Hi! I am trying to build yolov7 by compiling it and saving the serialzed trt engine.
However, the process is too slow. Takes 1hour for 256*256 resolution.
Is there anyway to speed up?
Environment
TensorRT Version: 8.2.4.2 GPU Type: RTX3080 12GB Nvidia Driver Version: 515.48 CUDA Version: 11.4 CUDNN Version: 8.2.4 Operating System + Version: Ubuntu 20.04 Python Version (if applicable): 3.8 TensorFlow Version (if applicable): PyTorch Version (if applicable): 1.12.0 Baremetal or Container (if container which image + tag):
Request you to share the ONNX model and the script if not shared already so that we can assist you better.
Alongside you can try few things:
validating your model with the below snippet
check_model.py
import sys
import onnx
filename = yourONNXmodel
model = onnx.load(filename)
onnx.checker.check_model(model).
2) Try running your model with trtexec command.
In case you are still facing issue, request you to share the trtexec “”–verbose"" log for further debugging
Also, we recommend you to please try on the latest TensorRT version 8.4 GA Update 1 and if you still face this issue share with us verbose logs and command to try from our end for better debugging. https://developer.nvidia.com/nvidia-tensorrt-8x-download
