Call to cuLaunchKernel results in CUDA_ERROR_LAUNCH_OUT_OF_RESOURCES
I’m working on an optimization project that uses CUDA but keep running into an issue where after the first launch of the kernel (which runs fine) every subsequent launch throws the error “Call to cuLaunchKernel results in CUDA_ERROR_LAUNCH_OUT_OF_RESOURCES”. I’m very new to CUDA so unsure how to debug this or fix it. Here’s what I have (apologies in advance for the obvious obfuscations):
@cuda.jit
def main_kernel(
    input_1, input_2, input_3, input_4, input_5, input_6, input_7,
    param_1, param_2, param_3, param_4, param_5, param_6, param_7,
    results, multiplier
    pos = cuda.grid(1)
    stride = cuda.gridsize(1)
    total_combinations = len(param_1) * len(param_2) * len(param_3)* len(param_4) * len(param_5) * len(param_6) * len(param_7)
    for param_idx in range(pos, total_combinations, stride):
        result_idx = param_idx
        if result_idx < len(results):
            results[result_idx, 0] = 0
            results[result_idx, 1] = 0
            results[result_idx, 2] = 0
            results[result_idx, 3] = 0
            results[result_idx, 4] = 0
            results[result_idx, 5] = 0
            results[result_idx, 6] = 0
            results[result_idx, 7] = 0
            results[result_idx, 8] = 0
            results[result_idx, 9] = 0
            results[result_idx, 10] = 0
def run_optimization(data, data_ID, param_7=None):
    with open("E:\\CUDA_TESTING\\test_config.json") as f:
            q = json.load(f)
    if data_ID in q.keys():
        step = q[data_ID]["tick_size"]
        multiplier = q[data_ID]["asset_multiplier"]
    param_1 = np.array([2], dtype=np.int8)
    param_2 = np.array([4*step * i for i in range(1, 101)], dtype=np.float32)
    param_3 = np.array([4*step * i for i in range(1, 201)], dtype=np.float32)
    param_4 = step * np.array([0.0, 40, 60, 80, 100], dtype=np.int8)
    param_5 = np.array([0, 10, 20, 30, 60, 120], dtype=np.int8)
    param_6 = np.array([1, 2, 3, 4], dtype=np.int8)
    param_7_old = param_7
    param_7 = np.array([int(x) for x in param_7], dtype=np.int16)
    print(f"Preparing data for []...")
    input_1, input_2, input_3, input_4, input_5, input_6, input_7 = preprocess_data(
        data, param_7
    total_combinations = (
        len(param_1) * len(param_2) * len(param_3) *
        len(param_4) *
        len(param_5) * len(param_6) * len(param_7_old)
    print(f"Testing {total_combinations} parameter combinations for {data_ID}...")
    results = np.zeros((total_combinations, 11), dtype=np.float32)
    d_input_1 = cuda.to_device(input_1) # float32; 4 bytes; cumulative 4 bytes
    d_input_2 = cuda.to_device(input_2) # float32; 4 bytes; cumulative 8 bytes
    d_input_3 = cuda.to_device(input_3) # float32; 4 bytes; cumulative 12 bytes
    d_input_4 = cuda.to_device(input_4) # float32; 4 bytes; cumulative 16 bytes
    d_input_5 = cuda.to_device(input_5) # float32; 4 bytes; cumulative 20 bytes
    d_input_6 = cuda.to_device([int(t[:10].replace('-', '')) for t in input_5]) # int32; 4 bytes; cumulative 29 bytes
    d_input_7 = cuda.to_device(input_7) # int8; 1 byte; cumulative 25 bytes
    d_param_1 = cuda.to_device(param_1) # int8; 1 byte; cumulative 30 bytes
    d_param_2 = cuda.to_device(param_2) # float32; 4 bytes; cumulative 34 bytes
    d_param_3 = cuda.to_device(param_3) # float32; 4 bytes; cumulative 38 bytes
    d_param_4 = cuda.to_device(param_4) # int8; 1 byte; cumulative 39 bytes
    d_param_5 = cuda.to_device(param_5) # int8; 1 byte; cumulative 40 bytes
    d_param_6 = cuda.to_device(param_6) # int8; 1 byte; cumulative 41 bytes
