No picture is shown after running for a period of time
Hi All,
Why did the image suddenly stop appearing? I couldn’t recover it no matter what I did. After restarting for a while, the image stopped appearing again.Please help me take a look, thank you!
device:
orin NX
The problem is port-index=1,configuration for 2LAN。
version:
root@tegra:/home/robot# v4l2-ctl -d /dev/gmsl1 --set-ctrl sensor_mode=3 --set-fmt-video=width=1920,height=1380,pixelformat=YUYV --stream-mmap=3 --stream-skip=3 --stream-count=1 --stream-poll --stream-to=-|ffmpeg -loglevel quiet -f rawvideo -s 1920x1380 -pix_fmt yuyv422 -i - video0_output.jpeg
select timeout
root@tegra:/home/robot# more /var/log/syslog | grep rce | grep cpu
Aug 30 12:09:18 tegra kernel: [    6.145543] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=73154acbae92fa621c3d5e1b2a6e10f1075059aa
root@tegra:/home/robot# more /etc/nv_tegra_release
# R35 (release), REVISION: 4.1, GCID: 33958178, BOARD: t186ref, EABI: aarch64, D
ATE: Tue Aug  1 19:57:35 UTC 2023
root@tegra:/home/robot# dmesg
[ 1681.814821] debug:[223, ar0233_power_on].
[ 1681.814826] debug:[238, ar0233_power_on, 0x0].
[ 1681.837772] bwmgr API not supported
[ 1681.838211] debug:[486, ar0233_set_mode].
[ 1681.841998] debug:[494, ar0233_set_mode, mode_prop_idx:3].
[ 1681.842000] debug:[139, ar0233_write_table].
[ 1681.868754] debug:[502, ar0233_set_mode].
[ 1681.868766] debug:[511, ar0233_start_streaming].
[ 1681.868767] debug:[139, ar0233_write_table].
[ 1681.894420] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[ 1681.896742] debug:[520, ar0233_start_streaming].
[ 1681.934422] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[ 1681.974401] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[ 1683.989599] debug:[529, ar0233_stop_streaming].
[ 1683.989603] debug:[139, ar0233_write_table].
[ 1683.989604] debug:[537, ar0233_stop_streaming, 0x0].
[ 1684.014742] bwmgr API not supported
[ 1684.016146] debug:[248, ar0233_power_off].
[ 1684.020227] debug:[265, ar0233_power_off, 0x0].
trace_v1.txt (43.3 MB)
dts (1).txt (477.7 KB)
hello wxsrite,
it’s due to you’ve stop_stream called, which may due to you’ve terminate the capture application.
hi, JerryChang,
select timeout
---------------> Because it times out here, and then it ends. Normally, there will be no timeout here.
hello wxsrite,
let’s narrow down the issue,
could you please simplify the capture pipeline, for instance, is it repo’ed with only fetching frames?
root@tegra:/sys/kernel/debug/dynamic_debug# cat /sys/kernel/debug/tracing/trace
# tracer: nop
# entries-in-buffer/entries-written: 0/0   #P:8
#                                _-----=> irqs-off
#                               / _----=> need-resched
#                              | / _---=> hardirq/softirq
#                              || / _--=> preempt-depth
#                              ||| /     delay
#           TASK-PID     CPU#  ||||   TIMESTAMP  FUNCTION
root@tegra:/sys/kernel/debug/dynamic_debug# v4l2-ctl -d /dev/gmsl3 --set-ctrl sensor_mode=3 --set-fmt-video=width=1920,height=1380,pixelformat=YUYV --stream-mmap=3 --stream-skip=3 --stream-count=1
root@tegra:/sys/kernel/debug/dynamic_debug# v4l2-ctl -d /dev/gmsl1 --set-ctrl sensor_mode=3 --set-fmt-video=width=1920,height=1380,pixelformat=YUYV --stream-mmap=3 --stream-skip=3 --stream-count=1
^C
root@tegra:/sys/kernel/debug/dynamic_debug# cd
root@tegra:~# exit
root@tegra:/home/robot# exit
robot@tegra:~$ v4l2-ctl -d /dev/gmsl1 --set-ctrl sensor_mode=3 --set-fmt-video=width=1920,height=1380,pixelformat=YUYV --stream-mmap=3 --stream-skip=3 --stream-count=1
^C
robot@tegra:~$ cat /sys/kernel/debug/tracing/trace > trace.txt
cat: /sys/kernel/debug/tracing/trace: Permission denied
robot@tegra:~$ sudo cat /sys/kernel/debug/tracing/trace > trace.txt
robot@tegra:~$ dmesg > dmesg.txt
dmesg: read kernel buffer failed: Operation not permitted
robot@tegra:~$ sudo dmesg > dmesg.txt
robot@tegra:~$
log:
dmesg (2).txt (3.0 KB)
trace (2).txt (95.4 MB)
hello wxsrite,
it looks you’re able to fetch the camera stream occasionally,
according to below, there’ll be < to indicate each capture buffer, for your use-case, (3 skip-frame plus 1 stream-count) there’re total 4 < below v4l pipeline, which represent correct results.
there’re lots of correctable error according to your tracing logs,
for instance,
kworker/4:0-108649 [004] .... 11237.020190: rtcpu_nvcsi_intr: tstamp:351843641119 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/4:0-108649 [004] .... 11237.020190: rtcpu_nvcsi_intr: tstamp:351843641119 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:1 status:0x00000006
there’re two errors, (1) Single bit ECC error in the packet header, (2) Packet payload CRC check failed.
you may double check your sensor output streaming, especially the stream configuration.
hi, JerryChang,
Do we have documentation that can indicate what the error is? I want to check it myself later.
hello wxsrite,
sorry, there’s no public doc to analysis those tracing logs.
