Processing: scp57131…
opencv.txt (1.9 KB)
If you would like to manually compile/install OpenCV, please try this script:
JEP/install_opencv4.5.0_Jetson.sh at master · AastaNV/JEP · GitHub
It is 4.5.0. If you need 4.1.1, please modify the script accordingly.
opencv_ Contrib-4.1.1 can it be solved 使用Ptr<BasicFaceRecognizer>model = EigenFaceRecognizer::create();错误
