we upgrade Jetson_Linux from 32.6.1 to 34.1 on xavier platform
It can be displayed normally in version 32.6.1, but it can only be displayed successfully in 34.1 occasionally
camera format
# v4l2-ctl -d /dev/video0 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'AR24' (32-bit BGRA 8-8-8-8)
Interval: Discrete 0.033s (30.000 fps)
Size: Discrete 1920x1080
Interval: Discrete 0.017s (60.000 fps)
Size: Discrete 1920x1920
use test command:
v4l2-ctl -d /dev/video0 \
--set-fmt-video=width=400,height=400,pixelformat=AR24 \
--set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 \
--stream-skip=0 --stream-to=AR24_400_c0.raw
Occasionally CAMERA can display images.
The following error message will appear when it cannot be displayed
[ 241.114845] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 241.115031] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 241.115259] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 241.115434] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 241.115947] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 243.673419] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 243.673690] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
kernel and trace log…
v3410_rgb888_v0_c.log (15.6 KB)
hello channinglan,
would you please moving to the latest production release, i.e. r35.3.1 since Jetson Linux 34.1 is a developer preview release.
BTW,
you may also refer to Camera Driver Porting, since it’s now using kernel-5.10.
Originally it was ported to r35.3.1 but it could not be displayed, so it was downgraded to r34.1, and it only happened to be displayed a few times by chance, I don’t know why this happens.
I don’t know if there is a difference in the parameters of dts, do you need to modify it???
hello channinglan,
do you keeps those failure messages for a quick check?
use v35.3.1 … The same result only occasionally succeeds
v3531_rgb88_err.log (11.2 KB)
v3531_rgb88_ok.log (13.5 KB)
hello channinglan,
there shows PHY interrupts, 0x110 means the data-lane FIFO overflow failures.
kworker/1:2-137 [001] .... 927.461628: rtcpu_nvcsi_intr: tstamp:29792054485 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
also,
it’s reported CHANSEL_SHORT_FRAME
, which due to the senosr signaling mismatch with the active_h settings.
kworker/1:2-137 [001] .... 927.517714: rtcpu_vinotify_event: tstamp:29794617973 cch:-1 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:953419521760 data:0x0000200001000000
however,
it looks your OK results also contain PHY interrupt error and SHORT_FRAME messges,
may I know the status when it works Occasionally.
for example, what’s your test steps, how you determine sensor output correct streams.
I updated the version 32.6.1 and it can display the screen normally
CHANSEL_SHORT_FRAME In this version also appears
v3261_rgb888_v0.log (19.5 KB)
In v35.3.1, the chances of displaying normally are very low! It seems that the first time after each re-flashing is more likely to appear
hello channinglan,
the root cause should be PHY interrupt which related to data-lane FIFO overflow failures.
could you please based-on r35.3.1, and running below commands to boost all the VI/CSI/ISP clocks for testing.
for example,
sudo su
echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/emc/mrq_rate_locked
cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/isp/rate
cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
cat /sys/kernel/debug/bpmp/debug/clk/emc/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/emc/rate
My test script already contains those settings
but the situation remains the same
ffplay -f rawvideo -video_size 400*400 -pixel_format rgba -i AR24_400_c0.raw
please see-also similar topics for digging into data-lane FIFO overflow failures.
such as… Topic 209574, Topic 242054.
can’t read NVCSI_STREAM_0_PH_WC_0
How to fix ???
- in 32.6.1 can display the screen normally …
But I still get this message, so should I fix this before testing the port to r35.3.1?
306.374283: rtcpu_vinotify_event: tstamp:10079137698 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:10078897441 data:0x01000000
You stated earlier that the CHANSEL_SHORT_FRAME error is related to active_h, but I don’t know how to fix it??
active_w = "400";
active_h = "400";
mode_type = "rgb";
pixel_phase = "rgb888";
csi_pixel_bit_depth = "24";
line_length = "2000";
readout_orientation = "0";
inherent_gain = "1";
mclk_multiplier = "1";
pix_clk_hz = "625000000";//1250000000 * 4 / 8
hello channinglan,
you should put the camera stream enabled for reading register.
there’s also an error due to reading blocked by firewall.
so, let me double check what’s the platform you’re working with, for example, it looks you worked with Xavier series, is it AGX Xavier or Xavier NX?
