Camera uncorr_err: request timed out after 2500 ms
root@nvidia-desktop:/home/nvidia/ofilm_debug# cat /sys/kernel/debug/tracing/trace
tracer: nop
entries-in-buffer/entries-written: 14/14 #P:6
_-------=> irqs-off
/ _------=> need-resched
| / _-----=> need-resched-lazy
|| / _----=> hardirq/softirq
||| / _—=> preempt-depth
|||| / _–=> preempt-lazy-depth
||||| / _-=> migrate-disable
|||||| / delay
TASK-PID CPU# ||||||| TIMESTAMP FUNCTION
    v4l2-ctl-2004    [002] .......  4051.229568: tegra_channel_open: vi-output, ofilm_tof 2-003b
    v4l2-ctl-2004    [002] .......  4051.232137: tegra_channel_set_power: ofilm_tof 2-003b : 0x1
    v4l2-ctl-2004    [002] .......  4051.232146: camera_common_s_power: status : 0x1
    v4l2-ctl-2004    [002] .......  4051.232157: tegra_channel_set_power: 13e00000.host1x:nvcsi@15a00000- : 0x1
    v4l2-ctl-2004    [002] .......  4051.232160: csi_s_power: enable : 0x1
    v4l2-ctl-2004    [002] .......  4051.232712: tegra_channel_capture_setup: vnc_id 0 W 1280 H 480 fmt 5
vi-output, ofil-2005 [000] … 4051.242257: vi_task_submit: class_id:48 ch:0 syncpt_id:26 syncpt_thresh:0 pid:2005 tid:2005
vi-output, ofil-2005 [000] … 4051.242270: vi_task_submit: class_id:48 ch:0 syncpt_id:26 syncpt_thresh:0 pid:2005 tid:2005
vi-output, ofil-2005 [000] … 4051.242271: vi_task_submit: class_id:48 ch:0 syncpt_id:26 syncpt_thresh:0 pid:2005 tid:2005
vi-output, ofil-2005 [000] … 4051.242272: vi_task_submit: class_id:48 ch:0 syncpt_id:26 syncpt_thresh:0 pid:2005 tid:2005
v4l2-ctl-2004 [000] … 4051.242308: tegra_channel_set_stream: enable : 0x1
v4l2-ctl-2004 [000] … 4051.243609: tegra_channel_set_stream: 13e00000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-2004 [000] … 4051.243611: csi_s_stream: enable : 0x1
v4l2-ctl-2004 [002] … 4051.244010: tegra_channel_set_stream: ofilm_tof 2-003b : 0x1
Heading
[tegra234-p3767-camera-p3768-t1-9296-rgb-tof.dts.txt|attachment]
Max9296 + MAX9295D , Serdes configuration is verify on other platform.
max9296_max9295d.c.txt (10.0 KB)
max9296_max9295d.h.txt (5.5 KB)
The trace log shows didn’t receive any validate data from the sensor.
Maybe have scope to probe the signal to confirm.
ofilm_rgb.c.txt (11.4 KB)
ofilm_tof.c.txt (11.1 KB)
ofilm_rgb_mode_tbls.h.txt (2.0 KB)
tegra234-p3767-camera-p3768-t1-9296-rgb-tof.dts.txt (7.2 KB)
this camera is combine iTof 1280x480 raw8 & 1600x1296 RGB888 , Can you help me check this dts ? The Serdes Max9296 is connect to the csi0
As no valid data is detected by the Jetson. I recommend you to verify if the streaming is enabled from the sensor or if the serializer is detecting any data. For the serializer you can check the datasheet there’s are registers which tells if pixel-clock is detected from the sensor at specific video pipe.
Also, you can review the schematics to see if the selected port is not the right one defined at your device-tree. You could try changing the port at the device-tree.
Enrique Ramirez
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com
Website: www.ridgerun.com
How Can I debug Mipi Csi interrupt? This Serdes Can produce Mipi Signal now.
It’s customized carrier board?
If not the CSI-0 don’t support 4 lanes and the port-index should be 1 for CAM0.
tegra234-p3767-camera-p3768-f306_ofilm.dts.txt (75.9 KB)
If I loaded this dtbo , I captured video0 that was happed this error.
:[ 2062.325829] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[ 2062.358971] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[ 2062.392119] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[ 2062.425258] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[ 2062.458408] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[ 2062.491739] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[ 2062.524680] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 131072
This is media-ctl:
root@nvidia-desktop:/home/nvidia# media-ctl -p -d /dev/media0
Media controller API version 5.15.148
Media device information
driver tegra-camrtc-ca
model NVIDIA Tegra Video Input Device
serial
bus info
hw revision 0x3
driver version 5.15.148
Device topology
  • entity 1: 13e00000.host1x:nvcsi@15a00000- (2 pads, 2 links)
    type V4L2 subdev subtype Unknown flags 0
    device node name /dev/v4l-subdev0
    pad0: Sink
    ← “fzcama 2-003a”:0 [ENABLED]
    pad1: Source
    → “vi-output, fzcama 2-003a”:0 [ENABLED]
  • entity 4: 13e00000.host1x:nvcsi@15a00000- (2 pads, 2 links)
    device node name /dev/v4l-subdev1
    pad0: Sink
    ← “fzcama 2-003b”:0 [ENABLED]
    pad1: Source
    → “vi-output, fzcama 2-003b”:0 [ENABLED]
  • entity 7: 13e00000.host1x:nvcsi@15a00000- (2 pads, 2 links)
    device node name /dev/v4l-subdev2
    pad0: Sink
    ← “fzcama 2-003c”:0 [ENABLED]
    pad1: Source
    → “vi-output, fzcama 2-003c”:0 [ENABLED]
  • entity 10: 13e00000.host1x:nvcsi@15a00000- (2 pads, 2 links)
    device node name /dev/v4l-subdev3
    pad0: Sink
    ← “fzcama 2-003d”:0 [ENABLED]
    pad1: Source
    → “vi-output, fzcama 2-003d”:0 [ENABLED]
  • entity 13: 13e00000.host1x:nvcsi@15a00000- (2 pads, 2 links)
    device node name /dev/v4l-subdev4
    pad0: Sink
    ← “fzcamb 2-002a”:0 [ENABLED]
    pad1: Source
    → “vi-output, fzcamb 2-002a”:0 [ENABLED]
  • entity 16: 13e00000.host1x:nvcsi@15a00000- (2 pads, 2 links)
    device node name /dev/v4l-subdev5
    pad0: Sink
    ← “fzcamb 2-002b”:0 [ENABLED]
    pad1: Source
    → “vi-output, fzcamb 2-002b”:0 [ENABLED]
  • entity 19: fzcama 2-003a (1 pad, 1 link)
    type V4L2 subdev subtype Sensor flags 0
    device node name /dev/v4l-subdev6
    pad0: Source
    [fmt:UYVY8_1X16/3840x2160 field:none colorspace:srgb]
    → “13e00000.host1x:nvcsi@15a00000-”:0 [ENABLED]
  • entity 21: vi-output, fzcama 2-003a (1 pad, 1 link)
    type Node subtype V4L flags 0
    device node name /dev/video0
    pad0: Sink
    ← “13e00000.host1x:nvcsi@15a00000-”:1 [ENABLED]
  • entity 43: fzcama 2-003b (1 pad, 1 link)
    device node name /dev/v4l-subdev7
    pad0: Source
  • entity 45: vi-output, fzcama 2-003b (1 pad, 1 link)
    device node name /dev/video1
    pad0: Sink
  • entity 55: fzcama 2-003c (1 pad, 1 link)
    device node name /dev/v4l-subdev8
    pad0: Source
  • entity 57: vi-output, fzcama 2-003c (1 pad, 1 link)
    device node name /dev/video2
    pad0: Sink
  • entity 67: fzcama 2-003d (1 pad, 1 link)
    device node name /dev/v4l-subdev9
    pad0: Source
  • entity 69: vi-output, fzcama 2-003d (1 pad, 1 link)
    device node name /dev/video3
    pad0: Sink
  • entity 79: fzcamb 2-002a (1 pad, 1 link)
    device node name /dev/v4l-subdev10
    pad0: Source
  • entity 81: vi-output, fzcamb 2-002a (1 pad, 1 link)
    device node name /dev/video4
    pad0: Sink
  • entity 91: fzcamb 2-002b (1 pad, 1 link)
    device node name /dev/v4l-subdev11
    pad0: Source
  • entity 93: vi-output, fzcamb 2-002b (1 pad, 1 link)
    device node name /dev/video5
    pad0: Sink
But I Changed the dts, It will time out , for example :
csi_pixel_bit_depth = “24”;
mode_type = “rgb”;
pixel_phase = “rgb888”;
active_w = “1600”;
I could not understand this datatype that not match witch something , it would occured timeout.
