OpenGL Error
Hi Im using 9800GT on windows platform, using Visual studios for coding. Im trying to use OpenGL to increase my display rate but there has been a problem on the pixel buffer. Following is my code.
void createVBO(GLuint* pixel_buffer, struct cudaGraphicsResource **cuda_pixel_resource){
if(pixel_buffer){ // create buffer object
glGenBuffers(1, pixel_buffer);
glBindBuffer(GL_ARRAY_BUFFER, *pixel_buffer); //register buffer on cuda
unsigned int size = XDIM * YDIM * 4 * sizeof(float);
glBufferData(GL_ARRAY_BUFFER, size, 0, GL_DYNAMIC_DRAW);
glBindBuffer(GL_ARRAY_BUFFER, 0);
CUT_CHECK_ERROR(cudaGraphicsGLRegisterBuffer(cuda_pixel_resource,
*pixel_buffer, cudaGraphicsMapFlagsWriteDiscard)); }
else{ cutilSafeCall( cudaMalloc( (void **)&d_vbo_buffer, XDIMYDIM4*sizeof(float) ) ); }}
int main(int argc, char *argv) {
// Pre-Calculation
readData();
convertor(); //convert values into single float
calc_resample_coefficients();
// Explicitly set device
glutInit(&argc, argv);
glewInit();
int device;
cudaGLGetDevice(&device)
cudaGLSetGLDevice(device);
glutInitDisplayMode(GLUT_RGBA | GLUT_DOUBLE);
glutInitWindowSize(window_width, window_height);
glutCreateWindow(“Cuda GL Interop (VBO)”);
glutDisplayFunc(display); // Create buffer object and register it with CUDA
createVBO(&pbo, &cuda_pbo_resource); // Loop
glutMainLoop();
deleteVBO();
cudaThreadExit();}
Im having some error saying
CUDA error: in file ‘my file path …’ in line 131: device kernel image is invalid.
Did somebody have similar problem before? Can someone help me? Thank you
Line 131 is CUT_CHECK_ERROR(cudaGraphicsGLRegisterBuffer(cuda_pixel_resource, *pixel_buffer, cudaGraphicsMapFlagsWriteDiscard));
Oh by the way my code does not have any rendering stuffs as in simpleGL. Do I need it? Can somebody help me out with how to start rendering? I have no clue of what is going on with that part. Thanks
And when I check cudaGraphicsMapResource in code bellow it the command window throws
.\Resampling_GL.cpp<143> : cudaSafeCall<> Runtime API error: invalid resource handle. Does this ring a bell? Thanks
Following is my code:
// includes, system
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
// includes, GL
#include <GL/glew.h>
#include <GL/glu.h>
//#include <GL/freeglut.h>
#include <GL/glut.h>
// includes CUDA <--> C++ interlops
#include <cuda_runtime.h>
#include <cutil_inline.h>
#include <cutil_gl_inline.h>
#include <cutil_gl_error.h>
#include <cuda_gl_interop.h>
//define variables
#define XDIM 1000 //original value 1000
#define YDIM 1024 //original value 1024
#define FRAMES 20
#define START_WAVELENGTH 7.5226E+02
#define WAVELENGTH_SPACING 8.6969E-02
#define SECOND_ORDER_CORRECTION -4.2264E-06
#define THIRD_ORDER_CORRECTION 8.9511E-10
#define FOURTH_ORDER_CORRECTION -1.7987E-13
#define LINE_LENGTH 1024	//Note same as YDIM, should be fixed
#define CAPTURE_LINE_OFFSET 800
#define RESAMPLE_POINTS 1024
// variables into cuda
unsigned char a[XDIM*XDIM*YDIM];
float resamp_1D[LINE_LENGTH*2], original_cpu[FRAMES*XDIM*YDIM], *dev_original;
float k_resampledspacing;
cuComplex d_in[YDIM*XDIM];
float dc_subtracted[YDIM*XDIM];
int frame=0;
float sum=0;
const unsigned int window_width = 1000;
const unsigned int window_height = 1024;
float4 *d_vbo_buffer;
// pbo variables
GLuint pbo;
struct cudaGraphicsResource *cuda_pbo_resource;
char inputfile[] = "joecornearadialvolume.unp";
extern "C"
void launch_kernel(float* sum, float* original_data, int* frame_num, cuComplex* d, float* k_resamp, float* dc_subtracted, float* resample, float4 *ptr);
// Read Data from file
void readData() {..}
void convertor(){}
void calc_resample_coefficients() {}
//simply use cudaGraphicsMapFlagsWriteDiscard as cudaGraphicsResource
	if(pixel_buffer){
	cudaGraphicsGLRegisterBuffer(cuda_pixel_resource, *pixel_buffer, cudaGraphicsMapFlagsWriteDiscard);
	CUT_CHECK_ERROR_GL();
	else{
	cutilSafeCall( cudaMalloc( (void **)&d_vbo_buffer, XDIM*YDIM*4*sizeof(float) ) );
void display() {
	// Map buffer object for writing from CUDA
	float4* pix_buff;
	cutilSafeCall(cudaGraphicsMapResources(1, &cuda_pbo_resource, 0)); //where invalid resource handle appears
	size_t num_bytes;
	cutilSafeCall(cudaGraphicsResourceGetMappedPointer((void**)&pix_buff, &num_bytes, cuda_pbo_resource));
	// Execute kernel
	// will execute by calling kernel.cu file
	if(pbo)
	launch_kernel(&sum, original_cpu, &frame, d_in, &k_resampledspacing, dc_subtracted, resamp_1D, pix_buff);
	else launch_kernel(&sum, original_cpu, &frame, d_in, &k_resampledspacing, dc_subtracted, resamp_1D, d_vbo_buffer);
	// Unmap buffer object
	cutilSafeCall(cudaGraphicsUnmapResources(1, &cuda_pbo_resource, 0));
	// copy to Open_gl texture
	// Render from buffer object
	glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT);
	glBindBuffer(GL_ARRAY_BUFFER, pbo);
	glVertexPointer(4, GL_FLOAT, 0, 0);
	glEnableClientState(GL_VERTEX_ARRAY);
	glDrawArrays(GL_POINTS, 0, XDIM * YDIM);
	glDisableClientState(GL_VERTEX_ARRAY);
	// Swap buffers
	glutSwapBuffers();
	glutPostRedisplay();
void deleteVBO() {
	cudaGraphicsUnregisterResource(cuda_pbo_resource);
	glDeleteBuffers(1, &pbo);
int main(int argc, char *argv[]) {
   //set GL context first.
   glutCreateWindow("Cuda GL Interop (VBO)");
glewInit();
int device;
   cudaGetDevice(&device);
   // Pre-Calculation
readData();
//Cuda Memory Allocation
// Loop
glutMainLoop();
deleteVBO();
cudaThreadExit();
Can somebody please give me suggestion? I cannot find any thing wrong. If possible can someone please look at my code? Ill send my code.
Part where Im getting that error is
void runCuda(struct cudaGraphicsResource **pbo_resource) {
float4* pix_buff;
cutilSafeCall(cudaGraphicsMapResources(1, pbo_resource, 0)); <- Here
size_t num_bytes;
cutilSafeCall(cudaGraphicsResourceGetMappedPointer((void **)&pix_buff, &num_bytes, *pbo_resource));
cutilSafeCall(cudaGraphicsUnmapResources(1, pbo_resource, 0));
By the way how can simpleGL sdk work without ignoring libcmt.lib ???
