Camera Bringup - collecting frames only once before the error occurs
Hello Everyone,
I am working on bringing up a new camera by writing a custom camera driver. I know there may be some issues in my implementation, but I have encountered a strange problem: I am only able to “collect” data once, then it crashes and to make any other attempt i have to reboot.
The first attempt:
tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 16384
Any subsequent attempt results in the following error:
[  240.994327] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  240.994349] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  240.995788] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
Is there any way to restart the VI “engine” or the camera “engine”? I’m not exactly sure what I should be looking for. It seems like the system only attempts to collect frames once before the error occurs (maybe something is crashing inside), but I might be missing something.
This issue makes debugging really frustrating because I have to reboot the system after every attempt.
Any suggestions or insights would be greatly appreciated!
DMESG, after the error occurs
[  319.087524] pstate: 20400009 (nzCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[  319.087526] pc : vb2_start_streaming+0xe4/0x160 [videobuf2_common]
[  319.087532] lr : vb2_start_streaming+0x74/0x160 [videobuf2_common]
[  319.087537] sp : ffff800010c43b00
[  319.087538] x29: ffff800010c43b00 x28: ffff000104163600 x27: 0000000040045612
[  319.087540] x26: ffffbcbcd17cb088 x25: 0000000000000000 x24: ffff800010c43cd8
[  319.087543] x23: ffff00008ac2f1f8 x22: ffff800010c43cd8 x21: ffff00008ac2f858
[  319.087545] x20: ffff00008ac2f870 x19: 00000000ffffffea x18: 0000000000000000
[  319.087548] x17: 0000000000000000 x16: ffffbcbce532d580 x15: 0000ffff86fde7a0
[  319.087550] x14: 0000000000000000 x13: 0000000000000000 x12: 0000000000000000
[  319.087552] x11: 0000000000000040 x10: ffffbcbce6505ff8 x9 : ffff434ac2ca8000
[  319.087554] x8 : 000000000000014b x7 : 0000000000000500 x6 : 0000000000000400
[  319.087557] x5 : ffff0007a8b66ea0 x4 : 0000000000000006 x3 : 0000000000000000
[  319.087559] x2 : ffffbcbce4021bf8 x1 : ffff0000ec948f80 x0 : ffff0000ec4a71f0
[  319.087562] Call trace:
[  319.087564]  vb2_start_streaming+0xe4/0x160 [videobuf2_common]
[  319.087569]  vb2_core_streamon+0xa4/0x1b0 [videobuf2_common]
[  319.087574]  vb2_ioctl_streamon+0x6c/0xc0 [videobuf2_v4l2]
[  319.087579]  v4l_streamon+0x44/0x60 [videodev]
[  319.087596]  __video_do_ioctl+0x190/0x400 [videodev]
[  319.087608]  video_usercopy+0x278/0x660 [videodev]
[  319.087620]  video_ioctl2+0x44/0x80 [videodev]
[  319.087632]  v4l2_ioctl+0x6c/0xa0 [videodev]
[  319.087643]  __arm64_sys_ioctl+0xb4/0x100
[  319.087652]  invoke_syscall+0x5c/0x130
[  319.087658]  el0_svc_common.constprop.0+0xf0/0x110
[  319.087661]  do_el0_svc+0x74/0xa0
[  319.087664]  el0_svc+0x28/0x80
[  319.087670]  el0t_64_sync_handler+0xa4/0x130
[  319.087672]  el0t_64_sync+0x1a4/0x1a8
[  319.087675] ---[ end trace 18708124a5a8e581 ]---
At first traces i am getting
 vi-output, mipi-6416    [001] .......   190.973333: tegra_channel_capture_frame: sof:0.0
 vi-output, mipi-6416    [001] .......   190.973335: tegra_channel_capture_frame: eof:218.28587712
     kworker/6:0-45      [006] .......   191.017751: rtcpu_vinotify_event: tstamp:6813357993 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:218016998848 data:0x359d580010000000
     kworker/6:0-45      [006] .......   191.017754: rtcpu_vinotify_event: tstamp:6813358160 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:218017005248 data:0x0000000031000001
     kworker/6:0-45      [006] .......   191.017755: rtcpu_vinotify_event: tstamp:6813358317 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:218017008256 data:0x0000000007020001
     kworker/6:0-45      [006] .......   191.017756: rtcpu_vinotify_event: tstamp:6813358448 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:218017050528 data:0x359d550010000000
     kworker/6:0-45      [006] .......   191.017757: rtcpu_vinotify_event: tstamp:6813358602 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:218017057024 data:0x0000000031000002