Otherwise, nvidia Jetson nano orin can Support RGB888 24 Bit?
Yes, you can reference to tc358840 for the RGB888 format support.
Can you tell me the reason when format changed , timeout occurd?
In you answer, It means jetson nano orin can not suport rgb888 24 bit?
trace.log (582.9 KB)
I mean Jetson able support RGB888 and the tc358840 is the refernece driver that been veified.
oot@nvidia-desktop:/mnt/test/ofilm_debug/debug_max96724/test_config# cat /sys/kernel/debug/tracing/trace
tracer: nop
entries-in-buffer/entries-written: 660265/1685499 #P:6
_-------=> irqs-off
|||||| / delay
    v4l2-ctl-10277   [001] .......   248.184243: tegra_channel_open: vi-output, ofilm_tof 2-003b
    v4l2-ctl-10277   [001] .......   248.188748: tegra_channel_set_power: ofilm_tof 2-003b : 0x1
    v4l2-ctl-10277   [001] .......   248.188757: camera_common_s_power: status : 0x1
    v4l2-ctl-10277   [001] .......   248.188782: tegra_channel_set_power: 13e00000.host1x:nvcsi@15a00000- : 0x1
    v4l2-ctl-10277   [001] .......   248.188790: csi_s_power: enable : 0x1
    v4l2-ctl-10277   [001] .......   248.189351: tegra_channel_capture_setup: vnc_id 0 W 1280 H 480 fmt c
vi-output, ofil-10278 [001] … 248.198176: vi_task_submit: class_id:48 ch:0 syncpt_id:26 syncpt_thresh:6040 pid:10278 tid:10278
vi-output, ofil-10278 [001] … 248.198192: vi_task_submit: class_id:48 ch:0 syncpt_id:26 syncpt_thresh:6040 pid:10278 tid:10278
CPU 2 buffer started
    v4l2-ctl-10277   [002] .......   248.198199: tegra_channel_set_stream: enable : 0x1
vi-output, ofil-10278 [001] … 248.198201: vi_task_submit: class_id:48 ch:0 syncpt_id:26 syncpt_thresh:6040 pid:10278 tid:10278
v4l2-ctl-10277 [002] … 248.199263: tegra_channel_set_stream: 13e00000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-10277 [002] … 248.199266: csi_s_stream: enable : 0x1
v4l2-ctl-10277 [002] … 248.200498: tegra_channel_set_stream: ofilm_tof 2-003b : 0x1
v4l2-ctl-10277 [002] … 250.465650: tegra_channel_close: vi-output, ofilm_tof 2-003b
vi-output, ofil-10279 [001] … 250.707107: tegra_channel_capture_setup: vnc_id 0 W 1280 H 480 fmt c
v4l2-ctl-10277 [002] … 250.707299: tegra_channel_set_stream: enable : 0x0
v4l2-ctl-10277 [002] … 250.707304: tegra_channel_set_stream: ofilm_tof 2-003b : 0x0
v4l2-ctl-10277 [001] … 250.718099: tegra_channel_set_stream: 13e00000.host1x:nvcsi@15a00000- : 0x0
v4l2-ctl-10277 [001] … 250.718104: csi_s_stream: enable : 0x0
v4l2-ctl-10277 [001] … 250.740987: tegra_channel_set_power: ofilm_tof 2-003b : 0x0
v4l2-ctl-10277 [001] … 250.741040: camera_common_s_power: status : 0x0
v4l2-ctl-10277 [001] … 250.741074: tegra_channel_set_power: 13e00000.host1x:nvcsi@15a00000- : 0x0
v4l2-ctl-10277 [001] … 250.741081: csi_s_power: enable : 0x0
CPU 3 buffer started
    v4l2-ctl-10576   [003] .......   252.296653: tegra_channel_open: vi-output, ofilm_rgb 2-003a
    v4l2-ctl-10576   [003] .......   252.305787: tegra_channel_set_power: ofilm_rgb 2-003a : 0x1
    v4l2-ctl-10576   [003] .......   252.305798: camera_common_s_power: status : 0x1
    v4l2-ctl-10576   [003] .......   252.305815: tegra_channel_set_power: 13e00000.host1x:nvcsi@15a00000- : 0x1
    v4l2-ctl-10576   [003] .......   252.305823: csi_s_power: enable : 0x1
    v4l2-ctl-10576   [002] .......   252.306396: tegra_channel_capture_setup: vnc_id 0 W 1600 H 1296 fmt c
vi-output, ofil-10577 [001] … 252.330865: vi_task_submit: class_id:48 ch:0 syncpt_id:26 syncpt_thresh:6040 pid:10577 tid:10577
vi-output, ofil-10577 [001] … 252.330884: vi_task_submit: class_id:48 ch:0 syncpt_id:26 syncpt_thresh:6040 pid:10577 tid:10577
vi-output, ofil-10577 [001] … 252.330893: vi_task_submit: class_id:48 ch:0 syncpt_id:26 syncpt_thresh:6040 pid:10577 tid:10577
v4l2-ctl-10576 [002] … 252.332154: tegra_channel_set_stream: ofilm_rgb 2-003a : 0x1
v4l2-ctl-10576 [003] … 254.597407: tegra_channel_close: vi-output, ofilm_rgb 2-003a
vi-output, ofil-10578 [002] … 254.850164: tegra_channel_capture_setup: vnc_id 0 W 1600 H 1296 fmt c
v4l2-ctl-10576 [003] … 254.850353: tegra_channel_set_stream: enable : 0x0
v4l2-ctl-10576 [003] … 254.850360: tegra_channel_set_stream: ofilm_rgb 2-003a : 0x0
v4l2-ctl-10576 [003] … 254.862070: tegra_channel_set_stream: 13e00000.host1x:nvcsi@15a00000- : 0x0
v4l2-ctl-10576 [003] … 254.862073: csi_s_stream: enable : 0x0
v4l2-ctl-10576 [002] … 254.882976: tegra_channel_set_power: ofilm_rgb 2-003a : 0x0
v4l2-ctl-10576 [002] … 254.883020: camera_common_s_power: status : 0x0
v4l2-ctl-10576 [002] … 254.883038: tegra_channel_set_power: 13e00000.host1x:nvcsi@15a00000- : 0x0
v4l2-ctl-10576 [002] … 254.883045: csi_s_power: enable : 0x0
v4l2-ctl-11194 [001] … 260.863938: tegra_channel_open: vi-output, ofilm_tof 2-003b
v4l2-ctl-11194 [003] … 260.868887: tegra_channel_set_power: ofilm_tof 2-003b : 0x1
v4l2-ctl-11194 [003] … 260.868897: camera_common_s_power: status : 0x1
v4l2-ctl-11194 [003] … 260.868929: tegra_channel_set_power: 13e00000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-11194 [003] … 260.868939: csi_s_power: enable : 0x1
v4l2-ctl-11194 [003] … 260.869509: tegra_channel_capture_setup: vnc_id 0 W 1280 H 480 fmt c
vi-output, ofil-11196 [002] … 260.879083: vi_task_submit: class_id:48 ch:0 syncpt_id:26 syncpt_thresh:6040 pid:11196 tid:11196
vi-output, ofil-11196 [002] … 260.879100: vi_task_submit: class_id:48 ch:0 syncpt_id:26 syncpt_thresh:6040 pid:11196 tid:11196
vi-output, ofil-11196 [002] … 260.879110: vi_task_submit: class_id:48 ch:0 syncpt_id:26 syncpt_thresh:6040 pid:11196 tid:11196
v4l2-ctl-11194 [003] … 260.879112: tegra_channel_set_stream: enable : 0x1
v4l2-ctl-11194 [003] … 260.879742: tegra_channel_set_stream: 13e00000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-11194 [003] … 260.879746: csi_s_stream: enable : 0x1
v4l2-ctl-11194 [001] … 260.880487: tegra_channel_set_stream: ofilm_tof 2-003b : 0x1
v4l2-ctl-11194 [001] … 263.141659: tegra_channel_close: vi-output, ofilm_tof 2-003b
vi-output, ofil-11197 [001] … 263.400154: tegra_channel_capture_setup: vnc_id 0 W 1280 H 480 fmt c
v4l2-ctl-11194 [003] … 263.400345: tegra_channel_set_stream: enable : 0x0
v4l2-ctl-11194 [003] … 263.400350: tegra_channel_set_stream: ofilm_tof 2-003b : 0x0
v4l2-ctl-11194 [003] … 263.410099: tegra_channel_set_stream: 13e00000.host1x:nvcsi@15a00000- : 0x0
v4l2-ctl-11194 [003] … 263.410104: csi_s_stream: enable : 0x0
v4l2-ctl-11194 [001] … 263.433036: tegra_channel_set_power: ofilm_tof 2-003b : 0x0
v4l2-ctl-11194 [001] … 263.433046: camera_common_s_power: status : 0x0
v4l2-ctl-11194 [001] … 263.433069: tegra_channel_set_power: 13e00000.host1x:nvcsi@15a00000- : 0x0
v4l2-ctl-11194 [001] … 263.433075: csi_s_power: enable : 0x0
v4l2-ctl-13496 [002] … 292.962237: tegra_channel_capture_setup: vnc_id 0 W 1280 H 480 fmt 5
vi-output, ofil-13497 [003] … 292.971102: vi_task_submit: class_id:48 ch:0 syncpt_id:26 syncpt_thresh:6040 pid:13497 tid:13497
vi-output, ofil-13497 [003] … 292.971117: vi_task_submit: class_id:48 ch:0 syncpt_id:26 syncpt_thresh:6040 pid:13497 tid:13497
v4l2-ctl-13496 [002] … 292.971119: tegra_channel_set_stream: enable : 0x1
vi-output, ofil-13497 [003] … 292.971124: vi_task_submit: class_id:48 ch:0 syncpt_id:26 syncpt_thresh:6040 pid:13497 tid:13497
v4l2-ctl-13496 [002] … 292.972306: tegra_channel_set_stream: 13e00000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-13496 [002] … 292.972309: csi_s_stream: enable : 0x1
v4l2-ctl-13496 [002] … 292.973841: tegra_channel_set_stream: ofilm_tof 2-003b : 0x1
v4l2-ctl-13496 [002] … 295.237291: tegra_channel_close: vi-output, ofilm_tof 2-003b
vi-output, ofil-13498 [002] … 295.479251: tegra_channel_capture_setup: vnc_id 0 W 1280 H 480 fmt 5
v4l2-ctl-13496 [002] … 295.512005: tegra_channel_set_power: ofilm_tof 2-003b : 0x0
v4l2-ctl-13496 [002] … 295.512054: camera_common_s_power: status : 0x0
v4l2-ctl-13496 [002] … 295.512080: tegra_channel_set_power: 13e00000.host1x:nvcsi@15a00000- : 0x0
v4l2-ctl-13496 [002] … 295.512087: csi_s_power: enable : 0x0
v4l2-ctl-14086 [001] … 301.198862: tegra_channel_open: vi-output, ofilm_tof 2-003b
v4l2-ctl-14086 [001] … 301.201428: tegra_channel_set_power: ofilm_tof 2-003b : 0x1
v4l2-ctl-14086 [001] … 301.201435: camera_common_s_power: status : 0x1
v4l2-ctl-14086 [001] … 301.201462: tegra_channel_set_power: 13e00000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-14086 [001] … 301.201469: csi_s_power: enable : 0x1
v4l2-ctl-14086 [001] … 301.201799: tegra_channel_capture_setup: vnc_id 0 W 1280 H 480 fmt 5
vi-output, ofil-14087 [002] … 301.202295: vi_task_submit: class_id:48 ch:0 syncpt_id:26 syncpt_thresh:6040 pid:14087 tid:14087
vi-output, ofil-14087 [002] … 301.202314: vi_task_submit: class_id:48 ch:0 syncpt_id:26 syncpt_thresh:6040 pid:14087 tid:14087
vi-output, ofil-14087 [002] … 301.202324: vi_task_submit: class_id:48 ch:0 syncpt_id:26 syncpt_thresh:6040 pid:14087 tid:14087
v4l2-ctl-14086 [001] … 301.204334: tegra_channel_set_stream: ofilm_tof 2-003b : 0x1
vi-output, ofil-14088 [001] … 303.711279: tegra_channel_capture_setup: vnc_id 0 W 1280 H 480 fmt 5
v4l2-ctl-14086 [001] … 303.722100: tegra_channel_set_stream: 13e00000.host1x:nvcsi@15a00000- : 0x0
v4l2-ctl-14086 [001] … 303.722104: csi_s_stream: enable : 0x0
v4l2-ctl-14086 [001] … 303.723964: tegra_channel_set_power: ofilm_tof 2-003b : 0x0
v4l2-ctl-14086 [001] … 303.724061: camera_common_s_power: status : 0x0
v4l2-ctl-14086 [001] … 303.724078: tegra_channel_set_power: 13e00000.host1x:nvcsi@15a00000- : 0x0
v4l2-ctl-14086 [001] … 303.724082: csi_s_power: enable : 0x0
v4l2-ctl-14329 [001] … 304.538118: tegra_channel_set_stream: enable : 0x1
