I am trying to build it onnxruntime on Jetson TX2 with python 3.7.8 and jetpack 4.4. While the build was successful, I ran into the following issue while importing it
Python 3.7.8 | packaged by conda-forge | (default, Jul 31 2020, 01:53:52)
[GCC 7.5.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import onnxruntime
/home/qureai/.local/lib/python3.7/site-packages/onnxruntime/capi/_pybind_state.py:14: UserWarning: Cannot load onnxruntime.capi. Error: 'Python version mismatch: module was compiled for Python 3.6, but the interpreter version is incompatible: 3.7.8 | packaged by conda-forge | (default, Jul 31 2020, 01:53:52)
[GCC 7.5.0].'.
warnings.warn("Cannot load onnxruntime.capi. Error: '{0}'.".format(str(e)))
File "<stdin>", line 1, in <module>
File "/home/qureai/.local/lib/python3.7/site-packages/onnxruntime/__init__.py", line 13, in <module>
from onnxruntime.capi._pybind_state import get_all_providers, get_available_providers, get_device, set_seed, \
ImportError: cannot import name 'get_all_providers' from 'onnxruntime.capi._pybind_state' (/home/qureai/.local/lib/python3.7/site-packages/onnxruntime/capi/_pybind_state.py)
I was able to build onnxruntime on the same board with python 3.6.9 and it ran successfully.
System information
- OS Platform and Distribution
Distributor ID: Ubuntu
Description: Ubuntu 18.04.4 LTS
Release: 18.04
Codename: bionic
NVIDIA Jetson TX2 - Jetpack 4.4 [L4T 32.4.3] - Version: 3.0.1
- Jetpack: 4.4 [L4T 32.4.3]
- Board:
* Type: TX2
* SOC Family: tegra186 ID: 24
* Module: P3310-1000 Board: UNKNOWN
* Code Name: quill
* Cuda ARCH: 6.2
* Board ids: 3310:0000:A0
- Libraries:
* CUDA: 10.2.89
* OpenCV: 4.1.1 compiled CUDA: NO
* TensorRT: 7.1.3.0
* VPI: 0.3.7
* VisionWorks: 1.6.0.501
* Vulkan: 1.2.70
* cuDNN: 8.0.0.180
- ONNX Runtime installed from : Source
- ONNX Runtime version:
- Python version: 3.7.8
- GCC/Compiler version (if compiling from source): gcc (Ubuntu/Linaro 7.5.0-3ubuntu1~18.04) 7.5.0
- CUDA/cuDNN version: 10.2.89/ 8.0.0.180
To Reproduce
I have built onnxruntime for python 3.6 using the instructions here
To build it for python3.7, I installed miniforge from here and created a python3.7 environment
# remove line 895,896 in https://github.com/microsoft/onnxruntime/blob/master/cmake/CMakeLists.txt
- string (APPEND CMAKE_CUDA_FLAGS "-gencode=arch=compute_53,code=sm_53 -gencode=arch=compute_62,code=sm_62") #nano, TX1, TX2
- string (APPEND CMAKE_CUDA_FLAGS "-gencode=arch=compute_72,code=sm_72") # Jetson N
+ string (APPEND CMAKE_CUDA_FLAGS "-gencode=arch=compute_62,code=sm_62") # 62 for tx2
$ ./build.sh --update --config Release --build --build_wheel \
--use_cuda --cuda_home /usr/local/cuda --cudnn_home /usr/lib/aarch64-linux-gnu
Expected behavior
Build will be successful and a wheel file will be created. When you install the wheel file and import onnxruntime, you’ll encounter this error
[GCC 7.5.0].'.
I think the problem may be with pybind11 which is somehow picking python3.6 instead of 3.7.
cmake output
[ 97%] Built target onnxruntime_test_all
[ 97%] Performing update step for 'pybind11'
[ 97%] No patch step for 'pybind11'
[ 97%] No configure step for 'pybind11'
[ 97%] No build step for 'pybind11'
[ 97%] No install step for 'pybind11'
[ 97%] Completed 'pybind11'
[ 98%] Built target pybind11
[100%] Built target onnxruntime_pybind11_state
