calling CUDA from fortran
I am trying to see if I can port a Fortran subroutine to CUDA and call it from Fortran itself. Is this possible?
Obviously I will have to allocate the device pointers and execute memcopy(device) and memcopy(host) each time the function is called.
I am using Intel Compiler 11 (ifort) to compile the Fortran code. My approach is to have the Fortran compiled object files linked with CUDA(nvcc) so that I compare the CUDA kernel vs the Fortran subroutine. Any pointers/references?
You could write wrappers for each function. The blas library has good examples,. Alternatively you could try PGI. Same principle as CUDA C , but more complicated. Check here also http://developer.nvidia.com/cuda-fortran and this http://www.hoopoe-cloud.com/Solutions/Fortran/Default.aspx
Thanks for the update.
I downloaded the CUDA-Fortran sample from the Nvidia page http://developer.nvidia.com/cuda-fortran
Works well with gfortran, g77 and ifort !!!
Based on the Fortran Cuda example, I wrote a dummy CUDA kernel and I called it using extern “C” inside the Fortran code and added the foll:
$(F77) -o test.run $(OBJS) -llapack -lblas $(CUDAINC) $(CUDALIB) -lcudart
But this gives me the following error:
/usr/bin/ld: cannot find -lcudart
collect2: ld returned 1 exit status
However, my LD_LIBRARY_PATH has /usr/local/cuda/lib64/
I am using gfortran (gcc-4.4.0) and CUDA 4.0 Any suggestions?
You need to pass the location of cudart (-L./usr/local/cuda/lib64).
LD_LIBRARY_PATH is not used by the linker.
Thanks !!!
I was using CUDALIB = /usr/local/cuda/lib64
Now I use
$(F77) -o test.run $(OBJS) -L/usr/local/cuda/lib64/ -lcudart -llapack -lblas
and just see a warning:
/usr/bin/ld: warning: libgfortran.so.1, needed by /usr/lib/…/lib64/liblapack.so, may conflict with libgfortran.so.3
I apologize to be bad mouth, but really using FORTRAN with CUDA is quite tedious. I use FORTRAN for my CPU codes, but I found it easier to use CUDA C for nvidia. I had only a short course in C 12 years ago.