v4l2-ctl-14329 [001] … 304.539330: tegra_channel_set_stream: 13e00000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-14329 [001] … 304.539333: csi_s_stream: enable : 0x1
v4l2-ctl-14329 [001] … 304.540099: tegra_channel_set_stream: ofilm_tof 2-003b : 0x1
v4l2-ctl-14329 [001] … 306.801234: tegra_channel_close: vi-output, ofilm_tof 2-003b
vi-output, ofil-14331 [001] … 307.043319: tegra_channel_capture_setup: vnc_id 0 W 1280 H 480 fmt 5
v4l2-ctl-14329 [002] … 307.043647: tegra_channel_set_stream: enable : 0x0
v4l2-ctl-14329 [002] … 307.043653: tegra_channel_set_stream: ofilm_tof 2-003b : 0x0
v4l2-ctl-14329 [002] … 307.058082: tegra_channel_set_stream: 13e00000.host1x:nvcsi@15a00000- : 0x0
v4l2-ctl-14329 [002] … 307.058086: csi_s_stream: enable : 0x0
v4l2-ctl-14329 [002] … 307.060065: tegra_channel_set_power: ofilm_tof 2-003b : 0x0
v4l2-ctl-14329 [002] … 307.060129: camera_common_s_power: status : 0x0
v4l2-ctl-14329 [002] … 307.060154: tegra_channel_set_power: 13e00000.host1x:nvcsi@15a00000- : 0x0
v4l2-ctl-14329 [002] … 307.060160: csi_s_power: enable : 0x0
vi-output, ofil-15252 [001] … 316.178208: vi_task_submit: class_id:48 ch:0 syncpt_id:26 syncpt_thresh:6040 pid:15252 tid:15252
vi-output, ofil-15252 [001] … 316.178221: vi_task_submit: class_id:48 ch:0 syncpt_id:26 syncpt_thresh:6040 pid:15252 tid:15252
vi-output, ofil-15252 [001] … 316.178226: vi_task_submit: class_id:48 ch:0 syncpt_id:26 syncpt_thresh:6040 pid:15252 tid:15252
v4l2-ctl-15251 [003] … 316.178234: tegra_channel_set_stream: enable : 0x1
v4l2-ctl-15251 [003] … 316.178829: tegra_channel_set_stream: 13e00000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-15251 [003] … 316.178831: csi_s_stream: enable : 0x1
v4l2-ctl-15251 [001] … 316.179305: tegra_channel_set_stream: ofilm_tof 2-003b : 0x1
CPU 0 buffer started
 kworker/0:1-47      [000] .......   316.318487: rtcpu_nvcsi_intr: tstamp:10615340049 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001044
 kworker/0:1-47      [000] .......   316.318487: rtcpu_nvcsi_intr: tstamp:10615342384 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318488: rtcpu_nvcsi_intr: tstamp:10615342384 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318488: rtcpu_nvcsi_intr: tstamp:10615343192 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318488: rtcpu_nvcsi_intr: tstamp:10615343192 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318489: rtcpu_nvcsi_intr: tstamp:10615343192 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318489: rtcpu_nvcsi_intr: tstamp:10615343192 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318489: rtcpu_nvcsi_intr: tstamp:10615344516 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318490: rtcpu_nvcsi_intr: tstamp:10615344516 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318490: rtcpu_nvcsi_intr: tstamp:10615344516 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001044
 kworker/0:1-47      [000] .......   316.318490: rtcpu_nvcsi_intr: tstamp:10615344516 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318491: rtcpu_nvcsi_intr: tstamp:10615345835 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000044
 kworker/0:1-47      [000] .......   316.318491: rtcpu_nvcsi_intr: tstamp:10615345835 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318491: rtcpu_nvcsi_intr: tstamp:10615345835 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318491: rtcpu_nvcsi_intr: tstamp:10615347616 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000044
 kworker/0:1-47      [000] .......   316.318492: rtcpu_nvcsi_intr: tstamp:10615347616 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001044
 kworker/0:1-47      [000] .......   316.318492: rtcpu_nvcsi_intr: tstamp:10615348428 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318492: rtcpu_nvcsi_intr: tstamp:10615348428 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318493: rtcpu_nvcsi_intr: tstamp:10615348428 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318493: rtcpu_nvcsi_intr: tstamp:10615348428 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318494: rtcpu_nvcsi_intr: tstamp:10615351430 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318494: rtcpu_nvcsi_intr: tstamp:10615351430 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318494: rtcpu_nvcsi_intr: tstamp:10615353708 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318495: rtcpu_nvcsi_intr: tstamp:10615353708 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318495: rtcpu_nvcsi_intr: tstamp:10615355347 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318495: rtcpu_nvcsi_intr: tstamp:10615355347 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318495: rtcpu_nvcsi_intr: tstamp:10615356156 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318496: rtcpu_nvcsi_intr: tstamp:10615356156 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318496: rtcpu_nvcsi_intr: tstamp:10615356968 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318496: rtcpu_nvcsi_intr: tstamp:10615356968 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318497: rtcpu_nvcsi_intr: tstamp:10615359080 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318497: rtcpu_nvcsi_intr: tstamp:10615359080 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318497: rtcpu_nvcsi_intr: tstamp:10615359923 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318498: rtcpu_nvcsi_intr: tstamp:10615359923 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318498: rtcpu_nvcsi_intr: tstamp:10615360800 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318498: rtcpu_nvcsi_intr: tstamp:10615360800 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000040
 kworker/0:1-47      [000] .......   316.318499: rtcpu_nvcsi_intr: tstamp:10615360800 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318499: rtcpu_nvcsi_intr: tstamp:10615360800 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318499: rtcpu_nvcsi_intr: tstamp:10615362126 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318500: rtcpu_nvcsi_intr: tstamp:10615362126 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318500: rtcpu_nvcsi_intr: tstamp:10615362126 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318500: rtcpu_nvcsi_intr: tstamp:10615363192 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318501: rtcpu_nvcsi_intr: tstamp:10615363192 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318501: rtcpu_nvcsi_intr: tstamp:10615363192 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000040
 kworker/0:1-47      [000] .......   316.318501: rtcpu_nvcsi_intr: tstamp:10615364324 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000040
 kworker/0:1-47      [000] .......   316.318502: rtcpu_nvcsi_intr: tstamp:10615365736 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318502: rtcpu_nvcsi_intr: tstamp:10615365736 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318502: rtcpu_nvcsi_intr: tstamp:10615365736 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318503: rtcpu_nvcsi_intr: tstamp:10615365736 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318503: rtcpu_nvcsi_intr: tstamp:10615367056 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318503: rtcpu_nvcsi_intr: tstamp:10615367056 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318504: rtcpu_nvcsi_intr: tstamp:10615367856 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318504: rtcpu_nvcsi_intr: tstamp:10615367856 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318504: rtcpu_nvcsi_intr: tstamp:10615367856 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318505: rtcpu_nvcsi_intr: tstamp:10615367856 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318505: rtcpu_nvcsi_intr: tstamp:10615370185 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318505: rtcpu_nvcsi_intr: tstamp:10615370185 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318505: rtcpu_nvcsi_intr: tstamp:10615372585 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000044
 kworker/0:1-47      [000] .......   316.318506: rtcpu_nvcsi_intr: tstamp:10615372585 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318506: rtcpu_nvcsi_intr: tstamp:10615372585 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001044
 kworker/0:1-47      [000] .......   316.318506: rtcpu_nvcsi_intr: tstamp:10615372585 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318507: rtcpu_nvcsi_intr: tstamp:10615373914 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318507: rtcpu_nvcsi_intr: tstamp:10615373914 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318507: rtcpu_nvcsi_intr: tstamp:10615374827 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318508: rtcpu_nvcsi_intr: tstamp:10615374827 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318508: rtcpu_nvcsi_intr: tstamp:10615375937 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318508: rtcpu_nvcsi_intr: tstamp:10615375937 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318509: rtcpu_nvcsi_intr: tstamp:10615376977 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318509: rtcpu_nvcsi_intr: tstamp:10615376977 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318509: rtcpu_nvcsi_intr: tstamp:10615376977 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318510: rtcpu_nvcsi_intr: tstamp:10615376977 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318510: rtcpu_nvcsi_intr: tstamp:10615379285 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318510: rtcpu_nvcsi_intr: tstamp:10615379285 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318510: rtcpu_nvcsi_intr: tstamp:10615379285 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318511: rtcpu_nvcsi_intr: tstamp:10615379285 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318511: rtcpu_nvcsi_intr: tstamp:10615381619 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318511: rtcpu_nvcsi_intr: tstamp:10615381619 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318512: rtcpu_nvcsi_intr: tstamp:10615382633 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318512: rtcpu_nvcsi_intr: tstamp:10615382633 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318512: rtcpu_nvcsi_intr: tstamp:10615382633 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318513: rtcpu_nvcsi_intr: tstamp:10615382633 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318513: rtcpu_nvcsi_intr: tstamp:10615383957 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000000
