When the camera driver was upgraded from r35.4.1 to r35.5.0, a kernel crash occurred when vi could not receive data
After I upgraded the driver running in r35.4.1 without problems to r35.5.0, when I used the v4l2-ctl command to print the frame rate, when I did not connect the sensor, or the sensor did not have a start stream, the following error occurred in dmesg:
[ 1432.454398] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 1432.454698] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1432.454990] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1432.455216] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 1432.455540] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1432.455760] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 1432.456261] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 1435.010744] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 1435.011045] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1435.011344] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1435.011576] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 1435.011894] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1435.012133] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 1435.012696] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 1435.042338] [RCE] ERROR: camera-ip/vi5/vi5.c:3913 [vi5_update_channel_match_data] "match configuration is already in use by by channel 35 cannot set channel match configuration"
[ 1435.042344] [RCE] ERROR: services/capture/capture-scheduler.c:3024 [capture_scheduler_thread] "Error processing event 0x100003"
[1435.042338] [RCE] ERROR: camera-ip/vi5/vi5.c:3913 [vi5_update_channel_match_data] “match configuration is already in use by by channel 35 cannot set channel match configuration”
[1435.042344] [RCE] ERROR: services/capture/capture-scheduler.c:3024 [capture_scheduler_thread] “Error processing event 0x100003” The two logs have not appeared before. I want to know if its presence means there is a bug in my drive.
When I was testing the slave mode of the multiplex camera, I used the v4l2-ctl command to print the frame rate of the multiplex camera. I controlled the output frame rate of the sensor by adjusting the trigger signal frequency provided by the outside, and the tests were all normal. But when I finally broke the trigger signal, I tried to terminate the v4l2-ctl command, and a kernel crash occurred, dmesg as follows:
[ 1808.228198] [RCE] ERROR: camera-ip/vi5/vi5.c:3913 [vi5_update_channel_match_data] "match configuration is already in use by by channel 32 cannot set channel match configuration"
[ 1808.228204] [RCE] ERROR: services/capture/capture-scheduler.c:3024 [capture_scheduler_thread] "Error processing event 0x100003"
[ 1808.436350] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 1808.436379] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 1808.436620] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1808.436632] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1808.436910] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1808.437144] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 1808.437148] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1808.437380] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1808.437621] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 3
[ 1808.439598] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 1808.439628] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 1808.441012] max96705 31-0044: ===>max96705 7 stop streaming 0
[ 1808.444552] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1808.452062] max96705 31-0044: i2c-r, 0x04 = 0xc7
[ 1808.452074] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 1
[ 1808.462494] max96705 31-0044: i2c-w, 0x04 = 0x47
