Hi:
The camera cannot produce pictures. Please help to find out what is the reason.
The steps are as follows:
clinet:
v4l2-ctl -d /dev/video5 --stream-mmap --stream-to-host 192.168.1.111 —> open d457 rgb,image ok
v4l2-ctl -d /dev/video3 --stream-mmap --stream-to-host 192.168.1.111 —> open d457 depth,image ok
v4l2-ctl -d /dev/video2 --stream-mmap --stream-to-host 192.168.1.111 —> open imx390,image ok
v4l2-ctl -d /dev/video5 --stream-mmap --stream-to-host 192.168.1.111 —> open d457 rgb,no image
v4l2-ctl -d /dev/video3 --stream-mmap --stream-to-host 192.168.1.111 —> open d457 rgb,no image
service:
qvidcap -p
Software version:
JP5.1.2
root@tegra:/home/robot# cat /etc/nv_tegra_release
R35 (release), REVISION: 4.1, GCID: 33958178, BOARD: t186ref, EABI: aarch64, DATE: Tue Aug 1 19:57:35 UTC 2023
Block Diagram:
sudo su
echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/emc/mrq_rate_locked
cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/isp/rate
cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
cat /sys/kernel/debug/bpmp/debug/clk/emc/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/emc/ratecd /sys/kernel/debug/dynamic_debug/
echo file csi2_fops.c +p > controlecho 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
cat /sys/kernel/debug/bpmp/debug/clk/emc/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/emc/rateecho 1 > /sys/kernel/debug/tracing/tracing_on
echo 30720 > /sys/kernel/debug/tracing/buffer_size_kb
echo 1 > /sys/kernel/debug/tracing/events/tegra_rtcpu/enable
echo 1 > /sys/kernel/debug/tracing/events/freertos/enable
echo 2 > /sys/kernel/debug/camrtc/log-level
echo 1 > /sys/kernel/debug/tracing/events/camera_common/enable
echo > /sys/kernel/debug/tracing/trace
cat /sys/kernel/debug/tracing/trace
trace log:
trace.log (563.4 KB)
dmesg:
dmesg.txt (137.7 KB)
dts:
temp.txt (430.0 KB)
camera info:
root@tegra:/home/robot# v4l2-ctl -d 5 -D
Driver Info:
Driver name : tegra-video
Card type : vi-output, DS5 mux 31-001a
Bus info : platform:tegra-capture-vi:2
Driver version : 5.10.120
Capabilities : 0x84a00001
Video Capture
Metadata Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Media Driver Info:
Driver name : tegra-camrtc-ca
Model : NVIDIA Tegra Video Input Device
Serial :
Bus info :
Media version : 5.10.120
Hardware revision: 0x00000003 (3)
Interface Info:
Type : V4L Video
Entity Info:
Name : vi-output, DS5 mux 31-001a
Function : V4L2 I/O
Pad 0x01000081 : 0: Sink
Link 0x02000086: from remote pad 0x1000006 of entity '13e40000.host1x:nvcsi@15a00000-': Data, Enabled
root@tegra:/home/robot# v4l2-ctl -d 3 -D
Driver Info:
Video Capture
Metadata Capture
Streaming
Extended Pix Format
Device Capabilities
Video Capture
Streaming
Extended Pix Format
Media Driver Info:
Serial :
Bus info :
Interface Info:
Type : V4L Video
Entity Info:
Function : V4L2 I/O
Pad 0x01000055 : 0: Sink
Link 0x0200005a: from remote pad 0x1000003 of entity '13e40000.host1x:nvcsi@15a00000-': Data, Enabled
root@tegra:/home/robot# v4l2-ctl -d 2 -D
Driver Info:
Card type : vi-output, ar0233 31-001c
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Video Capture
Streaming
Extended Pix Format
Media Driver Info:
Serial :
Bus info :
Interface Info:
Type : V4L Video
Entity Info:
Name : vi-output, ar0233 31-001c
Function : V4L2 I/O
Pad 0x01000035 : 0: Sink
Link 0x0200003a: from remote pad 0x1000009 of entity '13e40000.host1x:nvcsi@15a00000-': Data, Enabled