 kworker/0:1-47      [000] .......   316.318513: rtcpu_nvcsi_intr: tstamp:10615383957 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001000
 kworker/0:1-47      [000] .......   316.318514: rtcpu_nvcsi_intr: tstamp:10615384845 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318514: rtcpu_nvcsi_intr: tstamp:10615384845 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318514: rtcpu_nvcsi_intr: tstamp:10615384845 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318515: rtcpu_nvcsi_intr: tstamp:10615384845 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318515: rtcpu_nvcsi_intr: tstamp:10615386173 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318515: rtcpu_nvcsi_intr: tstamp:10615386173 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318516: rtcpu_nvcsi_intr: tstamp:10615386173 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318516: rtcpu_nvcsi_intr: tstamp:10615386173 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318516: rtcpu_nvcsi_intr: tstamp:10615387489 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318517: rtcpu_nvcsi_intr: tstamp:10615388831 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318518: rtcpu_nvcsi_intr: tstamp:10615388831 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318518: rtcpu_nvcsi_intr: tstamp:10615389956 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318518: rtcpu_nvcsi_intr: tstamp:10615389956 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318519: rtcpu_nvcsi_intr: tstamp:10615392327 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318519: rtcpu_nvcsi_intr: tstamp:10615392327 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318519: rtcpu_nvcsi_intr: tstamp:10615393568 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x14000004
 kworker/0:1-47      [000] .......   316.318520: rtcpu_nvcsi_intr: tstamp:10615393568 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318520: rtcpu_nvcsi_intr: tstamp:10615393568 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001404
 kworker/0:1-47      [000] .......   316.318520: rtcpu_nvcsi_intr: tstamp:10615393568 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318521: rtcpu_nvcsi_intr: tstamp:10615396010 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318521: rtcpu_nvcsi_intr: tstamp:10615396010 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x06000044
 kworker/0:1-47      [000] .......   316.318521: rtcpu_nvcsi_intr: tstamp:10615396010 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318522: rtcpu_nvcsi_intr: tstamp:10615396010 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000644
 kworker/0:1-47      [000] .......   316.318522: rtcpu_nvcsi_intr: tstamp:10615397327 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000000
 kworker/0:1-47      [000] .......   316.318522: rtcpu_nvcsi_intr: tstamp:10615397327 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318523: rtcpu_nvcsi_intr: tstamp:10615397327 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001000
 kworker/0:1-47      [000] .......   316.318523: rtcpu_nvcsi_intr: tstamp:10615397327 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318523: rtcpu_nvcsi_intr: tstamp:10615398650 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318524: rtcpu_nvcsi_intr: tstamp:10615398650 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318524: rtcpu_nvcsi_intr: tstamp:10615400832 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318524: rtcpu_nvcsi_intr: tstamp:10615400832 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318525: rtcpu_nvcsi_intr: tstamp:10615403143 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318525: rtcpu_nvcsi_intr: tstamp:10615403143 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000040
 kworker/0:1-47      [000] .......   316.318525: rtcpu_nvcsi_intr: tstamp:10615403143 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318526: rtcpu_nvcsi_intr: tstamp:10615403143 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000040
 kworker/0:1-47      [000] .......   316.318526: rtcpu_nvcsi_intr: tstamp:10615404722 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318526: rtcpu_nvcsi_intr: tstamp:10615404722 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318527: rtcpu_nvcsi_intr: tstamp:10615406400 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318527: rtcpu_nvcsi_intr: tstamp:10615406400 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318527: rtcpu_nvcsi_intr: tstamp:10615408101 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318528: rtcpu_nvcsi_intr: tstamp:10615408101 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318528: rtcpu_nvcsi_intr: tstamp:10615410592 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318528: rtcpu_nvcsi_intr: tstamp:10615410592 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318529: rtcpu_nvcsi_intr: tstamp:10615414958 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318529: rtcpu_nvcsi_intr: tstamp:10615414958 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318529: rtcpu_nvcsi_intr: tstamp:10615417476 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318529: rtcpu_nvcsi_intr: tstamp:10615417476 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318530: rtcpu_nvcsi_intr: tstamp:10615417476 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318530: rtcpu_nvcsi_intr: tstamp:10615417476 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318530: rtcpu_nvcsi_intr: tstamp:10615418887 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318531: rtcpu_nvcsi_intr: tstamp:10615418887 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318531: rtcpu_nvcsi_intr: tstamp:10615418887 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318532: rtcpu_nvcsi_intr: tstamp:10615418887 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318532: rtcpu_nvcsi_intr: tstamp:10615420325 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318532: rtcpu_nvcsi_intr: tstamp:10615420325 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318533: rtcpu_nvcsi_intr: tstamp:10615421855 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318533: rtcpu_nvcsi_intr: tstamp:10615421855 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318533: rtcpu_nvcsi_intr: tstamp:10615421855 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318533: rtcpu_nvcsi_intr: tstamp:10615421855 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318534: rtcpu_nvcsi_intr: tstamp:10615423451 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318534: rtcpu_nvcsi_intr: tstamp:10615423451 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318534: rtcpu_nvcsi_intr: tstamp:10615423451 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318535: rtcpu_nvcsi_intr: tstamp:10615423451 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318535: rtcpu_nvcsi_intr: tstamp:10615425100 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318535: rtcpu_nvcsi_intr: tstamp:10615425100 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318536: rtcpu_nvcsi_intr: tstamp:10615425100 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318536: rtcpu_nvcsi_intr: tstamp:10615425100 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318536: rtcpu_nvcsi_intr: tstamp:10615426779 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318537: rtcpu_nvcsi_intr: tstamp:10615426779 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318537: rtcpu_nvcsi_intr: tstamp:10615429110 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318537: rtcpu_nvcsi_intr: tstamp:10615429110 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318538: rtcpu_nvcsi_intr: tstamp:10615429110 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318538: rtcpu_nvcsi_intr: tstamp:10615429110 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318538: rtcpu_nvcsi_intr: tstamp:10615431842 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318539: rtcpu_nvcsi_intr: tstamp:10615431842 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318539: rtcpu_nvcsi_intr: tstamp:10615431842 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318539: rtcpu_nvcsi_intr: tstamp:10615431842 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318540: rtcpu_nvcsi_intr: tstamp:10615434224 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000044
 kworker/0:1-47      [000] .......   316.318540: rtcpu_nvcsi_intr: tstamp:10615434224 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001044
