Onnxruntime wrong GLIBCXX version
Given Jetson Zoo - eLinux.org documentation, onnxruntime_gpu-1.18.0-cp38-cp38-linux_aarch64.whl should be used with Jetpack 5.1.2.
I found that this onnxruntime wheel includes a shared library (/usr/local/lib/python3.8/dist-packages/onnxruntime/capi/onnxruntime_pybind11_state.so) that depends on GLIBCXX_3.4.29.
However, it seams that nvcr.io/nvidia/l4t-jetpack:r35.4.1 only has GLIBCXX_3.4.28.
Here’s a dump of my versions:
Host L4T 35.4.1
Host Jetpack 5.1.2
Container nvcr.io/nvidia/l4t-jetpack:r35.4.1
onnx 1.17.0
onnxslim 0.1.46
onnxruntime-gpu https://nvidia.box.com/shared/static/3fechcaiwbtblznlchl6dh8uuat3dp5r.whl
torch https://developer.download.nvidia.com/compute/redist/jp/v512/pytorch/torch-2.1.0a0+41361538.nv23.06-cp38-cp38-linux_aarch64.whl
torchvision https://github.com/ultralytics/assets/releases/download/v0.0.0/torchvision-0.16.2+c6f3977-cp38-cp38-linux_aarch64.whl
I get the following error message:
ONNX: slimming with onnxslim 0.1.46...
ONNX: simplifier failure: /lib/aarch64-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /usr/local/lib/python3.8/dist-packages/onnxruntime/capi/onnxruntime_pybind11_state.so)
$ strings /lib/aarch64-linux-gnu/libstdc++.so.6 | grep GLIBCXX
GLIBCXX_3.4
GLIBCXX_3.4.1
GLIBCXX_3.4.2
GLIBCXX_3.4.3
GLIBCXX_3.4.4
GLIBCXX_3.4.5
GLIBCXX_3.4.6
GLIBCXX_3.4.7
GLIBCXX_3.4.8
GLIBCXX_3.4.9
GLIBCXX_3.4.10
GLIBCXX_3.4.11
GLIBCXX_3.4.12
GLIBCXX_3.4.13
GLIBCXX_3.4.14
GLIBCXX_3.4.15
GLIBCXX_3.4.16
GLIBCXX_3.4.17
GLIBCXX_3.4.18
GLIBCXX_3.4.19
GLIBCXX_3.4.20
GLIBCXX_3.4.21
GLIBCXX_3.4.22
GLIBCXX_3.4.23
GLIBCXX_3.4.24
GLIBCXX_3.4.25
GLIBCXX_3.4.26
GLIBCXX_3.4.27
GLIBCXX_3.4.28
Can you please publish a up to date image or recommend an other version of onnxruntime-gpu compatible with GLIBCXX_3.4.28?
Thank you
I found that docker.io/dustynv/l4t-pytorch:r35.4.1 has the required GLIBXX versions:
GLIBCXX_3.4.29
GLIBCXX_3.4.30
Shouldn’t the official image be updated?
This is a known issue and the packages are prepared by the ONNXRuntime team.
The recommendation of the ONNXRuntime team is to upgrade the environment to JetPack 6.x.