SHORT_FRAME, this error introduced by VI receives less lines than expected, it may due to blanking lines, usually you could try reducing active_h
for some trial-n-error testing.
or, this error may caused by a FS_FAULT would insert a FE packet to terminate the frame. you may examine tracing logs to check whether it’s sending SOF/EOF…EOF in the expected sequence.
hello channinglan,
you should simply revise active_h
in device tree for a quick try, and, it should pop-up different failure once the VI receives more lines.
blanking lines ??? my source is FPGA …should be no blanking lines
set active_h = “380”;
--stream-skip=0 --stream-to=AR24_c0.raw
kworker/0:5-193 [000] .... 39.064824: rtcpu_string: tstamp:2027694703 id:0x04010000 str:"VM0 deactivating."
v4l2-ctl-3107 [000] .... 84.068370: tegra_channel_open: vi-output, gen3 0-001e
v4l2-ctl-3107 [000] .... 84.069434: tegra_channel_close: vi-output, gen3 0-001e
v4l2-ctl-3108 [000] .... 84.075606: tegra_channel_open: vi-output, gen3 0-001e
v4l2-ctl-3108 [000] .... 84.078404: tegra_channel_set_power: gen3 0-001e : 0x1
v4l2-ctl-3108 [000] .... 84.078417: camera_common_s_power: status : 0x1
v4l2-ctl-3108 [000] .... 84.078454: tegra_channel_set_power: 13e10000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-3108 [000] .... 84.078457: csi_s_power: enable : 0x1
v4l2-ctl-3108 [000] .... 84.078927: tegra_channel_capture_setup: vnc_id 0 W 400 H 400 fmt 9
v4l2-ctl-3108 [002] .... 84.089768: tegra_channel_set_stream: enable : 0x1
v4l2-ctl-3108 [002] .... 84.091442: tegra_channel_set_stream: 13e10000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-3108 [002] .... 84.091447: csi_s_stream: enable : 0x1
v4l2-ctl-3108 [002] .... 84.091974: tegra_channel_set_stream: gen3 0-001e : 0x1
kworker/0:7-195 [000] .... 84.139774: rtcpu_string: tstamp:3434828737 id:0x04010000 str:"VM0 activating."
kworker/0:7-195 [000] .... 84.139779: rtcpu_vinotify_event: tstamp:3435270613 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:109919178720 data:0xcd9ce50010000000
kworker/0:7-195 [000] .... 84.139780: rtcpu_vinotify_event: tstamp:3435270753 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:109919184224 data:0x0000000031000001
kworker/0:7-195 [000] .... 84.139780: rtcpu_vinotify_event: tstamp:3435270907 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:109919239008 data:0xcd9ce20010000000
kworker/0:7-195 [000] .... 84.139781: rtcpu_vinotify_event: tstamp:3435271042 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:109919244576 data:0x0000000031000002
you should also revise v4l command-line to reduce the height settings.
--set-fmt-video=width=400,height=380,pixelformat=AR24 \
v4l2-ctl-3199 [000] .... 299.917303: tegra_channel_open: vi-output, gen3 0-001e
v4l2-ctl-3199 [000] .... 299.918261: tegra_channel_close: vi-output, gen3 0-001e
v4l2-ctl-3200 [000] .... 299.926181: tegra_channel_open: vi-output, gen3 0-001e
v4l2-ctl-3200 [000] .... 299.929851: tegra_channel_set_power: gen3 0-001e : 0x1
v4l2-ctl-3200 [000] .... 299.929865: camera_common_s_power: status : 0x1
v4l2-ctl-3200 [000] .... 299.929896: tegra_channel_set_power: 13e10000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-3200 [000] .... 299.929898: csi_s_power: enable : 0x1
v4l2-ctl-3200 [000] .... 299.930511: tegra_channel_capture_setup: vnc_id 0 W 400 H 400 fmt 9
v4l2-ctl-3200 [003] .... 299.939634: tegra_channel_set_stream: enable : 0x1
v4l2-ctl-3200 [003] .... 299.941227: tegra_channel_set_stream: 13e10000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-3200 [003] .... 299.941231: csi_s_stream: enable : 0x1
v4l2-ctl-3200 [003] .... 299.941721: tegra_channel_set_stream: gen3 0-001e : 0x1
kworker/2:2-136 [002] .... 299.943728: rtcpu_string: tstamp:10174398204 id:0x04010000 str:"VM0 activating."
