Hi, JerryChang,
Another phenomenon
robot@tegra:~$ more cam_7.txt
[ 745.875237] debug:[223, ar0233_power_on].
[ 745.875242] debug:[238, ar0233_power_on, 0x0].
[ 745.892901] bwmgr API not supported
[ 745.893467] debug:[486, ar0233_set_mode].
[ 745.897071] debug:[494, ar0233_set_mode, mode_prop_idx:3].
[ 745.897073] debug:[139, ar0233_write_table].
[ 745.921407] debug:[502, ar0233_set_mode].
[ 745.921418] debug:[511, ar0233_start_streaming].
[ 745.921419] debug:[139, ar0233_write_table].
[ 745.949401] debug:[520, ar0233_start_streaming].
[ 748.401411] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 748.410568] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 748.420383] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 748.428085] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=3, csi_port=3
[ 748.438735] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 748.446446] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 3 vc- 0
[ 748.457163] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 748.466701] debug:[529, ar0233_stop_streaming].
[ 748.466705] debug:[139, ar0233_write_table].
[ 748.466706] debug:[537, ar0233_stop_streaming, 0x0].
[ 748.467807] bwmgr API not supported
[ 748.468539] debug:[248, ar0233_power_off].
[ 748.472277] debug:[265, ar0233_power_off, 0x0].
[ 751.359187] debug:[223, ar0233_power_on].
[ 751.359193] debug:[238, ar0233_power_on, 0x0].
[ 751.363322] bwmgr API not supported
[ 751.363657] debug:[486, ar0233_set_mode].
[ 751.367393] debug:[494, ar0233_set_mode, mode_prop_idx:3].
[ 751.367395] debug:[139, ar0233_write_table].
[ 751.393412] debug:[502, ar0233_set_mode].
[ 751.393424] debug:[511, ar0233_start_streaming].
[ 751.393425] debug:[139, ar0233_write_table].
[ 751.421396] debug:[520, ar0233_start_streaming].
[ 753.873403] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 753.882547] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 753.892375] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 753.900079] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=3, csi_port=3
[ 753.910731] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 753.918444] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 3 vc- 0
[ 753.929169] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 753.938682] debug:[529, ar0233_stop_streaming].
[ 753.938686] debug:[139, ar0233_write_table].
[ 753.938688] debug:[537, ar0233_stop_streaming, 0x0].
[ 753.940350] bwmgr API not supported
[ 753.941545] debug:[248, ar0233_power_off].
[ 753.945139] debug:[265, ar0233_power_off, 0x0].
[ 756.779489] debug:[223, ar0233_power_on].
[ 756.779494] debug:[238, ar0233_power_on, 0x0].
[ 756.791462] bwmgr API not supported
[ 756.792110] debug:[486, ar0233_set_mode].
[ 756.795893] debug:[494, ar0233_set_mode, mode_prop_idx:3].
[ 756.795895] debug:[139, ar0233_write_table].
[ 756.821408] debug:[502, ar0233_set_mode].
[ 756.821420] debug:[511, ar0233_start_streaming].
[ 756.821421] debug:[139, ar0233_write_table].
[ 756.849401] debug:[520, ar0233_start_streaming].
[ 757.010764] debug:[529, ar0233_stop_streaming].
[ 757.010770] debug:[139, ar0233_write_table].
[ 757.010771] debug:[537, ar0233_stop_streaming, 0x0].
[ 757.011930] bwmgr API not supported
[ 757.013728] debug:[248, ar0233_power_off].
[ 757.017325] debug:[265, ar0233_power_off, 0x0].
[ 757.163564] debug:[223, ar0233_power_on].
[ 757.163570] debug:[238, ar0233_power_on, 0x0].
[ 757.165261] bwmgr API not supported
[ 757.166035] debug:[486, ar0233_set_mode].
[ 757.169647] debug:[494, ar0233_set_mode, mode_prop_idx:3].
[ 757.169648] debug:[139, ar0233_write_table].
[ 757.197404] debug:[502, ar0233_set_mode].
[ 757.197417] debug:[511, ar0233_start_streaming].
[ 757.197419] debug:[139, ar0233_write_table].
[ 757.225422] debug:[520, ar0233_start_streaming].
[ 757.370763] debug:[529, ar0233_stop_streaming].
[ 757.370767] debug:[139, ar0233_write_table].
[ 757.370769] debug:[537, ar0233_stop_streaming, 0x0].
[ 757.371934] bwmgr API not supported
[ 757.373565] debug:[248, ar0233_power_off].
[ 757.377166] debug:[265, ar0233_power_off, 0x0].
[ 764.879427] debug:[223, ar0233_power_on].
[ 764.879432] debug:[238, ar0233_power_on, 0x0].
[ 764.896560] bwmgr API not supported
[ 764.897116] debug:[486, ar0233_set_mode].
