Collecting onnx==1.4.1
Using cached onnx-1.4.1.tar.gz (2.9 MB)
Collecting numpy
Downloading numpy-1.19.5-cp36-cp36m-manylinux2014_aarch64.whl (12.4 MB)
|################################| 12.4 MB 8.1 MB/s
Collecting protobuf
Using cached protobuf-3.15.6-py2.py3-none-any.whl (173 kB)
Requirement already satisfied: six in /usr/local/lib/python3.6/dist-packages (from onnx==1.4.1) (1.15.0)
Requirement already satisfied: typing-extensions>=3.6.2.1 in /usr/local/lib/python3.6/dist-packages (from onnx==1.4.1) (3.7.4.3)
Collecting typing>=3.6.4
Using cached typing-3.7.4.3.tar.gz (78 kB)
Building wheels for collected packages: onnx, typing
Building wheel for onnx (setup.py) ... error
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-j2olh8er/onnx_1a18955d9ba049a49ea50b7cb848657b/setup.py'"'"'; __file__='"'"'/tmp/pip-install-j2olh8er/onnx_1a18955d9ba049a49ea50b7cb848657b/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-umvfcvmx
cwd: /tmp/pip-install-j2olh8er/onnx_1a18955d9ba049a49ea50b7cb848657b/
Complete output (45 lines):
fatal: not a git repository (or any of the parent directories): .git
running bdist_wheel
running build
running build_py
running create_version
running cmake_build
File "/usr/local/bin/cmake", line 5, in <module>
from cmake import cmake
ModuleNotFoundError: No module named 'cmake'
File "<string>", line 1, in <module>
File "/tmp/pip-install-j2olh8er/onnx_1a18955d9ba049a49ea50b7cb848657b/setup.py", line 328, in <module>
'backend-test-tools = onnx.backend.test.cmd_tools:main',
File "/usr/lib/python3/dist-packages/setuptools/__init__.py", line 129, in setup
return distutils.core.setup(**attrs)
File "/usr/lib/python3.6/distutils/core.py", line 148, in setup
dist.run_commands()
File "/usr/lib/python3.6/distutils/dist.py", line 955, in run_commands
self.run_command(cmd)
File "/usr/lib/python3.6/distutils/dist.py", line 974, in run_command
cmd_obj.run()
File "/usr/lib/python3/dist-packages/wheel/bdist_wheel.py", line 204, in run
self.run_command('build')
File "/usr/lib/python3.6/distutils/cmd.py", line 313, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File "/usr/lib/python3.6/distutils/command/build.py", line 135, in run
self.run_command(cmd_name)
cmd_obj.run()
File "/tmp/pip-install-j2olh8er/onnx_1a18955d9ba049a49ea50b7cb848657b/setup.py", line 203, in run
self.run_command('cmake_build')
cmd_obj.run()
File "/tmp/pip-install-j2olh8er/onnx_1a18955d9ba049a49ea50b7cb848657b/setup.py", line 190, in run
subprocess.check_call(cmake_args)
File "/usr/lib/python3.6/subprocess.py", line 311, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '['/usr/local/bin/cmake', '-DPYTHON_INCLUDE_DIR=/usr/include/python3.6m', '-DPYTHON_EXECUTABLE=/usr/bin/python3', '-DBUILD_ONNX_PYTHON=ON', '-DCMAKE_EXPORT_COMPILE_COMMANDS=ON', '-DONNX_NAMESPACE=onnx', '-DPY_EXT_SUFFIX=.cpython-36m-aarch64-linux-gnu.so', '/tmp/pip-install-j2olh8er/onnx_1a18955d9ba049a49ea50b7cb848657b']' returned non-zero exit status 1.