[ 1808.463128] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 1808.610793] ------------[ cut here ]------------
[ 1808.610951] refcount_t: addition on 0; use-after-free.
[ 1808.610979] WARNING: CPU: 0 PID: 3822 at lib/refcount.c:25 refcount_warn_saturate+0x98/0x140
[ 1808.611237] Modules linked in: sg1_ar0144_gmsl1(E) max96712(E) max9296(E) max96705(E) nvidia_modeset(OE) fuse(E) lzo_rle(E) lzo_compress(E) zram(E) ramoops(E) reed_solomon(E) bnep(E) aes_ce_blk(E) crypto_simd(E) rtk_btusb(E) rtl8822ce(E) cryptd(E) input_leds(E) btusb(E) snd_soc_tegra186_asrc(E) aes_ce_cipher(E) ghash_ce(E) btrtl(E) snd_soc_tegra210_ope(E) snd_soc_tegra186_arad(E) snd_soc_tegra186_dspk(E) snd_soc_tegra210_iqc(E) loop(E) snd_soc_tegra210_afc(E) snd_soc_tegra210_mvc(E) sha2_ce(E) snd_soc_tegra210_dmic(E) btbcm(E) snd_soc_tegra210_adsp(E) snd_soc_tegra210_adx(E) snd_soc_tegra210_admaif(E) snd_soc_tegra210_amx(E) sha256_arm64(E) ucsi_ccg(E) snd_soc_tegra210_mixer(E) btintel(E) snd_soc_tegra210_sfc(E) snd_soc_tegra210_i2s(E) snd_soc_tegra_machine_driver(E) snd_soc_tegra_pcm(E) sha1_ce(E) typec_ucsi(E) snd_soc_tegra_utils(E) nct1008(E) snd_soc_spdif_tx(E) i2c_nvvrs11(E) nvadsp(E) typec(E) cfg80211(E) snd_soc_simple_card_utils(E) snd_hda_codec_hdmi(E) snd_soc_tegra210_ahub(E)
[ 1808.611371]  tegra_bpmp_thermal(E) userspace_alert(E) snd_hda_tegra(E) tegra210_adma(E) snd_hda_codec(E) snd_soc_rt5640(E) spi_tegra114(E) snd_hda_core(E) snd_soc_rl6231(E) nvidia(OE) binfmt_misc(E) ina3221(E) pwm_fan(E) nvgpu(E) nvmap(E) ip_tables(E) x_tables(E) [last unloaded: max96712]
[ 1808.611418] CPU: 0 PID: 3822 Comm: v4l2-ctl Tainted: G        W  OE     5.10.192-tegra #1
[ 1808.611421] Hardware name: Jetson AGX Orin Developer Kit (DT)
[ 1808.611426] pstate: 60400009 (nZCv daif +PAN -UAO -TCO BTYPE=--)
[ 1808.611431] pc : refcount_warn_saturate+0x98/0x140
[ 1808.611435] lr : refcount_warn_saturate+0x98/0x140
[ 1808.611437] sp : ffff800021aeba80
[ 1808.611440] x29: ffff800021aeba80 x28: ffff021298165880
[ 1808.611447] x27: 0000000000000000 x26: 0000ffff999b6acc
[ 1808.611453] x25: ffffa463944f2000 x24: ffff021298165e80
[ 1808.611459] x23: ffff021956f0a1f8 x22: ffff02124252c0a0
[ 1808.611465] x21: ffff021283ebac70 x20: ffff021956f0a550
[ 1808.611471] x19: ffff021283ebac40 x18: 0000000000000010
[ 1808.611477] x17: 0000000000000000 x16: ffffa46392af50f0
[ 1808.611482] x15: ffff021298165df0 x14: ffffffffffffffff
[ 1808.611488] x13: ffff8000a1aeb6b7 x12: ffff800021aeb6bf
[ 1808.611494] x11: ffffa46394aae500 x10: 0000000000000ab0
[ 1808.611500] x9 : ffff800021aeba80 x8 : 612d657375203b30
[ 1808.611505] x7 : 206e6f206e6f6974 x6 : c0000000ffffefff
[ 1808.611511] x5 : ffff02196cfc7978 x4 : ffffa46394807ba8
[ 1808.611517] x3 : 0000000000000001 x2 : ffff02196cfc7980
[ 1808.611523] x1 : 0000000000000000 x0 : 0000000000000000
[ 1808.611529] Call trace:
[ 1808.611534]  refcount_warn_saturate+0x98/0x140
[ 1808.611540]  kthread_stop+0x4c/0x290
[ 1808.611547]  vi5_channel_stop_kthreads+0x44/0x60
[ 1808.611551]  vi5_channel_stop_streaming+0xa8/0xb0
[ 1808.611557]  tegra_channel_stop_streaming+0x3c/0x70
[ 1808.611561]  __vb2_queue_cancel+0x40/0x220
[ 1808.611565]  vb2_core_queue_release+0x30/0x60
[ 1808.611569]  _vb2_fop_release+0x88/0xb0
[ 1808.611574]  tegra_channel_close+0x68/0x190
[ 1808.611580]  v4l2_release+0xc0/0x100
[ 1808.611586]  __fput+0x80/0x260
[ 1808.611590]  ____fput+0x24/0x30
[ 1808.611596]  task_work_run+0x88/0xe0
[ 1808.611602]  do_exit+0x35c/0xb00
[ 1808.611607]  do_group_exit+0x4c/0xb0
[ 1808.611612]  get_signal+0x184/0x8c0
[ 1808.611619]  do_notify_resume+0x18c/0x990
[ 1808.611623]  work_pending+0xc/0x738
[ 1808.611627] ---[ end trace 795c82a44854a7cc ]---
[ 1808.611775] ------------[ cut here ]------------
[ 1808.611908] refcount_t: underflow; use-after-free.