kworker/2:2-136 [002] .... 299.999706: rtcpu_vinotify_event: tstamp:10174834165 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:325585174496 data:0xcd9ce50010000000
kworker/2:2-136 [002] .... 299.999709: rtcpu_vinotify_event: tstamp:10174834305 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:325585179968 data:0x0000000031000001
kworker/2:2-136 [002] .... 299.999710: rtcpu_vinotify_event: tstamp:10174834459 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:325585238880 data:0xcd9ce20010000000
kworker/2:2-136 [002] .... 299.999710: rtcpu_vinotify_event: tstamp:10174834593 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:325585244384 data:0x0000000031000002
vi-output, gen3-3202 [000] .... 302.558401: tegra_channel_capture_setup: vnc_id 0 W 400 H 400 fmt 9
kworker/2:2-136 [002] .... 302.575688: rtcpu_vinotify_event: tstamp:10256619985 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:328204188768 data:0xcd9ce50010000000
kworker/2:2-136 [002] .... 302.575691: rtcpu_vinotify_event: tstamp:10256620125 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:328204194592 data:0x0000000031000001
kworker/2:2-136 [002] .... 302.575692: rtcpu_vinotify_event: tstamp:10256620280 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:328204244832 data:0xcd9ce20010000000
kworker/2:2-136 [002] .... 302.575692: rtcpu_vinotify_event: tstamp:10256620414 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:328204250400 data:0x0000000031000002
[ 397.781487] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 397.786066] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 397.786257] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 397.786487] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 397.786651] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 397.787116] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channe
modify driver to 400x380
v4l2-ctl-3167 [000] .... 273.557381: tegra_channel_open: vi-output, gen3 0-001e
v4l2-ctl-3167 [000] .... 273.558809: tegra_channel_close: vi-output, gen3 0-001e
v4l2-ctl-3168 [000] .... 273.568626: tegra_channel_open: vi-output, gen3 0-001e
v4l2-ctl-3168 [000] .... 273.570864: tegra_channel_set_power: gen3 0-001e : 0x1
v4l2-ctl-3168 [000] .... 273.570875: camera_common_s_power: status : 0x1
v4l2-ctl-3168 [000] .... 273.570915: tegra_channel_set_power: 13e10000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-3168 [000] .... 273.570917: csi_s_power: enable : 0x1
v4l2-ctl-3168 [000] .... 273.571449: tegra_channel_capture_setup: vnc_id 0 W 400 H 380 fmt 9
v4l2-ctl-3168 [001] .... 273.579240: tegra_channel_set_stream: enable : 0x1
v4l2-ctl-3168 [001] .... 273.580866: tegra_channel_set_stream: 13e10000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-3168 [001] .... 273.580870: csi_s_stream: enable : 0x1
v4l2-ctl-3168 [000] .... 273.581838: tegra_channel_set_stream: gen3 0-001e : 0x1
kworker/0:5-1182 [000] .... 273.590772: rtcpu_string: tstamp:9283948715 id:0x04010000 str:"VM0 activating."
kworker/0:5-1182 [000] .... 273.590777: rtcpu_vinotify_event: tstamp:9284386291 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:297090775328 data:0xcd9ce50010000000
kworker/0:5-1182 [000] .... 273.590778: rtcpu_vinotify_event: tstamp:9284386431 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:297090780832 data:0x0000000031000001
kworker/0:5-1182 [000] .... 273.590779: rtcpu_vinotify_event: tstamp:9284386585 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:297090835584 data:0xcd9ce20010000000
kworker/0:5-1182 [000] .... 273.590779: rtcpu_vinotify_event: tstamp:9284386720 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:297090841184 data:0x0000000031000002
hello channinglan,
I don’t see any failures with 400x380, is it capture the frames?
same error!!!
Type: Video Capture
--- active_h ---
380
v4l2-ctl-3094 [003] .... 158.402963: camera_common_s_power: status : 0x1
v4l2-ctl-3094 [003] .... 158.402999: tegra_channel_set_power: 13e10000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-3094 [003] .... 158.403001: csi_s_power: enable : 0x1
v4l2-ctl-3094 [003] .... 158.406022: tegra_channel_capture_setup: vnc_id 0 W 400 H 380 fmt 9
v4l2-ctl-3094 [000] .... 158.414975: tegra_channel_set_stream: enable : 0x1
v4l2-ctl-3094 [000] .... 158.416089: tegra_channel_set_stream: 13e10000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-3094 [000] .... 158.416093: csi_s_stream: enable : 0x1
v4l2-ctl-3094 [000] .... 158.416467: tegra_channel_set_stream: gen3 0-001e : 0x1
kworker/0:5-159 [000] .... 158.455551: rtcpu_string: tstamp:5688327719 id:0x04010000 str:"VM0 activating."
kworker/0:5-159 [000] .... 158.455555: rtcpu_vinotify_event: tstamp:5688762801 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:182030822528 data:0xcd9ce50010000000
kworker/0:5-159 [000] .... 158.455556: rtcpu_vinotify_event: tstamp:5688762946 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:182030828000 data:0x0000000031000001
kworker/0:5-159 [000] .... 158.455557: rtcpu_vinotify_event: tstamp:5688763102 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:182030882688 data:0xcd9ce20010000000
kworker/0:5-159 [000] .... 158.455557: rtcpu_vinotify_event: tstamp:5688763237 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:182030888288 data:0x0000000031000002
vi-output, gen3-3096 [003] .... 160.989838: tegra_channel_capture_setup: vnc_id 0 W 400 H 380 fmt 9
kworker/0:0-5 [000] .... 161.007582: rtcpu_vinotify_event: tstamp:5768953344 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:184605990656 data:0xcd9ce50010000000
kworker/0:0-5 [000] .... 161.007585: rtcpu_vinotify_event: tstamp:5768953483 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:184605996160 data:0x0000000031000001
kworker/0:0-5 [000] .... 161.007586: rtcpu_vinotify_event: tstamp:5768953637 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:184606050528 data:0xcd9ce20010000000
kworker/0:0-5 [000] .... 161.007586: rtcpu_vinotify_event: tstamp:5768953772 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:184606056096 data:0x0000000031000002
root@user-desktop:/home/user# [ 163.551664] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms```
[ 168.667804] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 168.668035] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 168.668978] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 168.669129] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 168.669323] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 168.669463] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 168.669914] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