 kworker/0:1-47      [000] .......   316.318540: rtcpu_nvcsi_intr: tstamp:10615436689 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318541: rtcpu_nvcsi_intr: tstamp:10615436689 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318541: rtcpu_nvcsi_intr: tstamp:10615439139 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318541: rtcpu_nvcsi_intr: tstamp:10615439139 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318542: rtcpu_nvcsi_intr: tstamp:10615441711 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318542: rtcpu_nvcsi_intr: tstamp:10615441711 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318542: rtcpu_nvcsi_intr: tstamp:10615441711 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318542: rtcpu_nvcsi_intr: tstamp:10615441711 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318543: rtcpu_nvcsi_intr: tstamp:10615443232 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318543: rtcpu_nvcsi_intr: tstamp:10615443232 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318543: rtcpu_nvcsi_intr: tstamp:10615445478 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318544: rtcpu_nvcsi_intr: tstamp:10615445478 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318544: rtcpu_nvcsi_intr: tstamp:10615445478 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318544: rtcpu_nvcsi_intr: tstamp:10615445478 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318545: rtcpu_nvcsi_intr: tstamp:10615447886 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318545: rtcpu_nvcsi_intr: tstamp:10615447886 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318545: rtcpu_nvcsi_intr: tstamp:10615450356 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318546: rtcpu_nvcsi_intr: tstamp:10615450356 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318546: rtcpu_nvcsi_intr: tstamp:10615450356 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318546: rtcpu_nvcsi_intr: tstamp:10615450356 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318546: rtcpu_nvcsi_intr: tstamp:10615452795 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318547: rtcpu_nvcsi_intr: tstamp:10615452795 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318548: rtcpu_nvcsi_intr: tstamp:10615452795 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318549: rtcpu_nvcsi_intr: tstamp:10615452795 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318549: rtcpu_nvcsi_intr: tstamp:10615455107 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318549: rtcpu_nvcsi_intr: tstamp:10615455107 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318550: rtcpu_nvcsi_intr: tstamp:10615456326 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000000
 kworker/0:1-47      [000] .......   316.318550: rtcpu_nvcsi_intr: tstamp:10615456326 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001000
 kworker/0:1-47      [000] .......   316.318550: rtcpu_nvcsi_intr: tstamp:10615457419 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318551: rtcpu_nvcsi_intr: tstamp:10615457419 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318551: rtcpu_nvcsi_intr: tstamp:10615457419 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318551: rtcpu_nvcsi_intr: tstamp:10615457419 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318551: rtcpu_nvcsi_intr: tstamp:10615458813 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318552: rtcpu_nvcsi_intr: tstamp:10615458813 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318552: rtcpu_nvcsi_intr: tstamp:10615458813 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318552: rtcpu_nvcsi_intr: tstamp:10615458813 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318553: rtcpu_nvcsi_intr: tstamp:10615460144 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318553: rtcpu_nvcsi_intr: tstamp:10615460144 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318553: rtcpu_nvcsi_intr: tstamp:10615460953 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318554: rtcpu_nvcsi_intr: tstamp:10615460953 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318554: rtcpu_nvcsi_intr: tstamp:10615462090 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318554: rtcpu_nvcsi_intr: tstamp:10615462090 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318555: rtcpu_nvcsi_intr: tstamp:10615462090 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318555: rtcpu_nvcsi_intr: tstamp:10615462090 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318555: rtcpu_nvcsi_intr: tstamp:10615463721 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318556: rtcpu_nvcsi_intr: tstamp:10615463721 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318556: rtcpu_nvcsi_intr: tstamp:10615466280 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318556: rtcpu_nvcsi_intr: tstamp:10615466280 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318557: rtcpu_nvcsi_intr: tstamp:10615468546 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318557: rtcpu_nvcsi_intr: tstamp:10615468546 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318557: rtcpu_nvcsi_intr: tstamp:10615470791 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000044
 kworker/0:1-47      [000] .......   316.318558: rtcpu_nvcsi_intr: tstamp:10615470791 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001044
 kworker/0:1-47      [000] .......   316.318558: rtcpu_nvcsi_intr: tstamp:10615472170 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000044
 kworker/0:1-47      [000] .......   316.318558: rtcpu_nvcsi_intr: tstamp:10615472170 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001044
 kworker/0:1-47      [000] .......   316.318559: rtcpu_nvcsi_intr: tstamp:10615476475 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318559: rtcpu_nvcsi_intr: tstamp:10615476475 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318559: rtcpu_nvcsi_intr: tstamp:10615479161 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318560: rtcpu_nvcsi_intr: tstamp:10615479161 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318560: rtcpu_nvcsi_intr: tstamp:10615481868 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318560: rtcpu_nvcsi_intr: tstamp:10615481868 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318561: rtcpu_nvcsi_intr: tstamp:10615484341 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318561: rtcpu_nvcsi_intr: tstamp:10615484341 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318561: rtcpu_nvcsi_intr: tstamp:10615486781 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x14000004
 kworker/0:1-47      [000] .......   316.318562: rtcpu_nvcsi_intr: tstamp:10615486781 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001404
 kworker/0:1-47      [000] .......   316.318562: rtcpu_nvcsi_intr: tstamp:10615489004 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318562: rtcpu_nvcsi_intr: tstamp:10615489004 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x06000044
 kworker/0:1-47      [000] .......   316.318562: rtcpu_nvcsi_intr: tstamp:10615489004 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318563: rtcpu_nvcsi_intr: tstamp:10615489004 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000644
 kworker/0:1-47      [000] .......   316.318563: rtcpu_nvcsi_intr: tstamp:10615491562 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000044
 kworker/0:1-47      [000] .......   316.318563: rtcpu_nvcsi_intr: tstamp:10615491562 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318564: rtcpu_nvcsi_intr: tstamp:10615491562 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001044
 kworker/0:1-47      [000] .......   316.318564: rtcpu_nvcsi_intr: tstamp:10615491562 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318564: rtcpu_nvcsi_intr: tstamp:10615494215 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318565: rtcpu_nvcsi_intr: tstamp:10615494215 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318565: rtcpu_nvcsi_intr: tstamp:10615494215 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318565: rtcpu_nvcsi_intr: tstamp:10615494215 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318566: rtcpu_nvcsi_intr: tstamp:10615496711 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000044
 kworker/0:1-47      [000] .......   316.318566: rtcpu_nvcsi_intr: tstamp:10615496711 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318566: rtcpu_nvcsi_intr: tstamp:10615496711 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001044
 kworker/0:1-47      [000] .......   316.318567: rtcpu_nvcsi_intr: tstamp:10615496711 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318567: rtcpu_nvcsi_intr: tstamp:10615499224 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318567: rtcpu_nvcsi_intr: tstamp:10615499224 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318567: rtcpu_nvcsi_intr: tstamp:10615499224 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318568: rtcpu_nvcsi_intr: tstamp:10615499224 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318568: rtcpu_nvcsi_intr: tstamp:10615501449 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318568: rtcpu_nvcsi_intr: tstamp:10615501449 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318569: rtcpu_nvcsi_intr: tstamp:10615504569 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318569: rtcpu_nvcsi_intr: tstamp:10615504569 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318569: rtcpu_nvcsi_intr: tstamp:10615504569 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318570: rtcpu_nvcsi_intr: tstamp:10615504569 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318570: rtcpu_nvcsi_intr: tstamp:10615507239 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318570: rtcpu_nvcsi_intr: tstamp:10615507239 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318571: rtcpu_nvcsi_intr: tstamp:10615509691 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318571: rtcpu_nvcsi_intr: tstamp:10615509691 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318571: rtcpu_nvcsi_intr: tstamp:10615511448 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318572: rtcpu_nvcsi_intr: tstamp:10615511448 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318572: rtcpu_nvcsi_intr: tstamp:10615513227 