[ 1808.611925] WARNING: CPU: 0 PID: 3822 at lib/refcount.c:28 refcount_warn_saturate+0xec/0x140
[ 1808.612153] Modules linked in: sg1_ar0144_gmsl1(E) max96712(E) max9296(E) max96705(E) nvidia_modeset(OE) fuse(E) lzo_rle(E) lzo_compress(E) zram(E) ramoops(E) reed_solomon(E) bnep(E) aes_ce_blk(E) crypto_simd(E) rtk_btusb(E) rtl8822ce(E) cryptd(E) input_leds(E) btusb(E) snd_soc_tegra186_asrc(E) aes_ce_cipher(E) ghash_ce(E) btrtl(E) snd_soc_tegra210_ope(E) snd_soc_tegra186_arad(E) snd_soc_tegra186_dspk(E) snd_soc_tegra210_iqc(E) loop(E) snd_soc_tegra210_afc(E) snd_soc_tegra210_mvc(E) sha2_ce(E) snd_soc_tegra210_dmic(E) btbcm(E) snd_soc_tegra210_adsp(E) snd_soc_tegra210_adx(E) snd_soc_tegra210_admaif(E) snd_soc_tegra210_amx(E) sha256_arm64(E) ucsi_ccg(E) snd_soc_tegra210_mixer(E) btintel(E) snd_soc_tegra210_sfc(E) snd_soc_tegra210_i2s(E) snd_soc_tegra_machine_driver(E) snd_soc_tegra_pcm(E) sha1_ce(E) typec_ucsi(E) snd_soc_tegra_utils(E) nct1008(E) snd_soc_spdif_tx(E) i2c_nvvrs11(E) nvadsp(E) typec(E) cfg80211(E) snd_soc_simple_card_utils(E) snd_hda_codec_hdmi(E) snd_soc_tegra210_ahub(E)
[ 1808.612263]  tegra_bpmp_thermal(E) userspace_alert(E) snd_hda_tegra(E) tegra210_adma(E) snd_hda_codec(E) snd_soc_rt5640(E) spi_tegra114(E) snd_hda_core(E) snd_soc_rl6231(E) nvidia(OE) binfmt_misc(E) ina3221(E) pwm_fan(E) nvgpu(E) nvmap(E) ip_tables(E) x_tables(E) [last unloaded: max96712]
[ 1808.612302] CPU: 0 PID: 3822 Comm: v4l2-ctl Tainted: G        W  OE     5.10.192-tegra #1
[ 1808.612305] Hardware name: Jetson AGX Orin Developer Kit (DT)
[ 1808.612310] pstate: 60400009 (nZCv daif +PAN -UAO -TCO BTYPE=--)
[ 1808.612313] pc : refcount_warn_saturate+0xec/0x140
[ 1808.612317] lr : refcount_warn_saturate+0xec/0x140
[ 1808.612319] sp : ffff800021aeba80
[ 1808.612322] x29: ffff800021aeba80 x28: ffff021298165880
[ 1808.612328] x27: 0000000000000000 x26: 0000ffff999b6acc
[ 1808.612334] x25: ffffa463944f2000 x24: ffff021298165e80
[ 1808.612340] x23: ffff021956f0a1f8 x22: ffff02124252c0a0
[ 1808.612346] x21: ffff021283ebac70 x20: 0000000000000000
[ 1808.612352] x19: ffff021283ebac40 x18: 0000000000000010
[ 1808.612358] x17: 0000000000000000 x16: ffffa46392af50f0
[ 1808.612364] x15: ffff021298165df0 x14: ffffffffffffffff
[ 1808.612370] x13: ffff8000a1aeb6b7 x12: ffff800021aeb6bf
[ 1808.612375] x11: ffffa46394aae500 x10: 0000000000000ab0
[ 1808.612381] x9 : ffff800021aeba80 x8 : 72657466612d6573
[ 1808.612387] x7 : 75203b776f6c6672 x6 : c0000000ffffefff
[ 1808.612393] x5 : ffff02196cfc7978 x4 : ffffa46394807ba8
[ 1808.612398] x3 : 0000000000000001 x2 : ffff02196cfc7980
[ 1808.612404] x1 : 0000000000000000 x0 : 0000000000000000
[ 1808.612410] Call trace:
[ 1808.612414]  refcount_warn_saturate+0xec/0x140
[ 1808.612418]  kthread_stop+0x27c/0x290
[ 1808.612423]  vi5_channel_stop_kthreads+0x44/0x60
[ 1808.612427]  vi5_channel_stop_streaming+0xa8/0xb0
[ 1808.612431]  tegra_channel_stop_streaming+0x3c/0x70
[ 1808.612435]  __vb2_queue_cancel+0x40/0x220
[ 1808.612439]  vb2_core_queue_release+0x30/0x60
[ 1808.612442]  _vb2_fop_release+0x88/0xb0
[ 1808.612448]  tegra_channel_close+0x68/0x190
[ 1808.612452]  v4l2_release+0xc0/0x100
[ 1808.612457]  __fput+0x80/0x260
[ 1808.612461]  ____fput+0x24/0x30
[ 1808.612466]  task_work_run+0x88/0xe0
[ 1808.612471]  do_exit+0x35c/0xb00
[ 1808.612475]  do_group_exit+0x4c/0xb0
[ 1808.612480]  get_signal+0x184/0x8c0
[ 1808.612486]  do_notify_resume+0x18c/0x990
[ 1808.612490]  work_pending+0xc/0x738
[ 1808.612492] ---[ end trace 795c82a44854a7cd ]---
[ 1808.628484] max96712 31-002d: ====>Disable link 3!
