Hi Im using 9800GT on windows platform. Following is my code.
int main(int argc, char *argv[]) {
// Pre-Calculation
readData();
convertor(); //convert values into single float
calc_resample_coefficients();
//Cuda Memory Allocation
// Explicitly set device
glutInit(&argc, argv);
glewInit();
cudaGLSetGLDevice(2);
CUcontext *pCtx = NULL;
cuInit(0);
cuCtxCreate(pCtx, CU_CTX_MAP_HOST, 0);
cuGLInit();
cuGLCtxCreate(pCtx, CU_CTX_MAP_HOST, 0);
int frame = 0, sum =0;
cudaMalloc((void**)&dev_frame, sizeof(int));
cudaMalloc((void**)&dev_sum, sizeof(int));
cudaMalloc((void**)&dev_original, sizeof(float)*FRAMES*XDIM*YDIM);
cudaMalloc((void**)&d_in,sizeof(cuComplex)*YDIM*XDIM);
cudaMalloc((void**)&dev_resamp, sizeof(float)*LINE_LENGTH*2);
cudaMalloc((void**)&dev_k_resampledspacing, sizeof(float));
cudaMalloc((void**)&dc_subtracted, sizeof(float)*XDIM*YDIM);
cudaMemcpy(dev_k_resampledspacing, &k_resampledspacing, sizeof(float), cudaMemcpyHostToDevice);
cudaMemcpy(dev_resamp, resamp_1D, sizeof(float)*LINE_LENGTH*2, cudaMemcpyHostToDevice);
cudaMemcpy(dev_original, original_cpu, sizeof(float)*FRAMES*XDIM*YDIM, cudaMemcpyHostToDevice);
cudaMemcpy(dev_frame, &frame, sizeof(int), cudaMemcpyHostToDevice);
cudaMemcpy(dev_sum, &sum, sizeof(int), cudaMemcpyHostToDevice);
glutInitDisplayMode(GLUT_RGBA | GLUT_DOUBLE);
glutInitWindowSize(window_width, window_height);
glutCreateWindow("Cuda GL Interop (VBO)");
glutDisplayFunc(display);
// Create buffer object and register it with CUDA
createVBO(&pbo, &cuda_pbo_resource);
// Loop
glutMainLoop();
deleteVBO();
cudaThreadExit();
If I run the code I get device kernel image is invalid. Does this mean I have problem with my GPU? Can someone guide me how to solve this if had similar problem? Thank you.
Regards,
Jaehong Yoon