    d_param_7 = cuda.to_device(param_7) # int16; 2 bytes; cumulative 43 bytes
    d_results = cuda.to_device(results) # 48 byte array; cumulative 96 bytes
    blocks = min(MAX_BLOCKS, (total_combinations + THREADS_PER_BLOCK - 1) // THREADS_PER_BLOCK)
    print(f"Launching CUDA kernel for {data_ID} with {blocks} blocks, {THREADS_PER_BLOCK} threads per block")
    start_time = time.time()
    main_kernel[blocks, THREADS_PER_BLOCK](
        d_input_1, d_input_2, d_input_3, d_input_4, d_input_5, d_input_6, d_input_7,
        d_param_1, d_param_2, d_param_3, d_param_4, d_param_5, d_param_6,
        d_param_7, d_results, multiplier
    # Copy results back from GPU
    results = d_results.copy_to_host()
    cuda.get_current_device().reset()
    cuda.close()
    end_time = time.time()
    print(f"CUDA execution for {data_ID} completed in {end_time - start_time:.2f} seconds")
    return results
def main():
    warnings.filterwarnings('ignore')
    data_dirs = {
        'test': 'E:\\CUDA_TESTING',
    param_7 = ["1", "2", "3", "4"]
    print(f"Running optimization ...")
    all_results = []
    files = os.listdir(data_dirs['test'])
    for file_path in files:
        try:
            data, data_ID = load_data(data_dirs['test'] + "\\" + file_path)
            # Run optimization
            results = run_optimization(
                data, data_ID, param_7=param_7
            print(f"Completed optimization for {data_ID}")
        except Exception as e:
            data_ID = os.path.basename(file_path).split('.')[0]
            print(f"Error processing {data_ID}: {str(e)}")
        print(f"Optimization completed successfully!")
    print("All optimizations completed successfully!")
if __name__ == "__main__":
    main()
Running this returns the following:
Testing 9600000 parameter combinations for TEST_1...
Launching CUDA kernel for TEST_1 with 32 blocks, 512 threads per block
CUDA execution for TEST_1 completed in 0.62 seconds
Completed optimization for TEST_1
Testing 9600000 parameter combinations for TEST_2...
Launching CUDA kernel for TEST_2 with 32 blocks, 512 threads per block
Error processing TEST_2: [701] Call to cuLaunchKernel results in CUDA_ERROR_LAUNCH_OUT_OF_RESOURCES
Testing 9600000 parameter combinations for TEST_3...
Launching CUDA kernel for TEST_3 with 32 blocks, 512 threads per block
Error processing TEST_3: [701] Call to cuLaunchKernel results in CUDA_ERROR_LAUNCH_OUT_OF_RESOURCES
Testing 9600000 parameter combinations for TEST_4...
Launching CUDA kernel for TEST_4 with 32 blocks, 512 threads per block
Error processing TEST_4: [701] Call to cuLaunchKernel results in CUDA_ERROR_LAUNCH_OUT_OF_RESOURCES
Error processing test_config: Unsupported file extension: .json
Wondering if anybody has some advice. The input lengths are around 24000, I’m running an optimization over a long time series. I’m not sure how to check how much memory I’m using or how much I’m able to use, so if anybody has advice I would love to hear it. I’ve run other optimizations with many more combinations and more input parameters, so not sure why this is killing itself like this.
why are you doing this:
do you have the same trouble if you just remove that line?
If my understanding is correct that resets whatever memory is being taken up in the GPU at that point in the code but I’m not sure that’s right, somebody I work with told me to try it. Removing both of those reset lines doesn’t change anything.
could you also remove this line:
and retest
Seems like removing all of the reset() and close() lines did the job. Thank you!