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318572: rtcpu_nvcsi_intr: tstamp:10615513227 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318572: rtcpu_nvcsi_intr: tstamp:10615513227 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318573: rtcpu_nvcsi_intr: tstamp:10615513227 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318573: rtcpu_nvcsi_intr: tstamp:10615515675 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318573: rtcpu_nvcsi_intr: tstamp:10615515675 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318574: rtcpu_nvcsi_intr: tstamp:10615518114 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318574: rtcpu_nvcsi_intr: tstamp:10615518114 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318574: rtcpu_nvcsi_intr: tstamp:10615518114 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318575: rtcpu_nvcsi_intr: tstamp:10615518114 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318575: rtcpu_nvcsi_intr: tstamp:10615520600 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318575: rtcpu_nvcsi_intr: tstamp:10615520600 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318576: rtcpu_nvcsi_intr: tstamp:10615522763 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318576: rtcpu_nvcsi_intr: tstamp:10615522763 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318576: rtcpu_nvcsi_intr: tstamp:10615526636 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318577: rtcpu_nvcsi_intr: tstamp:10615526636 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318577: rtcpu_nvcsi_intr: tstamp:10615526636 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318577: rtcpu_nvcsi_intr: tstamp:10615526636 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318578: rtcpu_nvcsi_intr: tstamp:10615529355 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318579: rtcpu_nvcsi_intr: tstamp:10615529355 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318579: rtcpu_nvcsi_intr: tstamp:10615532056 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318579: rtcpu_nvcsi_intr: tstamp:10615532056 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318580: rtcpu_nvcsi_intr: tstamp:10615534456 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000000
 kworker/0:1-47      [000] .......   316.318580: rtcpu_nvcsi_intr: tstamp:10615534456 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001000
 kworker/0:1-47      [000] .......   316.318580: rtcpu_nvcsi_intr: tstamp:10615537012 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318581: rtcpu_nvcsi_intr: tstamp:10615537012 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318581: rtcpu_nvcsi_intr: tstamp:10615539464 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318581: rtcpu_nvcsi_intr: tstamp:10615539464 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318582: rtcpu_nvcsi_intr: tstamp:10615541720 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318582: rtcpu_nvcsi_intr: tstamp:10615541720 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318582: rtcpu_nvcsi_intr: tstamp:10615541720 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318583: rtcpu_nvcsi_intr: tstamp:10615541720 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318583: rtcpu_nvcsi_intr: tstamp:10615546698 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318583: rtcpu_nvcsi_intr: tstamp:10615546698 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318584: rtcpu_nvcsi_intr: tstamp:10615546698 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318584: rtcpu_nvcsi_intr: tstamp:10615546698 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318584: rtcpu_nvcsi_intr: tstamp:10615549311 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318585: rtcpu_nvcsi_intr: tstamp:10615549311 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318585: rtcpu_nvcsi_intr: tstamp:10615549311 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318585: rtcpu_nvcsi_intr: tstamp:10615549311 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318585: rtcpu_nvcsi_intr: tstamp:10615551711 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318586: rtcpu_nvcsi_intr: tstamp:10615551711 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318586: rtcpu_nvcsi_intr: tstamp:10615551711 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318586: rtcpu_nvcsi_intr: tstamp:10615551711 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318587: rtcpu_nvcsi_intr: tstamp:10615554285 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318587: rtcpu_nvcsi_intr: tstamp:10615554285 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318587: rtcpu_nvcsi_intr: tstamp:10615556877 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000044
 kworker/0:1-47      [000] .......   316.318588: rtcpu_nvcsi_intr: tstamp:10615556877 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000040
 kworker/0:1-47      [000] .......   316.318588: rtcpu_nvcsi_intr: tstamp:10615556877 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001044
 kworker/0:1-47      [000] .......   316.318588: rtcpu_nvcsi_intr: tstamp:10615556877 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000040
 kworker/0:1-47      [000] .......   316.318589: rtcpu_nvcsi_intr: tstamp:10615559302 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318589: rtcpu_nvcsi_intr: tstamp:10615559302 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318589: rtcpu_nvcsi_intr: tstamp:10615561724 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318590: rtcpu_nvcsi_intr: tstamp:10615561724 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318590: rtcpu_nvcsi_intr: tstamp:10615561724 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318590: rtcpu_nvcsi_intr: tstamp:10615561724 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318591: rtcpu_nvcsi_intr: tstamp:10615564180 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000044
 kworker/0:1-47      [000] .......   316.318591: rtcpu_nvcsi_intr: tstamp:10615564180 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318591: rtcpu_nvcsi_intr: tstamp:10615564180 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001044
 kworker/0:1-47      [000] .......   316.318592: rtcpu_nvcsi_intr: tstamp:10615564180 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318592: rtcpu_nvcsi_intr: tstamp:10615566737 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318592: rtcpu_nvcsi_intr: tstamp:10615566737 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318593: rtcpu_nvcsi_intr: tstamp:10615566737 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318593: rtcpu_nvcsi_intr: tstamp:10615566737 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318593: rtcpu_nvcsi_intr: tstamp:10615569377 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x16000004
 kworker/0:1-47      [000] .......   316.318593: rtcpu_nvcsi_intr: tstamp:10615569377 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318594: rtcpu_nvcsi_intr: tstamp:10615569377 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001604
 kworker/0:1-47      [000] .......   316.318594: rtcpu_nvcsi_intr: tstamp:10615569377 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318594: rtcpu_nvcsi_intr: tstamp:10615571855 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318595: rtcpu_nvcsi_intr: tstamp:10615571855 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x06000040
 kworker/0:1-47      [000] .......   316.318595: rtcpu_nvcsi_intr: tstamp:10615571855 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318595: rtcpu_nvcsi_intr: tstamp:10615571855 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000640
 kworker/0:1-47      [000] .......   316.318596: rtcpu_nvcsi_intr: tstamp:10615574163 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318596: rtcpu_nvcsi_intr: tstamp:10615574163 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x06000000
 kworker/0:1-47      [000] .......   316.318596: rtcpu_nvcsi_intr: tstamp:10615574163 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318597: rtcpu_nvcsi_intr: tstamp:10615574163 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000600
 kworker/0:1-47      [000] .......   316.318597: rtcpu_nvcsi_intr: tstamp:10615576750 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318597: rtcpu_nvcsi_intr: tstamp:10615576750 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x06000044
 kworker/0:1-47      [000] .......   316.318597: rtcpu_nvcsi_intr: tstamp:10615576750 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318598: rtcpu_nvcsi_intr: tstamp:10615576750 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000644
 kworker/0:1-47      [000] .......   316.318598: rtcpu_nvcsi_intr: tstamp:10615579197 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000000
 kworker/0:1-47      [000] .......   316.318598: rtcpu_nvcsi_intr: tstamp:10615579197 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001000
 kworker/0:1-47      [000] .......   316.318599: rtcpu_nvcsi_intr: tstamp:10615581615 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318599: rtcpu_nvcsi_intr: tstamp:10615581615 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318599: rtcpu_nvcsi_intr: tstamp:10615584307 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318600: rtcpu_nvcsi_intr: tstamp:10615584307 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318600: rtcpu_nvcsi_intr: tstamp:10615586767 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318600: rtcpu_nvcsi_intr: tstamp:10615586767 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318601: rtcpu_nvcsi_intr: tstamp:10615586767 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318601: rtcpu_nvcsi_intr: tstamp:10615586767 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318601: rtcpu_nvcsi_intr: tstamp:10615588957 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318602: rtcpu_nvcsi_intr: tstamp:10615588957 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318602: rtcpu_nvcsi_intr: tstamp:10615591366 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318602: rtcpu_nvcsi_intr: tstamp:10615591366 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318602: rtcpu_nvcsi_intr: tstamp:10615591366 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001404