     kworker/6:0-45      [006] .......   191.017758: rtcpu_vinotify_error: tstamp:6813429256 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x00 frame:1497 vi_tstamp:218028912160 data:0x0000000000000124
     kworker/6:0-45      [006] .......   191.017759: rtcpu_vinotify_event: tstamp:6813696030 cch:-1 vi:0 tag:FS channel:0x00 frame:1497 vi_tstamp:218028531936 data:0x000005d900000014
     kworker/6:0-45      [006] .......   191.017759: rtcpu_vinotify_event: tstamp:6813696189 cch:-1 vi:0 tag:ATOMP_FS channel:0x00 frame:1497 vi_tstamp:218028531968 data:0x0000000800000000
     kworker/6:0-45      [006] .......   191.017760: rtcpu_vinotify_event: tstamp:6813696324 cch:-1 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:1497 vi_tstamp:218028582432 data:0x0000000000004004
     kworker/6:0-45      [006] .......   191.017761: rtcpu_vinotify_event: tstamp:6813696473 cch:-1 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:1497 vi_tstamp:218028587968 data:0x0000000001020001
     kworker/6:0-45      [006] .......   191.017761: rtcpu_vinotify_event: tstamp:6813696604 cch:-1 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:1497 vi_tstamp:218028641696 data:0x0000000000004001
     kworker/6:0-45      [006] .......   191.017762: rtcpu_vinotify_event: tstamp:6813696753 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x00 frame:1497 vi_tstamp:218028912160 data:0x0000000000000124
     kworker/6:0-45      [006] .......   191.017762: rtcpu_vinotify_event: tstamp:6813696888 cch:-1 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x10 frame:1497 vi_tstamp:218028912160 data:0x0005200001000000
     kworker/6:0-45      [006] .......   191.017763: rtcpu_vinotify_event: tstamp:6813697037 cch:-1 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x10 frame:1497 vi_tstamp:218028912160 data:0x0001200000000000
     kworker/6:0-45      [006] .......   191.017764: rtcpu_vinotify_event: tstamp:6813697171 cch:-1 vi:0 tag:ATOMP_FE channel:0x00 frame:1497 vi_tstamp:218028912160 data:0x0000000800000000
After error occurs there is only:
     kworker/0:3-184     [000] .......   243.543562: rtcpu_string: tstamp:8454996087 id:0x04010000 str:"VM0 activating."
     kworker/0:3-184     [000] .......   243.543567: rtcpu_vinotify_event: tstamp:8455525005 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:270566326656 data:0x359d580010000000
     kworker/0:3-184     [000] .......   243.543568: rtcpu_vinotify_event: tstamp:8455525143 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:270566333056 data:0x0000000031000001
     kworker/0:3-184     [000] .......   243.543569: rtcpu_vinotify_event: tstamp:8455525298 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:270566336032 data:0x0000000007020001
     kworker/0:3-184     [000] .......   243.543569: rtcpu_vinotify_event: tstamp:8455525433 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:270566383168 data:0x359d550010000000
     kworker/0:3-184     [000] .......   243.543570: rtcpu_vinotify_event: tstamp:8455525586 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:270566389696 data:0x0000000031000002
For the camera basic functionality first needs to check the device and driver configuration.
You can reference to below program guide for the detailed information of device tree and driver implementation.
Please refer to Applications Using V4L2 IOCTL Directly by using V4L2 IOCTL to verify basic camera functionality.
Once confirm the configure and still failed below link help to get log and some information and some tips for debug.
What’s the BSP version?
cat /etc/nv_tegra_release
R36 (release), REVISION: 4.0
Jetpack 36.4
Okay, It turned out to be a some crazy bug with my driver and types. And it got to work finally.
But unfortunately i got the error in nvargus-daemon :( I think it is due to RAW8 or RAW14 pixel format.
Can I handle that pixel format inside the nvargus-daemon?
SCF: Error BadParameter: Unknown sensor pixel type (in src/common/Utils.cpp, function translateColorFormat(), line 462)
Current release don’t support RAW8.
Thanks for information, v4l2src works just fine. The post mentioned below helped me.
Thanks for help anyway and have a nice day.
