Hi there,
I’m using OpenGL-Cuda Interop, in order to directly display the computed data. I generate a vbo and use its ID to get the device pointer like this.
cutilSafeCall( cudaGraphicsGLRegisterBuffer(&cudaGR[0], vboID, cudaGraphicsMapFlagsNone));
cudaGraphicsResourceGetMappedPointer((void**) &d_ptr, &Size, cudaGR[0]);
cutilSafeCall(cudaGraphicsUnmapResources(1, &cudaGR[0]));
Everything works fine. Now, there is another place in the code where a cuda kernel needs the data that is stored in the VBO. So basically, I used the same code as above and it also worked. Now, I did a driver update from 280.26 to 285.62 and calling cudaGraphicsGLRegisterBuffer the second time for the same vbo id results in a “Runtime API error 10208: unspecified driver error”.
I did not find any information if it is illegal to call cudaGraphicsGLRegisterBuffer twice for the same id or if it is a bug in the latest driver. Any ideas?
Thank you!