 kworker/0:1-47      [000] .......   316.318603: rtcpu_nvcsi_intr: tstamp:10615591366 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318603: rtcpu_nvcsi_intr: tstamp:10615592694 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x14000044
 kworker/0:1-47      [000] .......   316.318603: rtcpu_nvcsi_intr: tstamp:10615592694 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318604: rtcpu_nvcsi_intr: tstamp:10615592694 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001444
 kworker/0:1-47      [000] .......   316.318604: rtcpu_nvcsi_intr: tstamp:10615594788 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318604: rtcpu_nvcsi_intr: tstamp:10615594788 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x06000044
 kworker/0:1-47      [000] .......   316.318605: rtcpu_nvcsi_intr: tstamp:10615594788 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318605: rtcpu_nvcsi_intr: tstamp:10615594788 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000644
 kworker/0:1-47      [000] .......   316.318605: rtcpu_nvcsi_intr: tstamp:10615597393 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318606: rtcpu_nvcsi_intr: tstamp:10615597393 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318606: rtcpu_nvcsi_intr: tstamp:10615599617 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318606: rtcpu_nvcsi_intr: tstamp:10615599617 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318607: rtcpu_nvcsi_intr: tstamp:10615599617 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318607: rtcpu_nvcsi_intr: tstamp:10615599617 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318607: rtcpu_nvcsi_intr: tstamp:10615601829 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318609: rtcpu_nvcsi_intr: tstamp:10615601829 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318609: rtcpu_nvcsi_intr: tstamp:10615604512 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318610: rtcpu_nvcsi_intr: tstamp:10615604512 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318610: rtcpu_nvcsi_intr: tstamp:10615606623 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318610: rtcpu_nvcsi_intr: tstamp:10615606623 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318610: rtcpu_nvcsi_intr: tstamp:10615609110 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318611: rtcpu_nvcsi_intr: tstamp:10615609110 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318611: rtcpu_nvcsi_intr: tstamp:10615611680 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318611: rtcpu_nvcsi_intr: tstamp:10615611680 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000040
 kworker/0:1-47      [000] .......   316.318612: rtcpu_nvcsi_intr: tstamp:10615611680 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318612: rtcpu_nvcsi_intr: tstamp:10615611680 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000040
 kworker/0:1-47      [000] .......   316.318612: rtcpu_nvcsi_intr: tstamp:10615613984 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000044
 kworker/0:1-47      [000] .......   316.318613: rtcpu_nvcsi_intr: tstamp:10615613984 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318613: rtcpu_nvcsi_intr: tstamp:10615613984 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001044
 kworker/0:1-47      [000] .......   316.318614: rtcpu_nvcsi_intr: tstamp:10615613984 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318614: rtcpu_nvcsi_intr: tstamp:10615615307 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318614: rtcpu_nvcsi_intr: tstamp:10615615307 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318614: rtcpu_nvcsi_intr: tstamp:10615615307 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318615: rtcpu_nvcsi_intr: tstamp:10615617502 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000044
 kworker/0:1-47      [000] .......   316.318615: rtcpu_nvcsi_intr: tstamp:10615617502 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318615: rtcpu_nvcsi_intr: tstamp:10615617502 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001044
 kworker/0:1-47      [000] .......   316.318616: rtcpu_nvcsi_intr: tstamp:10615617502 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318616: rtcpu_nvcsi_intr: tstamp:10615619731 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000044
 kworker/0:1-47      [000] .......   316.318616: rtcpu_nvcsi_intr: tstamp:10615619731 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318617: rtcpu_nvcsi_intr: tstamp:10615619731 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001044
 kworker/0:1-47      [000] .......   316.318617: rtcpu_nvcsi_intr: tstamp:10615619731 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318618: rtcpu_nvcsi_intr: tstamp:10615622353 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318618: rtcpu_nvcsi_intr: tstamp:10615622353 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318618: rtcpu_nvcsi_intr: tstamp:10615622353 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318619: rtcpu_nvcsi_intr: tstamp:10615622353 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318619: rtcpu_nvcsi_intr: tstamp:10615624023 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318619: rtcpu_nvcsi_intr: tstamp:10615624023 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318619: rtcpu_nvcsi_intr: tstamp:10615626619 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318620: rtcpu_nvcsi_intr: tstamp:10615626619 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318620: rtcpu_nvcsi_intr: tstamp:10615628992 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318620: rtcpu_nvcsi_intr: tstamp:10615628992 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318621: rtcpu_nvcsi_intr: tstamp:10615631368 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318621: rtcpu_nvcsi_intr: tstamp:10615631368 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318621: rtcpu_nvcsi_intr: tstamp:10615631368 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318622: rtcpu_nvcsi_intr: tstamp:10615631368 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318622: rtcpu_nvcsi_intr: tstamp:10615633568 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318622: rtcpu_nvcsi_intr: tstamp:10615633568 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318623: rtcpu_nvcsi_intr: tstamp:10615633568 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318623: rtcpu_nvcsi_intr: tstamp:10615633568 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318623: rtcpu_nvcsi_intr: tstamp:10615636195 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318624: rtcpu_nvcsi_intr: tstamp:10615636195 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318624: rtcpu_nvcsi_intr: tstamp:10615636195 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318624: rtcpu_nvcsi_intr: tstamp:10615636195 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318625: rtcpu_nvcsi_intr: tstamp:10615803243 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318625: rtcpu_nvcsi_intr: tstamp:10615803243 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318626: rtcpu_nvcsi_intr: tstamp:10615803243 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318626: rtcpu_nvcsi_intr: tstamp:10615803243 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318626: rtcpu_nvcsi_intr: tstamp:10615804604 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318627: rtcpu_nvcsi_intr: tstamp:10615804604 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318627: rtcpu_nvcsi_intr: tstamp:10615804604 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318627: rtcpu_nvcsi_intr: tstamp:10615805679 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318627: rtcpu_nvcsi_intr: tstamp:10615805679 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318628: rtcpu_nvcsi_intr: tstamp:10615805679 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318628: rtcpu_nvcsi_intr: tstamp:10615806741 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318628: rtcpu_nvcsi_intr: tstamp:10615806741 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318629: rtcpu_nvcsi_intr: tstamp:10615806741 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318629: rtcpu_nvcsi_intr: tstamp:10615806741 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318629: rtcpu_nvcsi_intr: tstamp:10615808057 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318630: rtcpu_nvcsi_intr: tstamp:10615808057 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318630: rtcpu_nvcsi_intr: tstamp:10615808057 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318630: rtcpu_nvcsi_intr: tstamp:10615808057 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318631: rtcpu_nvcsi_intr: tstamp:10615809367 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318631: rtcpu_nvcsi_intr: tstamp:10615809367 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318631: rtcpu_nvcsi_intr: tstamp:10615810185 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318632: rtcpu_nvcsi_intr: tstamp:10615810185 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318632: rtcpu_nvcsi_intr: tstamp:10615810185 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318632: rtcpu_nvcsi_intr: tstamp:10615810185 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318632: rtcpu_nvcsi_intr: tstamp:10615811505 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000040
