I’ve read lots of documentation about building and flashing the kernel and dtb files and typically follow the following guides
https://developer.ridgerun.com/wiki/index.php?title=Compiling_Jetson_TX1/TX2_source_code#Build_u-boot
https://elinux.org/Jetson/TX2_DTB
I’ve been successful on the TX2 using Jetpack 3.2.1 but since moving to Jetpack 4.2 have has some difficulties.
I managed to build and flash the kernel and device tree successfully but have managed to break things by making changes to the device tree to get the USB ports working on the J120 carrier board, as I previously did for 3.2.1. I have tried to revert my changes but this has no effect, so I am obviously missing something.
There is some different information regarding flashing the dtb, i.e. one recommendation is
cp $DEVDIR/images/arch/arm64/boot/dts/tegra186-quill-p3310-1000-c03-00-base.dtb $DEVDIR/kernel/dtb
cd $DEVDIR/
sudo ./apply_binaries.sh
sudo ./flash.sh -r -d kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb -K kernel/Image jetson-tx2 mmcblk0p1
And another
cp $DEVDIR/images/arch/arm64/boot/dts/*.dtb $DEVDIR/kernel/dtb
cp $DEVDIR/images/arch/arm64/boot/dts/*.dtb $DEVDIR/bootloader
cp $DEVDIR/images/arch/arm64/boot/dts/*.dtb $DEVDIR/rootfs/boot
sudo ./flash.sh -r -k kernel-dtb jetson-tx2 mmcblk0p1
There are guides available to follow but with minimal explanation as to what is going on. I appreciate that there is a lot going on when building and flashing and explaining everything would be information overload, however I would like to understand things more to help diagnose my problem. I therefore have some questions to help clarify things.
1)Given that a lot of dtb files get built, how many of them need to be flashed onto the target?
2)When we rebuild the device tree, do we need to create a new system image or can we simply flash the dtb files? I have found that for J120 patch on Jetpack 3.2.1 a new system image was required and the kernel-dtb option was required.
3)Do the dtb files need to be copied to the bootloader folder?.
4)Is there anything else I have missed? It would be good to know the things to check rather than blindly following a guide.
Thanks in advance.
