I’ve already done all that analysis. The problem is that cudafe dies really early on - before it’s even looked at its arguments, or checked if it’s running as root, or tried to open its input. I suspect the root problem here is that something in Fedora Rawhide and/or the kernel has changed, and I’m more than happy to chase the regression to the upstream culprit, but cudafe is a stripped binary with some modifications to the ELF header sufficient to stop gdb from being able to open it, so the usual debugging method of just parking a breakpoint on the arch_prctl() call and then ‘stepi’ until it dies won’t work.
Yeah, except the goal here is to track down what caused the regression, because something in Fedora or the kernel changed. Oh well… looks like ‘git bisect’ time again.
Something corrupted the binaries. ‘yum reinstall cuda-core-6-5’ fixed it, and everything seems to be working. Now to figure out what screwed the binaries up…
