Jetson TX2 onnx doesnt install
I want to install onnx==1.14.1 to my Jetson TX2. I have python 3.6.9 and I can’t change python version because of my projects requirements. When I run sudo pip install onnx-1.14.1.tar.gz, there is an error which is:
Building wheel for onnx (pyproject.toml) … error
File “/usr/local/lib/python3.6/dist-packages/pip/_vendor/pep517/in_process/_in_process.py”, line 363, in
main()
File “/usr/local/lib/python3.6/dist-packages/pip/_vendor/pep517/in_process/_in_process.py”, line 345, in main
json_out[‘return_val’] = hook(**hook_input[‘kwargs’])
File “/usr/local/lib/python3.6/dist-packages/pip/_vendor/pep517/in_process/_in_process.py”, line 262, in build_wheel
metadata_directory)
File “/usr/local/lib/python3.6/dist-packages/setuptools/build_meta.py”, line 231, in build_wheel
wheel_directory, config_settings)
File “/usr/local/lib/python3.6/dist-packages/setuptools/build_meta.py”, line 215, in _build_with_temp_dir
self.run_setup()
File “/usr/local/lib/python3.6/dist-packages/setuptools/build_meta.py”, line 268, in run_setup
self).run_setup(setup_script=setup_script)
File “/usr/local/lib/python3.6/dist-packages/setuptools/build_meta.py”, line 158, in run_setup
exec(compile(code, file, ‘exec’), locals())
File “setup.py”, line 365, in
“backend-test-tools = onnx.backend.test.cmd_tools:main”,
File “/usr/local/lib/python3.6/dist-packages/setuptools/init.py”, line 153, in setup
return distutils.core.setup(**attrs)
File “/usr/lib/python3.6/distutils/core.py”, line 148, in setup
dist.run_commands()
File “/usr/lib/python3.6/distutils/dist.py”, line 955, in run_commands
self.run_command(cmd)
File “/usr/lib/python3.6/distutils/dist.py”, line 974, in run_command
cmd_obj.run()
File “/tmp/pip-build-env-zt49gzad/overlay/lib/python3.6/site-packages/wheel/bdist_wheel.py”, line 299, in run
self.run_command(‘build’)
File “/usr/lib/python3.6/distutils/cmd.py”, line 313, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File “/usr/lib/python3.6/distutils/command/build.py”, line 135, in run
self.run_command(cmd_name)
cmd_obj.run()
File “setup.py”, line 236, in run
self.run_command(“cmake_build”)
cmd_obj.run()
File “setup.py”, line 230, in run
subprocess.check_call(build_args)
File “/usr/lib/python3.6/subprocess.py”, line 311, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command ‘[’/usr/bin/cmake’, ‘–build’, ‘.’, ‘–’, ‘-j’, ‘4’]’ returned non-zero exit status 2.
ERROR: Failed building wheel for onnx
ERROR: Could not build wheels for onnx, which is required to install pyproject.toml-based projects
How can I solve them?
Based on the ONNX GitHub, you will need the Protobuf compiler (protoc) 3.6.1 to compile ONNX 1.14.1.
Could you check if you installed it correctly first?