ERROR: Failed building wheel for onnx
Running setup.py clean for onnx
Building wheel for typing (setup.py) ... done
Created wheel for typing: filename=typing-3.7.4.3-py3-none-any.whl size=28017 sha256=84e3299d899c6db1d5d8cf7234d92d51182687f5d2fcc2db0b2bd59ac7f25808
Stored in directory: /root/.cache/pip/wheels/5f/63/c2/b85489bbea28cb5d36cfe197244f898428004fa3caa7a23116
Successfully built typing
Failed to build onnx
Installing collected packages: typing, protobuf, numpy, onnx
Running setup.py install for onnx ... error
command: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-j2olh8er/onnx_1a18955d9ba049a49ea50b7cb848657b/setup.py'"'"'; __file__='"'"'/tmp/pip-install-j2olh8er/onnx_1a18955d9ba049a49ea50b7cb848657b/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-739w5b6e/install-record.txt --single-version-externally-managed --compile --install-headers /usr/local/include/python3.6/onnx
Complete output (47 lines):
running install
running build
running build_py
running cmake_build
dist.run_commands()
cmd_obj.run()
File "/usr/lib/python3/dist-packages/setuptools/command/install.py", line 61, in run
return orig.install.run(self)
File "/usr/lib/python3.6/distutils/command/install.py", line 589, in run
cmd_obj.run()
cmd_obj.run()
cmd_obj.run()
ERROR: Command errored out with exit status 1: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-j2olh8er/onnx_1a18955d9ba049a49ea50b7cb848657b/setup.py'"'"'; __file__='"'"'/tmp/pip-install-j2olh8er/onnx_1a18955d9ba049a49ea50b7cb848657b/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-739w5b6e/install-record.txt --single-version-externally-managed --compile --install-headers /usr/local/include/python3.6/onnx Check the logs for full command output.
Hi @Myron, have you installed cmake with sudo apt-get install cmake?
If that doesn’t fix, also try pip3 install cmake
Hi @dusty_nv . I tried that already but the issue still remains the same.
Using cached cmake-3.18.4.post1-py3-none-manylinux2014_aarch64.whl (16.1 MB)
Installing collected packages: cmake
Successfully installed cmake-3.18.4.post1
root@dnncam-0000681:/opt/nvidia/deepstream/deepstream-5.0.1/tensorrt_demos# pip3 install onnx==1.4.1 Collecting onnx==1.4.1
Requirement already satisfied: numpy in /usr/local/lib/python3.6/dist-packages (from onnx==1.4.1) (1.19.5)
Requirement already satisfied: protobuf in /usr/local/lib/python3.6/dist-packages (from onnx==1.4.1) (3.15.6)
Requirement already satisfied: typing-extensions>=3.6.2.1 in /usr/local/lib/python3.6/dist-packages (from onnx ==1.4.1) (3.7.4.3)
Requirement already satisfied: typing>=3.6.4 in /usr/local/lib/python3.6/dist-packages (from onnx==1.4.1) (3.7 .4.3)
command: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-tu3d 978y/onnx_aadaf9d9f6e449a7b9d4d1d14d236b83/setup.py'"'"'; __file__='"'"'/tmp/pip-install-tu3d978y/onnx_aadaf9d 9f6e449a7b9d4d1d14d236b83/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().repl ace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp /pip-wheel-rubn_8g6
cwd: /tmp/pip-install-tu3d978y/onnx_aadaf9d9f6e449a7b9d4d1d14d236b83/
Complete output (65 lines):
running bdist_wheel
running build
running build_py
running cmake_build
-- Build type not set - defaulting to Release
-- The C compiler identification is GNU 7.5.0
-- The CXX compiler identification is GNU 7.5.0
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/bin/cc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
CMake Error at /usr/local/lib/python3.6/dist-packages/cmake/data/share/cmake-3.18/Modules/FindPackageHandleS tandardArgs.cmake:165 (message):
Could NOT find Protobuf (missing: Protobuf_INCLUDE_DIR)
Call Stack (most recent call first):
/usr/local/lib/python3.6/dist-packages/cmake/data/share/cmake-3.18/Modules/FindPackageHandleStandardArgs.c make:458 (_FPHSA_FAILURE_MESSAGE)
/usr/local/lib/python3.6/dist-packages/cmake/data/share/cmake-3.18/Modules/FindProtobuf.cmake:626 (FIND_PA CKAGE_HANDLE_STANDARD_ARGS)
CMakeLists.txt:104 (find_package)
-- Configuring incomplete, errors occurred!
See also "/tmp/pip-install-tu3d978y/onnx_aadaf9d9f6e449a7b9d4d1d14d236b83/.setuptools-cmake-build/CMakeFiles /CMakeOutput.log".
See also "/tmp/pip-install-tu3d978y/onnx_aadaf9d9f6e449a7b9d4d1d14d236b83/.setuptools-cmake-build/CMakeFiles /CMakeError.log".
