Hi, I’m new to CUDA programming so my question might be silly. Also sorry for my english :)
I want to learn how to use CUDA Buffers with OpenGL textures. I copied some code from Mandelbrot CUDA SDK example. My code compiles without errors or warning, but when I try to run it I get this output
Creating GL texture...
Texture created.
Creating PBO...
src/main.cu(115) : cudaSafeCall() Runtime API error : unspecified driver error.
line 115 is
cutilSafeCall(cudaGraphicsGLRegisterBuffer(&cuda_pbo_resource, gl_PBO,cudaGraphicsMapFlagsWriteDiscard));
I don’t think it’s driver issue, because I can run Mandelbrot example on my system (and this, and some other lines, are copied from Mandelbrot example).
My whole aplication code
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <cstdio>
#include <GL/glew.h>
#if defined(__APPLE__) || defined(MACOSX)
#include <GLUT/glut.h>
#else
#include <GL/glut.h>
#endif
#ifdef _WIN32
#include <GL/wglew.h>
#endif
#include <cuda_runtime_api.h>
#include <cutil_inline.h>
#include <cutil_gl_inline.h>
#include <cuda_gl_interop.h>
#include <rendercheck_gl.h>
// includes, kernels
#include "kernel.cu"
#define BUFFER_DATA(i) ((char *)0 + i)
/* The number of our GLUT window */
int window;
int size; //initial size of window
int imageW;
int imageH;
unsigned char* h_data;
unsigned char* d_data;
int frame = 0, mtime, timebase = 0;
float fps;
//OpenGL PBO and texture "names"
GLuint gl_PBO, gl_Tex;
struct cudaGraphicsResource *cuda_pbo_resource; // handles OpenGL-CUDA exchange
//Source image on the host side
uchar4 *h_Src = 0;
// Destination image on the GPU side
uchar4 *d_dst = NULL;
/* A general OpenGL initialization function. Sets all of the initial parameters. */
GLvoid InitGL(GLsizei Width, GLsizei Height) // We call this right after our OpenGL window is created.
glEnable(GL_TEXTURE_2D); // Enable texture mapping.
glClearColor(0.0f, 0.0f, 0.2f, 0.0f); // This Will Clear The Background Color To Black
glClearDepth(1.0); // Enables Clearing Of The Depth Buffer
glShadeModel(GL_SMOOTH); // Enables Smooth Color Shading
glMatrixMode(GL_PROJECTION);
glLoadIdentity(); // Reset The Projection Matrix
gluPerspective(45.0f,(GLfloat)Width/(GLfloat)Height,0.1f,100.0f); // Calculate The Aspect Ratio Of The Window
glMatrixMode(GL_MODELVIEW);
void initOpenGLBuffers(int w, int h)
// delete old buffers
if (h_Src) {
free(h_Src);
h_Src = 0;
if (gl_Tex) {
glDeleteTextures(1, &gl_Tex);
gl_Tex = 0;
if (gl_PBO) {
cudaGraphicsUnregisterResource(cuda_pbo_resource);
glDeleteBuffers(1, &gl_PBO);
gl_PBO = 0;
// check for minimized window
if ((w==0) && (h==0)) {
return;
// allocate new buffers
h_Src = (uchar4*)malloc(w * h * 4);
printf("Creating GL texture...\n");
glGenTextures(1, &gl_Tex);
glBindTexture(GL_TEXTURE_2D, gl_Tex);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_S, GL_CLAMP);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_T, GL_CLAMP);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_NEAREST);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_NEAREST);
glTexImage2D(GL_TEXTURE_2D, 0, GL_RGBA8, w, h, 0, GL_RGBA, GL_UNSIGNED_BYTE, h_Src);
printf("Texture created.\n");
printf("Creating PBO...\n");
glGenBuffers(1, &gl_PBO);
glBindBuffer(GL_PIXEL_UNPACK_BUFFER_ARB, gl_PBO);
glBufferData(GL_PIXEL_UNPACK_BUFFER_ARB, w * h * 4, h_Src, GL_STREAM_COPY);
//While a PBO is registered to CUDA, it can't be used
//as the destination for OpenGL drawing calls.