[ 1808.628840] max96712 31-002d: i2c-r, 0x0006 = 0x0e
[ 1808.629122] max96712 31-002d: i2c-w, 0x0006 = 0x06
[ 1808.629262] max96705 31-0043: ===>max96705 6 stop streaming 0
[ 1808.629550] max96705 31-0043: i2c-r, 0x04 = 0xc7
[ 1808.629766] max96705 31-0043: i2c-w, 0x04 = 0x47
[ 1808.630299] bwmgr API not supported
[ 1808.630444] ar0144 31-001d: sensor_power_off:
[ 1808.796600] max96712 31-002d: ====>Disable link 2!
[ 1808.796948] max96712 31-002d: i2c-r, 0x0006 = 0x06
[ 1808.797229] max96712 31-002d: i2c-w, 0x0006 = 0x02
[ 1808.798368] bwmgr API not supported
[ 1808.798517] ar0144 31-001c: sensor_power_off:
[ 1809.845371] tegra194-vi5 13e40000.host1x:vi1@14c00000: capture control message timed out
[ 1810.741939] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 1810.742221] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1810.742521] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1810.742752] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 1810.743067] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1810.743293] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 1
[ 1810.744063] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 1810.870054] tegra194-vi5 13e40000.host1x:vi1@14c00000: capture control message timed out
[ 1810.870314] tegra194-vi5 13e40000.host1x:vi1@14c00000: csi_stream_release: failed to disable nvcsi tpg on stream 2 virtual channel 2
[ 1810.998180] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 1810.998445] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1810.998729] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1810.998945] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 1810.999262] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1810.999493] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 1
[ 1810.999963] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 1811.042154] [RCE] ERROR: camera-ip/vi5/vi5.c:3913 [vi5_update_channel_match_data] "match configuration is already in use by by channel 35 cannot set channel match configuration"
[ 1811.042160] [RCE] ERROR: services/capture/capture-scheduler.c:3024 [capture_scheduler_thread] "Error processing event 0x100003"
[ 1811.894736] tegra194-vi5 13e40000.host1x:vi1@14c00000: capture control message timed out
[ 1811.895005] tegra194-vi5 13e40000.host1x:vi1@14c00000: vi_capture_release: release channel IVC failed
[ 1811.895356] ------------[ cut here ]------------
[ 1811.895374] WARNING: CPU: 0 PID: 3822 at /home/fyx/work/nvidia/r35.5.0/Linux_for_Tegra/source/public/kernel_src/kernel/nvidia/drivers/media/platform/tegra/camera/fusa-capture/capture-vi.c:972 vi_capture_release+0x2b4/0x2e0
[ 1811.895951] Modules linked in: sg1_ar0144_gmsl1(E) max96712(E) max9296(E) max96705(E) nvidia_modeset(OE) fuse(E) lzo_rle(E) lzo_compress(E) zram(E) ramoops(E) reed_solomon(E) bnep(E) aes_ce_blk(E) crypto_simd(E) rtk_btusb(E) rtl8822ce(E) cryptd(E) input_leds(E) btusb(E) snd_soc_tegra186_asrc(E) aes_ce_cipher(E) ghash_ce(E) btrtl(E) snd_soc_tegra210_ope(E) snd_soc_tegra186_arad(E) snd_soc_tegra186_dspk(E) snd_soc_tegra210_iqc(E) loop(E) snd_soc_tegra210_afc(E) snd_soc_tegra210_mvc(E) sha2_ce(E) snd_soc_tegra210_dmic(E) btbcm(E) snd_soc_tegra210_adsp(E) snd_soc_tegra210_adx(E) snd_soc_tegra210_admaif(E) snd_soc_tegra210_amx(E) sha256_arm64(E) ucsi_ccg(E) snd_soc_tegra210_mixer(E) btintel(E) snd_soc_tegra210_sfc(E) snd_soc_tegra210_i2s(E) snd_soc_tegra_machine_driver(E) snd_soc_tegra_pcm(E) sha1_ce(E) typec_ucsi(E) snd_soc_tegra_utils(E) nct1008(E) snd_soc_spdif_tx(E) i2c_nvvrs11(E) nvadsp(E) typec(E) cfg80211(E) snd_soc_simple_card_utils(E) snd_hda_codec_hdmi(E) snd_soc_tegra210_ahub(E)
