CUDA + OpenGL Unspecified launch failure in prior launch
Hi all,
I’ve been trying to understand how to use CUDA+OpenGL+VBO’s for some graphical rendering of my data (which is continuously being modified by CUDA kernels). From what I read it seems the best way to to this is with a VBO. I started by following the example code in the programming guide (under ‘OpenGL Interoperability’, page 38) and can’t get it to work properly - it compiles, runs and even displays some initialisation data (which reside on the host), but I found my CUDA calls weren’t having an effect. So I surrounded all CUDA calls with ‘CUDA_SAFE_CALL’ and back-traced my issue back to this line:
CUDA_SAFE_CALL( cudaGraphicsGLRegisterBuffer(&vboID_d, vboID_h, cudaGraphicsMapFlagsNone) ); // unspecified launch failure in prior launch
I don’t even know if cuda-gdb could be of use here? I’ve been attempting to get a simple OpenGL+CUDA program working for about a week now. I should note that I’m new to OpenGL, so I’m not even sure exactly what’s going on here… I adapted this code from the programming guide and from the ‘nbody’ SDK example (The source-code of which I found to be very confusing!). Here are some snippets of my code to illustrate what I’m attempting to do:
Note: All this code, unless specified otherwise, is in the same file and uses globals.
// Global Variables
GLuint vboID_h;
cudaGraphicsResource* vboID_d;
void main(){
initGL();
initVBO();
cudaSetGLDevice(0);
glutDisplayFunc(display);
glutMainLoop();
void initGL(int argc, char** argv)
	// First initialize OpenGL context, so we can properly set the GL for CUDA.
	// This is necessary in order to achieve optimal performance with OpenGL/CUDA interop.
	glutInit(&argc, argv);
	glutInitDisplayMode(GLUT_RGB | GLUT_DEPTH | GLUT_DOUBLE);
	glutInitWindowSize(720, 480);
	glutCreateWindow("CUDA & OpenGL Simulation");
	if (bFullscreen)
		glutFullScreen();
	GLenum err = glewInit();
	if (GLEW_OK != err)
		shrLog("GLEW Error: %s\n", glewGetErrorString(err));
		exit(-1);
	else if (!glewIsSupported("GL_VERSION_2_0 "
						 "GL_VERSION_1_5 "
						 "GL_ARB_multitexture "
						 "GL_ARB_vertex_buffer_object"))
		fprintf(stderr, "Required OpenGL extensions missing.");
		cudaThreadExit();
		exit(-1);
	else
#if   defined(WIN32)
		wglSwapIntervalEXT(0);
#elif defined(LINUX)
		glxSwapIntervalSGI(0);
#endif
	glEnable(GL_DEPTH_TEST);
	glClearColor(0.0, 0.0, 0.0, 1.0);
	checkGLErrors("initGL");
// Most of this code came from the Programming Guide
void initVBO(){
	// Create buffer object and register it with CUDA
	glGenBuffers(1, &vboID_h);
	glBindBuffer(GL_ARRAY_BUFFER, vboID_h);
	static unsigned int size = N_CELLS * 3 * sizeof(float);
		// Just some data to start off with to see if the kernel/cudaBuffer has any effect
	float original;
	for (int n=0; n<size; ++n){
		if (n>0 && (n+1)%3==0){
			original[n] = 0.0;
		} else {
			original[n] = (float)(n/100.);
	glBufferData(GL_ARRAY_BUFFER, size, original, GL_DYNAMIC_DRAW);
	//glBindBuffer(GL_ARRAY_BUFFER, vboID_h); // this line is in the programming guide, but it seems like it shouldn't be here, as it un-binds the first binding??
	cudaThreadSynchronize();
	CUDA_SAFE_CALL(	cudaGraphicsGLRegisterBuffer(&vboID_d, vboID_h, cudaGraphicsMapFlagsNone) );	// <-- error here
void display(){
		float* arr_d;
	size_t num_bytes;
	float debug[16];
	// Map buffer object
	CUDA_SAFE_CALL(cudaGraphicsMapResources(1, &vboID_d, streamID));
	CUDA_SAFE_CALL(cudaGraphicsResourceGetMappedPointer((void**)&arr_d, &num_bytes, vboID_d));
		runCudaGL(vboID_d);   // wrapper to call the kernel (which resides in a .cu file along with the kernels it calls)
	// Unmap buffer object
	cudaGraphicsUnmapResources(1, &vboID_d, 0);
		// Render from buffer object
		glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT);
		glVertexPointer(3, GL_FLOAT, 0, 0);
		glEnableClientState(GL_VERTEX_ARRAY);
		glDrawArrays(GL_POINTS, 0, 16); // 3 -> N_CELLS
		glDisableClientState(GL_VERTEX_ARRAY);
  • The nbody example didn’t use ‘cudaGraphicsGLRegisterBuffer’… presumeably because it was written before this function?
  • Can anyone seen any obvious bugs/mistakes?
OpenGL registers a series of callback functions and then enters GlutMainLoop. It will automatically process display() 2 times, but then it returns to GlutMainLoop() and waits for inputs. I dont see anything in your program prompting GlutMainLoop() to continuously reprocess display(). I’ve been playing around with this for a short time (so I’m not very confident this is the best way), but I would register a timer callback, TimerFunc, that GlutMainLoop would process at a specified time. In the actual timer callback function I’d do my CUDA and display().
The source code is available for GlutMainLoop, but it doesnt seem well suited for highly synchronized, and optimally controlled CUDA programs unless you modify it. It doesnt look like optimizing it will be quick work. The timerfunction should be adequate to prove out your other work.
Main(){
glutTimerFunc(elapsedUSecs, TimerFunction, value) //specify paramaters to repeatedly call back
GlutMainLoop()
 TimerFunction()
       CUDA()
       dislpay()
 Return()
This link says it a bit better. See 3.090 [url=“http://www.opengl.org/resources/faq/technical/glut.htm”]http://www.opengl.org/resources/faq/technical/glut.htm[/url]
Hi UltraRacerX,
Thanks for your reply - good feedback.
  • I like your idea of registering a timer callback, but I want to display continuously (don’t want to miss frames) and so I’m concerned as to whether it’d be refreshing too infrequently for my needs.
  • Also, I have registered an idle callback, but forgot to post the relevant source code here; it’s very simple:
void idle(void)
	glutPostRedisplay();
So display() is continuously refreshing.
  • However, I don’t see how this relates to my problem? My code crashes when I’m initialising the VBO - before it even gets to glutMainLoop()…
void initVBO(){
	float original;
			original[n] = 0.0;
		} else {
So, this line: cudaGraphicsGLRegisterBuffer(&vboID_d, vboID_h, cudaGraphicsMapFlagsNone);
Gives me the error: unspecified launch failure in prior launch.
I fixed my bug - needed to call cudaGLSetGLDevice() before initialising my VBO’s… DOH!