[ 764.900902] debug:[494, ar0233_set_mode, mode_prop_idx:3].
[ 764.900904] debug:[139, ar0233_write_table].
[ 764.925388] debug:[502, ar0233_set_mode].
[ 764.925400] debug:[511, ar0233_start_streaming].
[ 764.925402] debug:[139, ar0233_write_table].
[ 764.953391] debug:[520, ar0233_start_streaming].
[ 765.130013] debug:[529, ar0233_stop_streaming].
[ 765.130018] debug:[139, ar0233_write_table].
[ 765.130020] debug:[537, ar0233_stop_streaming, 0x0].
[ 765.131136] bwmgr API not supported
[ 765.132545] debug:[248, ar0233_power_off].
[ 765.136399] debug:[265, ar0233_power_off, 0x0].
[ 765.267311] debug:[223, ar0233_power_on].
[ 765.267316] debug:[238, ar0233_power_on, 0x0].
[ 765.282502] bwmgr API not supported
[ 765.283051] debug:[486, ar0233_set_mode].
[ 765.286901] debug:[494, ar0233_set_mode, mode_prop_idx:3].
[ 765.286902] debug:[139, ar0233_write_table].
[ 765.313389] debug:[502, ar0233_set_mode].
[ 765.313402] debug:[511, ar0233_start_streaming].
[ 765.313403] debug:[139, ar0233_write_table].
[ 765.346131] debug:[520, ar0233_start_streaming].
[ 765.489962] debug:[529, ar0233_stop_streaming].
[ 765.489967] debug:[139, ar0233_write_table].
[ 765.489968] debug:[537, ar0233_stop_streaming, 0x0].
[ 765.491144] bwmgr API not supported
[ 765.492545] debug:[248, ar0233_power_off].
[ 765.496361] debug:[265, ar0233_power_off, 0x0].
[ 773.731502] debug:[223, ar0233_power_on].
[ 773.731508] debug:[238, ar0233_power_on, 0x0].
[ 773.749108] bwmgr API not supported
[ 773.749702] debug:[486, ar0233_set_mode].
[ 773.753306] debug:[494, ar0233_set_mode, mode_prop_idx:3].
[ 773.753308] debug:[139, ar0233_write_table].
[ 773.777375] debug:[502, ar0233_set_mode].
[ 773.777387] debug:[511, ar0233_start_streaming].
[ 773.777389] debug:[139, ar0233_write_table].
[ 773.805369] debug:[520, ar0233_start_streaming].
[ 776.273378] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 776.282538] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 776.292375] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 776.300090] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=3, csi_port=3
[ 776.310745] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 776.318446] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 3 vc- 0
[ 776.329189] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 776.338700] debug:[529, ar0233_stop_streaming].
[ 776.338704] debug:[139, ar0233_write_table].
[ 776.338705] debug:[537, ar0233_stop_streaming, 0x0].
[ 776.339829] bwmgr API not supported
[ 776.340535] debug:[248, ar0233_power_off].
[ 776.344140] debug:[265, ar0233_power_off, 0x0].
[ 779.231418] debug:[223, ar0233_power_on].
[ 779.231423] debug:[238, ar0233_power_on, 0x0].
[ 779.243077] bwmgr API not supported
[ 779.243425] debug:[486, ar0233_set_mode].
[ 779.247162] debug:[494, ar0233_set_mode, mode_prop_idx:3].
[ 779.247165] debug:[139, ar0233_write_table].
[ 779.273416] debug:[502, ar0233_set_mode].
[ 779.273428] debug:[511, ar0233_start_streaming].
[ 779.273429] debug:[139, ar0233_write_table].
[ 779.301376] debug:[520, ar0233_start_streaming].
[ 781.745365] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 781.754500] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 781.764378] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 781.772094] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=3, csi_port=3
[ 781.782745] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 781.790454] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 3 vc- 0
[ 781.801170] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 781.810672] debug:[529, ar0233_stop_streaming].
[ 781.810676] debug:[139, ar0233_write_table].
[ 781.810677] debug:[537, ar0233_stop_streaming, 0x0].
[ 781.811784] bwmgr API not supported
[ 781.812527] debug:[248, ar0233_power_off].
[ 781.816128] debug:[265, ar0233_power_off, 0x0].
[ 844.746526] debug:[223, ar0233_power_on].
[ 844.746531] debug:[238, ar0233_power_on, 0x0].
[ 844.764799] bwmgr API not supported
[ 844.765371] debug:[486, ar0233_set_mode].
[ 844.768972] debug:[494, ar0233_set_mode, mode_prop_idx:3].
[ 844.768973] debug:[139, ar0233_write_table].
[ 844.793303] debug:[502, ar0233_set_mode].
[ 844.793315] debug:[511, ar0233_start_streaming].
