Hi Guys
I have a question that
first we make some cuda functions and then build it to dll file
second shall we make a new c# project to call the cuda function on dll file
so we can use C# to make to program for computer interface (easier than C++)
and we can get the capacity of CUDA
Now in my computer, I don’t have c# so I can not try to do it
Does anybody has tried to do it, can you tell me that it can work.
This exactly what i am doing and it is working! :D
GUI under .NET via C# and rendering/computing core via CUDA in external DLL…
Everything works ok but when i compile Emu_Debug mode i just can’t trace into any of my dll function :( Pdb file should be ok but maybe I am just too lame with those C# things :D
Deploying CUDA library as a COM component makes sense. Instead of packaging the CUDA library as simple C DLL , deploy it as a COM component. You will be able to access your code through tons of languages and scripts and through different machines too.
I was wondering if you would be willing to share your C# wrapper to CUDA?
Im interested in using CUDA for non graphics applications but I’m not sure how I can utilise it yet. I wouldn’t like to spend to much time wrapping it up in C# to find it is not of much use to me.
Huh, this is actually what I am working on as well. Maybe we should all collaborate on these open issues to create some concrete code for the community.