File "/tmp/pip-install-tu3d978y/onnx_aadaf9d9f6e449a7b9d4d1d14d236b83/setup.py", line 328, in <module>
dist.run_commands()
cmd_obj.run()
cmd_obj.run()
cmd_obj.run()
File "/tmp/pip-install-tu3d978y/onnx_aadaf9d9f6e449a7b9d4d1d14d236b83/setup.py", line 203, in run
cmd_obj.run()
File "/tmp/pip-install-tu3d978y/onnx_aadaf9d9f6e449a7b9d4d1d14d236b83/setup.py", line 190, in run
subprocess.CalledProcessError: Command '['/usr/local/bin/cmake', '-DPYTHON_INCLUDE_DIR=/usr/include/python3. 6m', '-DPYTHON_EXECUTABLE=/usr/bin/python3', '-DBUILD_ONNX_PYTHON=ON', '-DCMAKE_EXPORT_COMPILE_COMMANDS=ON', ' -DONNX_NAMESPACE=onnx', '-DPY_EXT_SUFFIX=.cpython-36m-aarch64-linux-gnu.so', '/tmp/pip-install-tu3d978y/onnx_a adaf9d9f6e449a7b9d4d1d14d236b83']' returned non-zero exit status 1.
Installing collected packages: onnx
command: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-tu 3d978y/onnx_aadaf9d9f6e449a7b9d4d1d14d236b83/setup.py'"'"'; __file__='"'"'/tmp/pip-install-tu3d978y/onnx_aadaf 9d9f6e449a7b9d4d1d14d236b83/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().re place('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-_bxbua8p/install-record.txt --single-version-externally-managed --compile --install-headers /u sr/local/include/python3.6/onnx
Complete output (54 lines):
running install
running build
running build_py
running cmake_build
CMake Error at /usr/local/lib/python3.6/dist-packages/cmake/data/share/cmake-3.18/Modules/FindPackageHandl eStandardArgs.cmake:165 (message):
/usr/local/lib/python3.6/dist-packages/cmake/data/share/cmake-3.18/Modules/FindPackageHandleStandardArgs .cmake:458 (_FPHSA_FAILURE_MESSAGE)
/usr/local/lib/python3.6/dist-packages/cmake/data/share/cmake-3.18/Modules/FindProtobuf.cmake:626 (FIND_ PACKAGE_HANDLE_STANDARD_ARGS)
See also "/tmp/pip-install-tu3d978y/onnx_aadaf9d9f6e449a7b9d4d1d14d236b83/.setuptools-cmake-build/CMakeFil es/CMakeOutput.log".
See also "/tmp/pip-install-tu3d978y/onnx_aadaf9d9f6e449a7b9d4d1d14d236b83/.setuptools-cmake-build/CMakeFil es/CMakeError.log".
dist.run_commands()
cmd_obj.run()
cmd_obj.run()
cmd_obj.run()
cmd_obj.run()
subprocess.CalledProcessError: Command '['/usr/local/bin/cmake', '-DPYTHON_INCLUDE_DIR=/usr/include/python 3.6m', '-DPYTHON_EXECUTABLE=/usr/bin/python3', '-DBUILD_ONNX_PYTHON=ON', '-DCMAKE_EXPORT_COMPILE_COMMANDS=ON', '-DONNX_NAMESPACE=onnx', '-DPY_EXT_SUFFIX=.cpython-36m-aarch64-linux-gnu.so', '/tmp/pip-install-tu3d978y/onnx _aadaf9d9f6e449a7b9d4d1d14d236b83']' returned non-zero exit status 1.
ERROR: Command errored out with exit status 1: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.a rgv[0] = '"'"'/tmp/pip-install-tu3d978y/onnx_aadaf9d9f6e449a7b9d4d1d14d236b83/setup.py'"'"'; __file__='"'"'/tm p/pip-install-tu3d978y/onnx_aadaf9d9f6e449a7b9d4d1d14d236b83/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '" '"'exec'"'"'))' install --record /tmp/pip-record-_bxbua8p/install-record.txt --single-version-externally-manag ed --compile --install-headers /usr/local/include/python3.6/onnx Check the logs for full command output.
It seems that you don’t have protobuf library in your environment.
Could you install it and try it again?
$ sudo apt-get install libprotobuf-dev protobuf-compiler
hi @AastaLLL , I tried this But the error still remains the same.
I am actually using the following docker image.
deepstream 5.0.1-20.09-base
We can install ONNX v1.4.1 with the following instructions:
$ apt update
$ apt-get install python3-pip
$ apt-get install cmake libprotobuf-dev protobuf-compiler
$ pip3 install Cython
$ pip3 install onnx==1.4.1
Please give it a try.
hi @AastaLLL , I did try this but still no success. When I try and install ONNX on JETSON TX2 Platform without docker image , everything installs successfully but in the docker it fails to install.
Any thoughts?
Could you share the detailed error log with us?
For the error above, you should get it solved after installing the protobuf library.
(This is included in the instructions shared in Mar 31)
