Camera sensor can't preview using gst-launch-1.0 nvarguscamerasrc on jetson
Hi guys
I made a new Desirializer board for Jetson TX2 and want to bring up a camera sensor module(imx390-max9295).I modified the device tree and the dmesg show:“tegra-vi4 15700000.vi: subdev imx390 2-0023 bound”,but when I use gst-launch-1.0 nvarguscamerasrc or other app framework to preview and it show error like this:
app logs.txt (1.3 KB)
Hi,this is my dts file,and I get very confused with the "proxy I2C slave address"and the “physical I2C slave address”.whether it right or not because when i change the sensor physical address from 0x21 to 0x20,the dmesg still shows:“imx390 2-0023: Detected IMX390 sensor”.I doubt the issue is in my dts file but I don’t no where it is. could anyone helps me fix it.thanks very much.
dts.txt (497.5 KB)
Confirm basic capture function by v4l2-ctl and get trace log if failed.
https://elinux.org/Jetson/l4t/Camera_BringUp
