We checked the electronics and wiring, found nothing wrong. This problem always occurs when the automatic startup program is started and the camera stream is pulled.
For example, the following one will go wrong, resulting in an error.
gst-launch-1.0 nvarguscamerasrc ! ‘video/x-raw(memory:NVMM), format=(string)NV12,width=(int)1640, height=(int)1232, framerate=(fraction)30/1’ ! nvvidconv ! ‘video/x-raw, format=(string)I420, width=(int)1024, height=(int)600’ ! autovideosink
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:736 Failed to create CaptureSession
Mar 16 07:26:55 localhost systemd[1]: Started Argus daemon.
Mar 16 07:27:14 linux nvargus-daemon[5632]: === NVIDIA Libargus Camera Service (0.98.3)=== Listening for connections…=== ac-gui[7769]: Connection established (7FA33CF1D0)OFPars
Mar 16 07:27:14 linux nvargus-daemon[5632]: NvPclHwGetModuleList: No module data found
Mar 16 07:27:14 linux nvargus-daemon[5632]: OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
Mar 16 07:27:14 linux nvargus-daemon[5632]: ---- imager: No override file found. ----
Mar 16 07:27:14 linux nvargus-daemon[5632]: LSC: LSC surface is not based on full res!
Mar 16 07:27:14 linux nvargus-daemon[5632]: === ac-gui[7769]: CameraProvider initialized (0x7f9c891670)LSC: LSC surface is not based on full res!
Mar 16 07:27:24 linux nvargus-daemon[5632]: SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceEvent.cpp, function wait(), line 59)
Mar 16 07:27:24 linux nvargus-daemon[5632]: Error: Camera HwEvents wait, this may indicate a hardware timeout occured,abort current/incoming cc
