Well i’ve been reading in the forum trying to find an answer to my problem but I couldn’t so I need some of your help, I’m new to CUDA and I’m developing a project. Basically I have this 3 files:
TestCuda.cu
#include "TestCuda.h"
__global__ void testCU(){
int a;
a = 10;
void function()
testCU<<<1,1>>>();
TestCuda.h
void function();
Test.c
int main()
function();
Now when compiling with this command:
nvcc -c Test.c
nvcc TestCuda.c -o test Test.o
I got these errors:
Undefined symbols:
"_function", referenced from:
_main in tmpxft_0000046b_00000000-4_Test.o
ld: symbol(s) not found
collect2: ld returned 1 exit status
The problem is that my MAIN function is in a C file and in the CU file I implement the function “function” which call the cuda-kernel “testCU()”
You need to declare function as [font=“Courier New”]extern “C” void function()[/font] inTestCuda.cu and also change TestCuda.h. The latter is a bit trickier, since it is used both in C and C++ code. Conditional compilation helps here:
Thanks for the quick answer, finally it worked, I was declaring my function as extern “C” but I wasn’t modifying the .h file.
Just another question, I’m using OpenCV to read images but when I try to compile with nvcc it show an error about different architectures, my dynamic libraries of OpenCV are in “x86_64” and when I compile with nvcc it tries to create just an “i386” binary, so what is the best way to make it work in the linkin phase? I’m using these options in when compiling
-Xcompiler "-arch x86_64" --no-align-double
is there a way to build CUDA in x86_64 architecture? because I try to build OpenCV just for “i386” but I had no luck.
Now another technical question is, what good/bad things can imply the fact of compiling with -m64? As far as I understand I’ll can run that application just in systems 64bit-compatible, but I’m not sure in this assumption.
I tried this but I also tried another thing, in TestCuda.h I put the conditional compilation, but in TestCuda.cu I didn’t declare the function as extern “C”, and it compiles and executes very well, is this a bad practice of compilation? or is it as good as the compilation you proposed?
