Hi,ALL:
Why is the camera not displaying images? Is there something wrong with vi?
Orin NX
root@tegra:/home/robot# more /etc/nv_tegra_release
# R35 (release), REVISION: 6.0, GCID: 37391689, BOARD: t186ref, EABI: aarch64, DATE: Wed Aug 28 09:12:27 UTC 2024
v4l2-ctl -d /dev/gmsl3 --stream-mmap=3
root@tegra:/home/robot# dmesg
[50207.431103] tegra-capture-ivc bc00000.rtcpu:ivc-bus:ivccontrol@3: tegra_ivc_write: error -512
[50207.439927] tegra194-vi5 13e40000.host1x:vi0@15c00000: IVC control submit failed
[50207.448171] tegra-camrtc-capture-vi tegra-capture-vi: vi capture setup failed
[50207.455769] tegra-capture-ivc bc00000.rtcpu:ivc-bus:ivccontrol@3: tegra_ivc_write: error -512
[50207.464621] tegra194-vi5 13e40000.host1x:vi0@15c00000: IVC control submit failed
[50207.472450] tegra194-vi5 13e40000.host1x:vi0@15c00000: csi_stream_release: failed to disable nvcsi tpg on stream 0 virtual channel 0
root@tegra:/home/robot# v4l2-ctl -d /dev/gmsl2 -D
Driver Info:
Driver name : tegra-video
Card type : vi-output, ar0233 32-001c
Bus info : platform:tegra-capture-vi:2
Driver version : 5.10.216
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Media Driver Info:
Driver name : tegra-camrtc-ca
Model : NVIDIA Tegra Video Input Device
Serial :
Bus info :
Media version : 5.10.216
Hardware revision: 0x00000003 (3)
Interface Info:
Type : V4L Video
Entity Info:
Name : vi-output, ar0233 32-001c
Function : V4L2 I/O
Pad 0x0100005a : 0: Sink
Link 0x0200005f: from remote pad 0x100000c of entity '13e40000.host1x:nvcsi@15a00000-': Data, Enabled
root@tegra:/home/robot# cat /sys/kernel/debug/tracing/trace
# tracer: nop
# entries-in-buffer/entries-written: 18/18 #P:8
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/2:1-428966 [002] .... 51028.872668: rtcpu_dbg_set_loglevel: tstamp:1595326108048 old:2 new:2
kworker/2:1-428966 [002] .... 51034.036667: rtcpu_string: tstamp:1595487977935 id:0x04010000 str:"VM0 deactivating."
v4l2-ctl-626101 [007] .... 51064.458345: tegra_channel_open: vi-output, ar0233 30-001b
v4l2-ctl-626101 [007] .... 51064.466362: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1380 fmt 10
kworker/2:1-428966 [002] .... 51064.512667: rtcpu_string: tstamp:1596439517366 id:0x04010000 str:"VM0 activating."
v4l2-ctl-626101 [007] .... 51065.983187: tegra_channel_close: vi-output, ar0233 30-001b
kworker/2:1-428966 [002] .... 51072.196674: rtcpu_string: tstamp:1596680896303 id:0x04010000 str:"VM0 deactivating."
v4l2-ctl-626673 [007] .... 51218.886671: tegra_channel_open: vi-output, ar0233 32-001c
v4l2-ctl-626673 [007] .... 51218.886811: tegra_channel_close: vi-output, ar0233 32-001c
v4l2-ctl-626675 [007] .... 51218.888979: tegra_channel_open: vi-output, ar0233 32-001c
v4l2-ctl-626675 [007] .... 51218.889116: tegra_channel_close: vi-output, ar0233 32-001c
v4l2-ctl-626677 [007] .... 51218.891791: tegra_channel_open: vi-output, ar0233 32-001c
v4l2-ctl-626677 [007] .... 51218.907439: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1380 fmt 10
kworker/2:1-428966 [002] .... 51218.964669: rtcpu_string: tstamp:1601266655263 id:0x04010000 str:"VM0 activating."
v4l2-ctl-626677 [007] .... 51222.582090: tegra_channel_close: vi-output, ar0233 32-001c
kworker/2:1-428966 [002] .... 51228.832675: rtcpu_string: tstamp:1601574667292 id:0x04010000 str:"VM0 deactivating."
v4l2-ctl-626763 [007] .... 51250.561078: tegra_channel_open: vi-output, ar0233 32-001c
v4l2-ctl-626763 [007] .... 51250.562879: tegra_channel_close: vi-output, ar0233 32-001c