//But in our particular case OpenGL is only used
//to display the content of the PBO, specified by CUDA kernels,
//so we need to register/unregister it only once.
printf("PBO created.\n");
void InitData()
cudaSetDevice( cutGetMaxGflopsDeviceId() );
glewInit();
initOpenGLBuffers(imageW, imageH);
/* The function called when our window is resized */
GLvoid ReSizeGLScene(GLsizei Width, GLsizei Height)
if (Height==0) // Prevent A Divide By Zero If The Window Is Too Small
Height=1;
glViewport(0, 0, Width, Height);
glLoadIdentity();
glOrtho(0.0, 1.0, 0.0, 1.0, 0.0, 1.0);
glLoadIdentity();
imageW=Width;
imageH=Height;
initOpenGLBuffers(Width, Height);
void ComputeFPS()
frame++;
mtime = glutGet( GLUT_ELAPSED_TIME );
if( mtime - timebase > 1000 )
fps = (float)(frame * 1000) /( float )( mtime - timebase ) ;
timebase = mtime;
frame = 0;
char fpstext[256];
sprintf(fpstext, "fps: %3.1f", fps);
glutSetWindowTitle(fpstext);
void ComputeBitmap()
dim3 grid( ((imageW*imageH)/512)+1, 1, 1);
dim3 threads( 512, 1, 1);
cutilSafeCall(cudaGraphicsMapResources(1, &cuda_pbo_resource, 0));
size_t num_bytes;
cutilSafeCall(cudaGraphicsResourceGetMappedPointer((void**)&d_dst, &num_bytes, cuda_pbo_resource));
test_buf<<<grid, threads>>>(d_dst, imageW*imageH);
cutilCheckMsg("Kernel execution failed");
cutilSafeCall(cudaGraphicsUnmapResources(1, &cuda_pbo_resource, 0));
ComputeFPS();
/* The main drawing function. */
GLvoid DrawGLScene()
ComputeBitmap();
glLoadIdentity(); // reset the view before we draw each star.
glDisable(GL_DEPTH_TEST);
glTexSubImage2D(GL_TEXTURE_2D, 0, 0, 0, imageW, imageH, GL_RGBA, GL_UNSIGNED_BYTE, BUFFER_DATA(0));
glBegin(GL_QUADS); // Begin Drawing The Textured Quad
glTexCoord2f(0.0f, 0.0f); glVertex2f(0.0f,0.0f);
glTexCoord2f(1.0f, 0.0f); glVertex2f(1.0f,0.0f);
glTexCoord2f(1.0f, 1.0f); glVertex2f(1.0f,1.0f);
glTexCoord2f(0.0f, 1.0f); glVertex2f(0.0f,1.0f);
glEnd(); // Done Drawing The Textured Quad
glBindTexture(GL_TEXTURE_2D, 0);
// since this is double buffered, swap the buffers to display what just got drawn.
glutSwapBuffers();
ComputeFPS();
GLvoid OnClose()
cudaThreadExit();
void usage(char* arg)
fprintf(stdout, "USAGE:\n%s windowSize chargesCount maxCharge maxColoredCharge\n", arg);
fflush(stdout);
int main(int argc, char** argv)
//setting GL window
/* Initialize GLUT state - glut will take any command line arguments that pertain to it or
X Windows - look at its documentation at http://reality.sgi.com/mjk/spec3/spec3.html */
glutInit(&argc, argv);
if(argc!=5)
usage(argv[0]);
return EXIT_FAILURE;
try
size=atoi(argv[1]);
imageW=size;
imageH=size;
//chargesCount=atoi(argv[2]);
//maxCharge=atoi(argv[3]);
//maxColoredCharge=atoi(argv[4]);
catch(...)
fprintf(stdout, "Bad parameter(s) format\n");
fflush(stdout);
usage(argv[0]);
/* Select type of Display mode:
Double buffer
RGBA color */
glutInitDisplayMode(GLUT_RGBA | GLUT_DOUBLE);
/* get a window */
glutInitWindowSize(size, size);
/* the window starts at the upper left corner of the screen */
glutInitWindowPosition(0, 0);
/* Open a window */
window = glutCreateWindow("Project CUDA");
/* Register the function to do all our OpenGL drawing. */
glutDisplayFunc(&DrawGLScene);
/* Even if there are no events, redraw our gl scene. */
glutIdleFunc(&DrawGLScene);
/* Register the function called when our window is resized. */
glutReshapeFunc(&ReSizeGLScene);
atexit(&OnClose);
/* Initialize our window. */
InitGL(size, size);
InitData();
/* Start Event Processing Engine */
glutMainLoop();
and very simple kernel
__global__ void test_buf(uchar4* data, int size)
int tid = blockIdx.x * blockDim.x + threadIdx.x;
unsigned char c = threadIdx.x%256;
if(tid<size)
data[tid] = make_uchar4(c,c,c,0);
What I am not doing or doing wrong?
