I am porting the following code
device void SHA1_Create(PSHA1CTX pCtx)
SHA1_Initialize(pCtx);
return;
device void SHA1_Initialize(PSHA1CTX pCtx)
// init the digest
SHA1_Reset(pCtx);
// set the bit counter to zero
pCtx->lCountLo = pCtx->lCountHi = 0;
device void SHA1_Reset
(PSHA1CTX pCtx)
And I am getting the following compilation error code in visual studio:
Performing Custom Build Step
“.\duplicate_kernel.cu”, line 257: error: calling a host function from a
device/global function is only allowed in device emulation
mode
“.\duplicate_kernel.cu”, line 266: error: calling a host function from a
mode
SHA1_Reset(pCtx);
As you can see both functions are declared as device, so I am not sure what the error code means. Any suggestions?
