hey,
with the devkit and GStreamer, will it achieve in practice, encoding of 28 FPS at 3280x1848 ? (theory number of the nano)
and will a camera like that would work for that purpose :
thanks in advance.
hey,
thanks in advance.
Hi vbellet, the encoder supports up to 4Kp30 (3840x2160), so in theory it should keep up too at your resolution of 1848 vertical lines.
From what I can tell with the IMX219 sensors, their 4K resolution is for still images only.
Did someone with a nano and raspberry camera already tried at that resolution ?
3380*1848
I’ve tried before to capture 4K video from the IMX219 Raspberry Pi Camera Module v2 in 4K mode, but it does not seem to work, sorry. The product specs I’ve seen for that camera online imply 4K still images.
I see but one person on the forum did run that :
v4l2-ctl -d /dev/video0 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'RG10'
Name : 10-bit Bayer RGRG/GBGB
Size: Discrete 3280x2464
Interval: Discrete 0.048s (21.000 fps)
Size: Discrete 3280x1848
Interval: Discrete 0.036s (28.000 fps)
Size: Discrete 1920x1080
Interval: Discrete 0.033s (30.000 fps)
Interval: Discrete 0.017s (60.000 fps)
To me that means it should work no?
That command just lists the formats - when I actually tried to run the capture @ 4K on that camera, it didn’t work for me.
Too bad :/
Here’s a new camera using IMX179 sensor that reports 4K @ 15FPS: [url]Service Product Solution - APPRO PHOTOELECTRON INC.
great news. Unfortunately we are looking for a M12 or M8 lens :/ and we need to be have more 25 FPS at minimum resolution of 3280x1848 ( a bit less than 4k)
I think this one can do high FPS if the carrier board has a 4 lane connection: Arducam IMX219 Wide Angle Camera Module for NVIDIA Jetson Nano
We tried this one and it also does not go above 120fps, even tho the spec says otherwise: Arducam IMX219 Low Distortion IR Sensitive (NoIR) M12 Mount Camera Module for NVIDIA Jetson Nano
jetson@jetson:~$ v4l2-ctl --list-formats-ext
Index : 0
Size: Discrete 3264x2464
Size: Discrete 3264x1848
jetson@jetson:~$ dmesg |grep imx
[ 4.891425] imx219 7-0010: tegracam sensor driver:imx219_v2.0.6
[ 4.920820] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[ 4.920852] imx219 7-0010: board setup failed
[ 4.920950] imx219: probe of 7-0010 failed with error -121
[ 4.921443] imx219 8-0010: tegracam sensor driver:imx219_v2.0.6
[ 5.110012] vi 54080000.vi: subdev imx219 8-0010 bound
jetson@jetson:~$
Any idea why? is it the kernel driver that thinks it’s a RPi V2 camera?
Hi razvan.grigore,
Please open a new topic for your issue. Thanks