[ 844.793316] debug:[139, ar0233_write_table].
[ 844.821302] debug:[520, ar0233_start_streaming].
[ 847.281315] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 847.290454] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 847.300383] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 847.308086] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=3, csi_port=3
[ 847.318739] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 847.326451] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 3 vc- 0
[ 847.337201] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 847.346720] debug:[529, ar0233_stop_streaming].
[ 847.346723] debug:[139, ar0233_write_table].
[ 847.346724] debug:[537, ar0233_stop_streaming, 0x0].
[ 847.347842] bwmgr API not supported
[ 847.348533] debug:[248, ar0233_power_off].
[ 847.352133] debug:[265, ar0233_power_off, 0x0].
robot@tegra:~$ more trace_cam7.txt
# tracer: nop
# entries-in-buffer/entries-written: 95/95 #P:8
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/4:2-247 [004] .... 828.749324: rtcpu_string: tstamp:27364055381 id:0x04010000 str:"VM0 deactivating."
v4l2-ctl-12450 [007] .... 844.733816: tegra_channel_open: vi-output, ar0233 33-001b
v4l2-ctl-12450 [007] .... 844.733954: tegra_channel_close: vi-output, ar0233 33-001b
v4l2-ctl-12452 [007] .... 844.736047: tegra_channel_open: vi-output, ar0233 33-001b
v4l2-ctl-12452 [007] .... 844.736179: tegra_channel_close: vi-output, ar0233 33-001b
v4l2-ctl-12454 [007] .... 844.742945: tegra_channel_open: vi-output, ar0233 33-001b
v4l2-ctl-12454 [007] .... 844.746510: tegra_channel_set_power: ar0233 33-001b : 0x1
v4l2-ctl-12454 [007] .... 844.746519: camera_common_s_power: status : 0x1
v4l2-ctl-12454 [007] .... 844.757483: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-12454 [007] .... 844.757486: csi_s_power: enable : 0x1
v4l2-ctl-12454 [007] .... 844.757997: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1380 fmt 10
v4l2-ctl-12454 [007] .... 844.763808: tegra_channel_set_stream: enable : 0x1
v4l2-ctl-12454 [007] .... 844.765062: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-12454 [007] .... 844.765064: csi_s_stream: enable : 0x1
v4l2-ctl-12454 [007] .... 844.765359: tegra_channel_set_stream: ar0233 33-001b : 0x1
kworker/4:2-247 [004] .... 844.769305: rtcpu_string: tstamp:27865515328 id:0x04010000 str:"VM0 activating."
kworker/4:2-247 [004] .... 844.825301: rtcpu_vinotify_event: tstamp:27865962511 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:89170029
6640 data:0x759e300010000000
kworker/4:2-247 [004] .... 844.825301: rtcpu_vinotify_event: tstamp:27865962651 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:89170030
3072 data:0x0000000031000001
kworker/4:2-247 [004] .... 844.825301: rtcpu_vinotify_event: tstamp:27865962806 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:89170033
8880 data:0x759e2d0010000000
kworker/4:2-247 [004] .... 844.825302: rtcpu_vinotify_event: tstamp:27865962939 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:89170034
5408 data:0x0000000031000002
kworker/4:2-247 [004] .... 844.825303: rtcpu_nvcsi_intr: tstamp:27866806685 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 844.881296: rtcpu_nvcsi_intr: tstamp:27868056658 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 844.937292: rtcpu_nvcsi_intr: tstamp:27869306632 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 844.937293: rtcpu_nvcsi_intr: tstamp:27870556609 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 844.993293: rtcpu_nvcsi_intr: tstamp:27871806583 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 845.049297: rtcpu_nvcsi_intr: tstamp:27873056557 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 845.049297: rtcpu_nvcsi_intr: tstamp:27874306531 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 845.105295: rtcpu_nvcsi_intr: tstamp:27875556504 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 845.161302: rtcpu_nvcsi_intr: tstamp:27876806478 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 845.217296: rtcpu_nvcsi_intr: tstamp:27878056452 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 845.217297: rtcpu_nvcsi_intr: tstamp:27879306426 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 845.273294: rtcpu_nvcsi_intr: tstamp:27880556400 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 845.329294: rtcpu_nvcsi_intr: tstamp:27881806374 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 845.329294: rtcpu_nvcsi_intr: tstamp:27883056348 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 845.385293: rtcpu_nvcsi_intr: tstamp:27884306321 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 845.441292: rtcpu_nvcsi_intr: tstamp:27885554971 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 845.497293: rtcpu_nvcsi_intr: tstamp:27886804945 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 845.497294: rtcpu_nvcsi_intr: tstamp:27888054922 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 845.553292: rtcpu_nvcsi_intr: tstamp:27889304552 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 845.609292: rtcpu_nvcsi_intr: tstamp:27890554525 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 845.609292: rtcpu_nvcsi_intr: tstamp:27891804499 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 845.665293: rtcpu_nvcsi_intr: tstamp:27893054473 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 845.725291: