5 and TensorRT 8.5.2, which doesn’t have the nvinfer1::HardwareCompatibilityLevel header, and I guess it doesn’t support hardware compatibility anyway in this JP5 version.
So go for a version <= 1.18.0. Perhaps the already built wheel from here?
