Hello Dear community
I’ve installed the latest jetpack to my Jetson Tx2 (4.3).
When I was installing Caffe from JetHacks Caffe Deep Learning Framework - NVIDIA Jetson TX2 - JetsonHacks
But I have errors like this:
Scanning dependencies of target caffe
[ 2%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/window_data_layer.cpp.o
[ 3%] Building CXX object src/caffe/CMakeFiles/caffe.dir/solvers/nesterov_solver.cpp.o
[ 3%] Building CXX object src/caffe/CMakeFiles/caffe.dir/solvers/rmsprop_solver.cpp.o
[ 3%] Building CXX object src/caffe/CMakeFiles/caffe.dir/syncedmem.cpp.o
[ 4%] Building CXX object src/caffe/CMakeFiles/caffe.dir/solvers/sgd_solver.cpp.o
[ 4%] Building CXX object src/caffe/CMakeFiles/caffe.dir/util/benchmark.cpp.o
/home/nvidia/caffe/src/caffe/layers/window_data_layer.cpp: In member function ‘virtual void caffe::WindowDataLayer<Dtype>::load_batch(caffe::Batch<Dtype>*)’:
/home/nvidia/caffe/src/caffe/layers/window_data_layer.cpp:293:42: error: ‘CV_LOAD_IMAGE_COLOR’ was not declared in this scope
cv_img = cv::imread(image.first, CV_LOAD_IMAGE_COLOR);
/home/nvidia/caffe/src/caffe/layers/window_data_layer.cpp:293:42: note: suggested alternative: ‘CV_IS_IMAGE_HDR’
CV_IS_IMAGE_HDR
src/caffe/CMakeFiles/caffe.dir/build.make:39377: recipe for target 'src/caffe/CMakeFiles/caffe.dir/layers/window_data_layer.cpp.o' failed
make[3]: *** [src/caffe/CMakeFiles/caffe.dir/layers/window_data_layer.cpp.o] Error 1
make[3]: *** Waiting for unfinished jobs....
CMakeFiles/Makefile2:272: recipe for target 'src/caffe/CMakeFiles/caffe.dir/all' failed
make[2]: *** [src/caffe/CMakeFiles/caffe.dir/all] Error 2
make[2]: *** Waiting for unfinished jobs....
[ 4%] Linking CXX static library ../../lib/libgtest.a
[ 4%] Built target gtest
CMakeFiles/Makefile2:372: recipe for target 'src/caffe/test/CMakeFiles/runtest.dir/rule' failed
make[1]: *** [src/caffe/test/CMakeFiles/runtest.dir/rule] Error 2
Makefile:255: recipe for target 'runtest' failed
make: *** [runtest] Error 2
Is there another way to install caffe in Jetson TX2 with jetpack 4.3??