rtcpu_nvcsi_intr: tstamp:27894304447 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 845.725291: rtcpu_nvcsi_intr: tstamp:27895554421 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 845.781295: rtcpu_nvcsi_intr: tstamp:27896804395 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 845.837293: rtcpu_nvcsi_intr: tstamp:27898054368 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 845.893295: rtcpu_nvcsi_intr: tstamp:27899304342 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 845.893295: rtcpu_nvcsi_intr: tstamp:27900554319 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 845.949291: rtcpu_nvcsi_intr: tstamp:27901804320 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 846.005292: rtcpu_nvcsi_intr: tstamp:27903054267 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 846.005292: rtcpu_nvcsi_intr: tstamp:27904304241 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 846.061291: rtcpu_nvcsi_intr: tstamp:27905554214 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 846.117295: rtcpu_nvcsi_intr: tstamp:27906804189 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 846.173295: rtcpu_nvcsi_intr: tstamp:27908052847 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 846.173295: rtcpu_nvcsi_intr: tstamp:27909302821 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 846.229292: rtcpu_nvcsi_intr: tstamp:27910552798 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 846.285293: rtcpu_nvcsi_intr: tstamp:27911802772 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 846.285294: rtcpu_nvcsi_intr: tstamp:27913052392 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 846.345295: rtcpu_nvcsi_intr: tstamp:27914302427 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 846.401295: rtcpu_nvcsi_intr: tstamp:27915552340 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 846.401296: rtcpu_nvcsi_intr: tstamp:27916802314 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 846.457291: rtcpu_nvcsi_intr: tstamp:27918052287 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 846.513291: rtcpu_nvcsi_intr: tstamp:27919302261 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 846.569290: rtcpu_nvcsi_intr: tstamp:27920552235 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 846.569290: rtcpu_nvcsi_intr: tstamp:27921802209 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 846.625289: rtcpu_nvcsi_intr: tstamp:27923052183 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 846.681296: rtcpu_nvcsi_intr: tstamp:27924302157 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 846.681298: rtcpu_nvcsi_intr: tstamp:27925552130 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 846.737291: rtcpu_nvcsi_intr: tstamp:27926802107 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 846.797300: rtcpu_nvcsi_intr: tstamp:27928052080 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
v4l2-ctl-12454 [007] .... 846.823963: tegra_channel_close: vi-output, ar0233 33-001b
kworker/4:2-247 [004] .... 846.853294: rtcpu_nvcsi_intr: tstamp:27929302055 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 846.853295: rtcpu_nvcsi_intr: tstamp:27930550723 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 846.909301: rtcpu_nvcsi_intr: tstamp:27931800697 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 846.965299: rtcpu_nvcsi_intr: tstamp:27933050674 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 846.965300: rtcpu_nvcsi_intr: tstamp:27934300649 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 847.021317: rtcpu_nvcsi_intr: tstamp:27935550255 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 847.081292: rtcpu_nvcsi_intr: tstamp:27936800231 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 847.081293: rtcpu_nvcsi_intr: tstamp:27938050207 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 847.137302: rtcpu_nvcsi_intr: tstamp:27939300180 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 847.193314: rtcpu_nvcsi_intr: tstamp:27940550154 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 847.249296: rtcpu_nvcsi_intr: tstamp:27941800128 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 847.249297: rtcpu_nvcsi_intr: tstamp:27943050102 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 847.309298: rtcpu_nvcsi_intr: tstamp:27944300075 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
vi-output, ar02-12457 [003] .... 847.337103: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1380 fmt 10
v4l2-ctl-12454 [007] .... 847.346704: tegra_channel_set_stream: enable : 0x0
v4l2-ctl-12454 [007] .... 847.346707: tegra_channel_set_stream: ar0233 33-001b : 0x0
v4l2-ctl-12454 [007] .... 847.346726: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x0
v4l2-ctl-12454 [007] .... 847.346728: csi_s_stream: enable : 0x0
v4l2-ctl-12454 [007] .... 847.348354: tegra_channel_set_power: ar0233 33-001b : 0x0
v4l2-ctl-12454 [007] .... 847.348359: camera_common_s_power: status : 0x0
v4l2-ctl-12454 [007] .... 847.352135: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x0
v4l2-ctl-12454 [007] .... 847.352137: csi_s_power: enable : 0x0
kworker/4:2-247 [004] .... 847.365292: rtcpu_nvcsi_intr: tstamp:27945550049 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000080
kworker/4:2-247 [004] .... 852.949283: rtcpu_string: tstamp:28120314713 id:0x04010000 str:"VM0 deactivating."
robot@tegra:~$
dts:
dts.txt (485.1 KB)
