I followed the steps in follow tutorial inside a Jetson Xavier:
but, when I try to import onnxruntime in python3 I have follow error:
import onnxruntime
/usr/local/lib/python3.6/dist-packages/onnxruntime/capi/_pybind_state.py:14: UserWarning: Cannot load onnxruntime.capi. Error: ‘libcublas.so.10: cannot open shared object file: No such file or directory’.
warnings.warn(“Cannot load onnxruntime.capi. Error: ‘{0}’.”.format(str(e)))
File “”, line 1, in
File “/usr/local/lib/python3.6/dist-packages/onnxruntime/ init .py”, line 13, in
from onnxruntime.capi._pybind_state import get_all_providers, get_available_providers, get_device, set_seed,
ImportError: cannot import name ‘get_all_providers’
I’m completely stuck in this error and I don’t understand the root cause, I tried also using other different versions of onnxruntime, but always have same issue
What should be the issue?
