Hello.
Linux is not my strong side, therefore possible “silly” questions.
To the point. I have Jetson Nano according to instructions on Install Opencv 4.1 on Nvidia Jetson Nano - Pysource
I compiled Opencv 4.1.0. Everything OK. Because OpenCV 4.1.1 should be a bit faster, I want to try it for my project.
The only thing I found was for RPI 4
Install OpenCV 4 on Raspberry Pi 4 and Raspbian Buster - PyImageSearch
With that tutorial, I got to the point where I need to do cmake.
My Cmake which I modified the trial/error methods looks like this
cmake -D CMAKE_BUILD_TYPE=RELEASE \
-D CMAKE_INSTALL_PREFIX=/usr/local \
-D OPENCV_EXTRA_MODULES_PATH=~/opencv_contrib/modules \
-D WITH_CUDA=ON \
-D ENABLE_NEON=ON \
-D BUILD_opencv_python3=ON \
-D BUILD_TESTS=OFF \
-D INSTALL_PYTHON_EXAMPLES=OFF \
-D OPENCV_ENABLE_NONFREE=ON \
-D BUILD_EXAMPLES=OFF ..
This one has run for me without error. So I think without a mistake because before that I couldn’t make make -j4 and at the end was an errorlog.
-- OpenCV modules:
-- To be built: aruco bgsegm bioinspired calib3d ccalib core cudaarithm cudabgsegm cudacodec cudafeatures2d cudafilters cudaimgproc cudalegacy cudaobjdetect cudaoptflow cudastereo cudawarping cudev datasets dnn dnn_objdetect dpm face features2d flann freetype fuzzy gapi hfs highgui img_hash imgcodecs imgproc line_descriptor ml objdetect optflow phase_unwrapping photo plot python2 python3 quality reg rgbd saliency shape stereo stitching structured_light superres surface_matching text tracking ts video videoio videostab xfeatures2d ximgproc xobjdetect xphoto
-- Disabled: world
-- Disabled by dependency: -
-- Unavailable: cnn_3dobj cvv hdf java js matlab ovis sfm viz
-- Applications: perf_tests apps
-- Documentation: NO
-- Non-free algorithms: YES
-- GUI:
-- GTK+: YES (ver 3.22.30)
-- GThread : YES (ver 2.56.4)
-- GtkGlExt: NO
-- VTK support: NO
-- Media I/O:
-- ZLib: /usr/lib/aarch64-linux-gnu/libz.so (ver 1.2.11)
-- JPEG: /usr/lib/aarch64-linux-gnu/libjpeg.so (ver 80)
-- WEBP: build (ver encoder: 0x020e)
-- PNG: /usr/lib/aarch64-linux-gnu/libpng.so (ver 1.6.34)
-- TIFF: /usr/lib/aarch64-linux-gnu/libtiff.so (ver 42 / 4.0.9)
-- JPEG 2000: build (ver 1.900.1)
-- OpenEXR: build (ver 2.3.0)
-- HDR: YES
-- SUNRASTER: YES
-- PXM: YES
-- PFM: YES
-- Video I/O:
-- DC1394: YES (2.2.5)
-- FFMPEG: YES
-- avcodec: YES (57.107.100)
-- avformat: YES (57.83.100)
-- avutil: YES (55.78.100)
-- swscale: YES (4.8.100)
-- avresample: YES (3.7.0)
-- GStreamer: YES (1.14.5)
-- v4l/v4l2: YES (linux/videodev2.h)
-- Parallel framework: pthreads
-- Trace: YES (with Intel ITT)
-- Other third-party libraries:
-- Lapack: NO
-- Eigen: YES (ver 3.3.4)
-- Custom HAL: YES (carotene (ver 0.0.1))
-- Protobuf: build (3.5.1)
-- NVIDIA CUDA: YES (ver 10.0, CUFFT CUBLAS)
-- NVIDIA GPU arch: 53
-- NVIDIA PTX archs:
-- cuDNN: YES (ver 7.5.0)
-- OpenCL: YES (no extra features)
-- Include path: /home/georgeai/opencv/3rdparty/include/opencl/1.2
-- Link libraries: Dynamic load
-- Python 2:
-- Interpreter: /usr/bin/python2.7 (ver 2.7.15)
-- Libraries: /usr/lib/aarch64-linux-gnu/libpython2.7.so (ver 2.7.15+)
-- numpy: /usr/lib/python2.7/dist-packages/numpy/core/include (ver 1.13.3)
-- install path: lib/python2.7/dist-packages/cv2/python-2.7
-- Python 3:
-- Interpreter: /usr/bin/python3 (ver 3.6.8)
-- Libraries: /usr/lib/aarch64-linux-gnu/libpython3.6m.so (ver 3.6.8)
-- numpy: /usr/lib/python3/dist-packages/numpy/core/include (ver 1.13.3)
-- install path: lib/python3.6/dist-packages/cv2/python-3.6
-- Python (for build): /usr/bin/python2.7
-- Java:
-- ant: NO
-- JNI: NO
-- Java wrappers: NO
-- Java tests: NO
-- Install to: /usr/local
-- Configuring done
-- Generating done
-- Build files have been written to: /home/georgeai/opencv/build
But when I try to make -j4 it looks like it runs out but after 22% stop
[ 19%] Built target carotene_objs
Scanning dependencies of target opencv_core_pch_dephelp
[ 19%] Building CXX object modules/core/CMakeFiles/opencv_core_pch_dephelp.dir/opencv_core_pch_dephelp.cxx.o
In file included from /home/georgeai/opencv/modules/core/src/precomp.hpp:55:0,
from /home/georgeai/opencv/build/modules/core/opencv_core_pch_dephelp.cxx:1:
/home/georgeai/opencv/modules/core/include/opencv2/core/private.hpp:66:12: fatal error: Eigen/Core: No such file or directory
# include <Eigen/Core>
compilation terminated.
