Apologies if this has been posted elsewhere, I couldn’t find anything using search.
I am trying to integrate working CUDA code into a working C++ program, but am faced with a compile error I can’t seem to work out.
Without posting all the code, here’s how I have it set up. It’s based on the ‘C++ Integration’ sample code from here.
== main.h ==
// includes
int main(int argc, char **argv);
extern "C" void gpuDivide(float* image, unsigned int width, unsigned int height, float divisor);
== main.cpp ==
#include "main.h"
// code
== GpuIntegration.cu ==
#include "GpuKernel.cu"
divide<<< 1,1 >>>(image, width, height, divisor);
== GpuKernel.cu ==
__global__ void divide(float *image, unsigned int width, unsigned int height, float divisor)
// code
Compile command:
/usr/local/cuda/bin/nvcc -I/usr/local/cuda/include -O2 -g -c
The compiler comes up with the following:
make all
Building file: ../GpuIntegration.cu
Invoking: C Compiler
/usr/local/cuda/bin/nvcc -o "GpuIntegration.o" "../GpuIntegration.cu"
/usr/lib/gcc/x86_64-linux-gnu/4.4.1/../../../../lib/crt1.o: In function `_start':
/build/buildd/eglibc-2.10.1/csu/../sysdeps/x86_64/elf/start.S:109: undefined reference to `main'
collect2: ld returned 1 exit status
make: *** [GpuIntegration.o] Error 1
I’ve been struggling with this since last week, which has stifled my progress. Any suggestions on how to fix this are most welcome!
Thanks for your help,
Chris
