I’m trying to add the Optix denoiser to a Vulkan ray tracing application. I’ve been following the sample available here: GitHub - nvpro-samples/vk_denoise: Denoising a Vulkan ray traced image using OptiX denoiser
It works just fine if I allocate a single vk::DeviceMemory per vk::Buffer, but as soon as I allocate a single vk::DeviceMemory for multiple vk::Buffers, the memory offset is no longer 0 (assuming I’m not using the first block) and the call tho the cudaExternalMemoryGetMappedBuffer will fail with code 1.
If I run the program with cuda and optix disabled, both memory managers work correctly, so it’s not that the memory is malformed or corrupted.
Why does cuda crash when I try to use a memory object at an offset? Are there any additional steps I have to take in order to use it at an offset?
Here’s the segment of the code:
vk::MemoryGetWin32HandleInfoKHR handleInfo;
handleInfo.memory = cudaBuffer.buffer->m_allocId->memory();
handleInfo.handleType = vk::ExternalMemoryHandleTypeFlagBits::eOpaqueWin32;
cudaBuffer.handle = VulkanContext::getDevice().getMemoryWin32HandleKHR(handleInfo);
vk::MemoryRequirements memoryRequirements =
VulkanContext::getDevice().getBufferMemoryRequirements(
cudaBuffer.buffer->get());
cudaExternalMemoryHandleDesc cudaExtMemHandleDesc{};
cudaExtMemHandleDesc.size = memoryRequirements.size;
cudaExtMemHandleDesc.type = cudaExternalMemoryHandleTypeOpaqueWin32;
cudaExtMemHandleDesc.handle.win32.handle = cudaBuffer.handle;
cudaExternalMemory_t cudaExtMemVertexBuffer{};
CUDA_CHECK(cudaImportExternalMemory(&cudaExtMemVertexBuffer, &cudaExtMemHandleDesc));
cudaExternalMemoryBufferDesc cudaExtBufferDesc{};
cudaExtBufferDesc.offset = cudaBuffer.buffer->m_allocId->offset;
cudaExtBufferDesc.size = memoryRequirements.size;
cudaExtBufferDesc.flags = 0;
CUDA_CHECK(cudaExternalMemoryGetMappedBuffer(
&cudaBuffer.cudaPtr,
&cudaExtBufferDesc));
If cudaExtBufferDesc.offset is not 0, the program will always fail at the final line.
How do I map to a memory object at an offset?
