actually, we had some internal discussions.
the recommended way (especially for Xavier series) is to burn all fuses together instead of burning fuses step-by-step.
Hi JerryChang,
Thatās not a solution. The manual clearly states āThe following fuses are available for the system designer to use for burning during the product lifetime.ā in a chapter titled āODM Field Programmable Fusesā. With these fuses we cannot do the burning in a one step approach. They need to be available during the product lifetime, and lockable separately with the FUSE_ODM_LOCK function. I think we are going in loops.
This topic has been open for 9 months now, and nvidia is not doing much to make it move forward. I think this needs to improve if the Jetson is targeted for use in industrial products. Do you have any support channels other than this forum?
How do you implement your ratcheting mechanism? This also make use of these fuses if Iām not mistaken. So surely itās not prevented by hardware.
hello h123,
weāre able to burn reserved ODM fuse after production mode fuse enabled via recovery method (through USB).
this might be a permission issue, weāll need more time for investigation.
Hi JerryChang,
Any update on this topic?
Hi JerryChang,
Any update on when we can expect a fix for this?
For a new product we are using the Orin Nano, and we are also planning to use the ODM fuses during the product lifetime. Can we assume that this works on the Orin Nano?
hello h123,
thatās due to the firewall settings to block users updating ODM RESERVED fuses from kernel.
unfortunately, we donāt have patch to address this issue, itās still under investigation.