modules/core/CMakeFiles/opencv_core_pch_dephelp.dir/build.make:62: recipe for target 'modules/core/CMakeFiles/opencv_core_pch_dephelp.dir/opencv_core_pch_dephelp.cxx.o' failed
make[2]: *** [modules/core/CMakeFiles/opencv_core_pch_dephelp.dir/opencv_core_pch_dephelp.cxx.o] Error 1
CMakeFiles/Makefile2:2772: recipe for target 'modules/core/CMakeFiles/opencv_core_pch_dephelp.dir/all' failed
make[1]: *** [modules/core/CMakeFiles/opencv_core_pch_dephelp.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
[ 19%] Building CXX object 3rdparty/protobuf/CMakeFiles/libprotobuf.dir/src/google/protobuf/util/internal/json_objectwriter.cc.o
[ 19%] Building CXX object 3rdparty/protobuf/CMakeFiles/libprotobuf.dir/src/google/protobuf/util/internal/json_stream_parser.cc.o
[ 19%] Building CXX object 3rdparty/protobuf/CMakeFiles/libprotobuf.dir/src/google/protobuf/util/internal/object_writer.cc.o
[ 19%] Building CXX object 3rdparty/protobuf/CMakeFiles/libprotobuf.dir/src/google/protobuf/util/internal/proto_writer.cc.o
[ 19%] Building CXX object 3rdparty/protobuf/CMakeFiles/libprotobuf.dir/src/google/protobuf/util/internal/protostream_objectsource.cc.o
[ 19%] Building CXX object 3rdparty/protobuf/CMakeFiles/libprotobuf.dir/src/google/protobuf/util/internal/protostream_objectwriter.cc.o
[ 20%] Building CXX object 3rdparty/protobuf/CMakeFiles/libprotobuf.dir/src/google/protobuf/util/internal/type_info.cc.o
[ 20%] Building CXX object 3rdparty/protobuf/CMakeFiles/libprotobuf.dir/src/google/protobuf/util/internal/utility.cc.o
[ 20%] Building CXX object 3rdparty/protobuf/CMakeFiles/libprotobuf.dir/src/google/protobuf/util/json_util.cc.o
[ 20%] Building CXX object 3rdparty/protobuf/CMakeFiles/libprotobuf.dir/src/google/protobuf/util/message_differencer.cc.o
[ 20%] Building CXX object 3rdparty/protobuf/CMakeFiles/libprotobuf.dir/src/google/protobuf/util/time_util.cc.o
[ 20%] Building CXX object 3rdparty/protobuf/CMakeFiles/libprotobuf.dir/src/google/protobuf/util/type_resolver_util.cc.o
[ 20%] Building CXX object 3rdparty/protobuf/CMakeFiles/libprotobuf.dir/src/google/protobuf/wire_format.cc.o
[ 20%] Building CXX object 3rdparty/protobuf/CMakeFiles/libprotobuf.dir/src/google/protobuf/wrappers.pb.cc.o
[ 20%] Linking CXX static library ../lib/liblibprotobuf.a
[ 20%] Built target libprotobuf
Makefile:162: recipe for target 'all' failed
make: *** [all] Error 2
At this point, is my knowledge done. I do not know what is wrong or where there is a mistake and I would be happy if someone could advise me. This OpenCV 4.1.1 I wanted to try and I know it works respectively. it is possible.
Thanks for help
