I bought QSFP+ AOC 40G 850nm AQOA9N13ADLN0723 cable. According to the specification it is InfiniBand 4x DDR/QDR compliant. Unfortunately after
ibportstate --Direct 0 1 enable
I get: state: Down, and Physical state: PortConfigurationTraining or Disabled alternately. After
ibportstate --Direct 0 1 width 1
(on both ends) i get Physical state: LinkUp but State: Initializing. OpenSM is running on one of the nodes (no switch). And in the OpenSM log:
OpenSM 3.3.23
osm_vendor_init: 1000 pending umads specified
Entering DISCOVERING state
osm_vendor_bind: Mgmt class 0x81 binding to port GUID 0x117500006f916e
osm_vendor_bind: Mgmt class 0x03 binding to port GUID 0x117500006f916e
osm_vendor_bind: Mgmt class 0x04 binding to port GUID 0x117500006f916e
osm_vendor_bind: Mgmt class 0x21 binding to port GUID 0x117500006f916e
osm_opensm_bind: Setting IS_SM on port 0x00117500006f916e
SM port is down
SM port is up
log_send_error: ERR 5411: DR SMP Send completed with error (IB_TIMEOUT) – dropping
Method 0x1, Attr 0x11, TID 0x12a8
Received SMP on a 1 hop path: Initial path = 0,1, Return path = 0,0
sm_mad_ctrl_send_err_cb: ERR 3113: MAD completed in error (IB_TIMEOUT): SubnGet(NodeInfo), attr_mod 0x0, TID 0x12a8
sm_mad_ctrl_send_err_cb: ERR 3120: Timeout while getting attribute 0x11 (NodeInfo); Possible mis-set mkey?
Entering MASTER state
Is it cable compatibility or OpenSM problem?
