Please check
is truly lossless encoding ( byte per byte) even possible?
Yes, it is byte-to-byte lossless -
which codecs/compression?
H265 -
which systems? (xavier , xavier NX , tx2 )
TX2, Xavier and Xavier NX -
which Jetpack versions?
After Jetpack 4.6 -
is it possible through the gstreamer framework or only through multimedia API framework?
It is supported in nvv4l2h265enc. The frame data has to be NV24 and enable the property:
enable-lossless : Enable lossless encoding for YUV444
flags: readable, writable, changeable only in NULL or READY state
Boolean. Default: false
what settings are required for supported frameworks? ( --elossless , qp=? which video format etc.)
Please refer to this post:
Can tx2nx decode YUV444? - #3 by DaneLLL -
expected performance (roughly)?
The performance listed in module data sheet is for encoding YUV420. For encoding YUV444, we don’t have exact data but it may be worse -
future plans?