 kworker/0:1-47      [000] .......   316.318633: rtcpu_nvcsi_intr: tstamp:10615811505 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001044
 kworker/0:1-47      [000] .......   316.318633: rtcpu_nvcsi_intr: tstamp:10615811505 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318633: rtcpu_nvcsi_intr: tstamp:10615812562 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318634: rtcpu_nvcsi_intr: tstamp:10615812562 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318634: rtcpu_nvcsi_intr: tstamp:10615812562 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318634: rtcpu_nvcsi_intr: tstamp:10615813633 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318635: rtcpu_nvcsi_intr: tstamp:10615813633 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318635: rtcpu_nvcsi_intr: tstamp:10615813633 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318635: rtcpu_nvcsi_intr: tstamp:10615814694 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318636: rtcpu_nvcsi_intr: tstamp:10615814694 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318636: rtcpu_nvcsi_intr: tstamp:10615814694 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318636: rtcpu_nvcsi_intr: tstamp:10615815767 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318637: rtcpu_nvcsi_intr: tstamp:10615815767 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318637: rtcpu_nvcsi_intr: tstamp:10615815767 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318637: rtcpu_nvcsi_intr: tstamp:10615816822 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318637: rtcpu_nvcsi_intr: tstamp:10615816822 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318638: rtcpu_nvcsi_intr: tstamp:10615816822 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318638: rtcpu_nvcsi_intr: tstamp:10615816822 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318638: rtcpu_nvcsi_intr: tstamp:10615818148 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318639: rtcpu_nvcsi_intr: tstamp:10615818148 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318640: rtcpu_nvcsi_intr: tstamp:10615818148 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318640: rtcpu_nvcsi_intr: tstamp:10615818148 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318640: rtcpu_nvcsi_intr: tstamp:10615819464 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318641: rtcpu_nvcsi_intr: tstamp:10615821267 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318641: rtcpu_nvcsi_intr: tstamp:10615821267 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318641: rtcpu_nvcsi_intr: tstamp:10615821267 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318642: rtcpu_nvcsi_intr: tstamp:10615821267 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318642: rtcpu_nvcsi_intr: tstamp:10615823275 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318642: rtcpu_nvcsi_intr: tstamp:10615823275 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318643: rtcpu_nvcsi_intr: tstamp:10615824086 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318643: rtcpu_nvcsi_intr: tstamp:10615824086 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318643: rtcpu_nvcsi_intr: tstamp:10615824086 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001044
 kworker/0:1-47      [000] .......   316.318644: rtcpu_nvcsi_intr: tstamp:10615824086 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318644: rtcpu_nvcsi_intr: tstamp:10615825403 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000044
 kworker/0:1-47      [000] .......   316.318644: rtcpu_nvcsi_intr: tstamp:10615825403 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318644: rtcpu_nvcsi_intr: tstamp:10615826213 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318645: rtcpu_nvcsi_intr: tstamp:10615826213 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318645: rtcpu_nvcsi_intr: tstamp:10615826213 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318645: rtcpu_nvcsi_intr: tstamp:10615826213 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318646: rtcpu_nvcsi_intr: tstamp:10615827528 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318646: rtcpu_nvcsi_intr: tstamp:10615827528 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318646: rtcpu_nvcsi_intr: tstamp:10615827528 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318647: rtcpu_nvcsi_intr: tstamp:10615827528 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318647: rtcpu_nvcsi_intr: tstamp:10615829294 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318647: rtcpu_nvcsi_intr: tstamp:10615829294 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318648: rtcpu_nvcsi_intr: tstamp:10615829294 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318648: rtcpu_nvcsi_intr: tstamp:10615829294 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318648: rtcpu_nvcsi_intr: tstamp:10615830614 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318649: rtcpu_nvcsi_intr: tstamp:10615830614 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318649: rtcpu_nvcsi_intr: tstamp:10615831969 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318649: rtcpu_nvcsi_intr: tstamp:10615831969 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318650: rtcpu_nvcsi_intr: tstamp:10615831969 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318650: rtcpu_nvcsi_intr: tstamp:10615831969 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318650: rtcpu_nvcsi_intr: tstamp:10615833339 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000004
 kworker/0:1-47      [000] .......   316.318651: rtcpu_nvcsi_intr: tstamp:10615833339 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001004
 kworker/0:1-47      [000] .......   316.318651: rtcpu_nvcsi_intr: tstamp:10615835307 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318651: rtcpu_nvcsi_intr: tstamp:10615835307 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318652: rtcpu_nvcsi_intr: tstamp:10615835307 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318652: rtcpu_nvcsi_intr: tstamp:10615835307 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318652: rtcpu_nvcsi_intr: tstamp:10615836626 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318653: rtcpu_nvcsi_intr: tstamp:10615836626 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
 kworker/0:1-47      [000] .......   316.318653: rtcpu_nvcsi_intr: tstamp:10615836626 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000004
 kworker/0:1-47      [000] .......   316.318653: rtcpu_nvcsi_intr: tstamp:10615836626 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
status:0x00000044 on class:CORRECTABLE_ERR type:PHY_INTR means:
  • bit 6 set: err_intr_cil_data_lane_sot_mb_err1 = more than one bit error detected on data lane 1 sync word.
  • bit 2 set: err_intr_cil_data_lane_sot_mb_err0 = more than one bit error detected on data lane 0 sync word.
For your line:
  • phy:1 = PHY 1.
  • cil:1 = CIL B.
So the short decode is:
PHY1 / CIL-B has multi-bit SOT sync-word errors on both data lanes 0 and 1.
Practically, this usually points to a CSI link/signal/timing issue on the sensor/serdes side, not a VI scheduling issue.
Can you help me analyze this rgb trace log?
tracer: nop
entries-in-buffer/entries-written: 805/805 #P:6
_-------=> irqs-off
/ _------=> need-resched
| / _-----=> need-resched-lazy
|| / _----=> hardirq/softirq
||| / _—=> preempt-depth
|||| / _–=> preempt-lazy-depth
||||| / _-=> migrate-disable
|||||| / delay
TASK-PID CPU# ||||||| TIMESTAMP FUNCTION
    v4l2-ctl-51882   [002] .......   743.388445: tegra_channel_open: vi-output, ofilm_rgb 2-003a
    v4l2-ctl-51882   [002] .......   743.396264: tegra_channel_set_power: ofilm_rgb 2-003a : 0x1
vi-output, ofil-51891 [002] … 743.406852: vi_task_submit: class_id:48 ch:0 syncpt_id:26 syncpt_thresh:126492 pid:51891 tid:51891
vi-output, ofil-51891 [002] … 743.406867: vi_task_submit: class_id:48 ch:0 syncpt_id:26 syncpt_thresh:126492 pid:51891 tid:51891
vi-output, ofil-51891 [002] … 743.406873: vi_task_submit: class_id:48 ch:0 syncpt_id:26 syncpt_thresh:126492 pid:51891 tid:51891
v4l2-ctl-51882 [001] … 743.406892: tegra_channel_set_stream: enable : 0x1
v4l2-ctl-51882 [001] … 743.408003: tegra_channel_set_stream: 13e00000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-51882 [001] … 743.408006: csi_s_stream: enable : 0x1
v4l2-ctl-51882 [001] … 743.408424: tegra_channel_set_stream: ofilm_rgb 2-003a : 0x1
kworker/0:1-47 [000] … 743.438106: rtcpu_string: tstamp:23963303454 id:0x04010000 str:“VM0 activating.”
kworker/0:1-47 [000] … 743.438111: rtcpu_nvcsi_intr: tstamp:23963573010 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x0e000000
kworker/0:1-47 [000] … 743.438112: rtcpu_nvcsi_intr: tstamp:23963573010 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x06000000
kworker/0:1-47 [000] … 743.438114: rtcpu_vinotify_event: tstamp:23963796411 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:766831132864 data:0x799e300010000000
kworker/0:1-47 [000] … 743.438115: rtcpu_vinotify_event: tstamp:23963796735 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:766831142528 data:0x0000000031000001
kworker/0:1-47 [000] … 743.438117: rtcpu_nvcsi_intr: tstamp:23964029728 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x06000000
kworker/0:1-47 [000] … 743.438117: rtcpu_nvcsi_intr: tstamp:23964029728 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x0e000000
kworker/0:1-47 [000] … 743.438117: rtcpu_nvcsi_intr: tstamp:23964427786 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x0e000000