[ 1811.896091]  tegra_bpmp_thermal(E) userspace_alert(E) snd_hda_tegra(E) tegra210_adma(E) snd_hda_codec(E) snd_soc_rt5640(E) spi_tegra114(E) snd_hda_core(E) snd_soc_rl6231(E) nvidia(OE) binfmt_misc(E) ina3221(E) pwm_fan(E) nvgpu(E) nvmap(E) ip_tables(E) x_tables(E) [last unloaded: max96712]
[ 1811.896142] CPU: 0 PID: 3822 Comm: v4l2-ctl Tainted: G        W  OE     5.10.192-tegra #1
[ 1811.896145] Hardware name: Jetson AGX Orin Developer Kit (DT)
[ 1811.896150] pstate: 60400009 (nZCv daif +PAN -UAO -TCO BTYPE=--)
[ 1811.896156] pc : vi_capture_release+0x2b4/0x2e0
[ 1811.896161] lr : vi_capture_release+0x2b4/0x2e0
[ 1811.896164] sp : ffff800021aeba60
[ 1811.896167] x29: ffff800021aeba60 x28: ffff021298165880
[ 1811.896174] x27: 0000000000000000 x26: 0000ffff999b6acc
[ 1811.896180] x25: ffffa463944f2000 x24: ffff021298165880
[ 1811.896186] x23: 00000000ffffff92 x22: ffff0212d69f7f00
[ 1811.896192] x21: 000000000000ffff x20: 0000000000000001
[ 1811.896198] x19: ffff02125992d400 x18: 0000000000000010
[ 1811.896203] x17: 0000000000000000 x16: ffffa46392af50f0
[ 1811.896209] x15: ffff021298165df0 x14: 3169763a78317473
[ 1811.896215] x13: 6f682e3030303034 x12: 61635f6976203a30
[ 1811.896221] x11: 3030303063343140 x10: 72203a657361656c
[ 1811.896227] x9 : 65725f6572757470 x8 : 653331203569762d
[ 1811.896233] x7 : 3439316172676574 x6 : c0000000ffffefff
[ 1811.896238] x5 : ffff02196cfc7978 x4 : ffffa46394807ba8
[ 1811.896244] x3 : 0000000000000001 x2 : 0000000000000000
[ 1811.896250] x1 : 0000000000000000 x0 : 0000000000000000
[ 1811.896257] Call trace:
[ 1811.896263]  vi_capture_release+0x2b4/0x2e0
[ 1811.896269]  vi_capture_shutdown+0x68/0x100
[ 1811.896275]  vi_channel_close_ex+0x30/0x90
[ 1811.896280]  vi_channel_release+0x30/0x40
[ 1811.896288]  __fput+0x80/0x260
[ 1811.896292]  ____fput+0x24/0x30
[ 1811.896300]  task_work_run+0x88/0xe0
[ 1811.896306]  do_exit+0x35c/0xb00
[ 1811.896310]  do_group_exit+0x4c/0xb0
[ 1811.896315]  get_signal+0x184/0x8c0
[ 1811.896322]  do_notify_resume+0x18c/0x990
[ 1811.896326]  work_pending+0xc/0x738
[ 1811.896330] ---[ end trace 795c82a44854a7ce ]---
[ 1811.946022] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000000
[ 1811.946280] Mem abort info:
[ 1811.946368]   ESR = 0x96000004
[ 1811.946464]   EC = 0x25: DABT (current EL), IL = 32 bits
[ 1811.946619]   SET = 0, FnV = 0
[ 1811.946709]   EA = 0, S1PTW = 0
[ 1811.946833] Data abort info:
[ 1811.946924]   ISV = 0, ISS = 0x00000004
[ 1811.947036]   CM = 0, WnR = 0
Is this a kernel crash caused by the driver? How to locate the code that causes the kernel crash? Thank you for your advice.
hello FANYX,
could you please confirm whether the sensor works if you output the stream to CSI channel.
I understand, but the question I want to ask is, why does the kernel crash when the sensor stops output data midway? For example, after I normally lit up the camera, I used the i2ctransfer tool to close the staream of the sensor. At this time, vi could not receive data, and then the kernel crashed. This is not normal in my opinion, and it is also a problem that I have not encountered in the previous version. So I wanted to ask you for advice. thank you.
hello FANYX,
this seems like a bug we’ve encounter recently on r35.5.0 release version.
Do you have a solution for this bug? If so, please provide the solution, thank you.
such failure is caused by tegra_channel_error_recover(), however, we’ve not root cause yet.
I see. If you find out what the problem is, let me know. thank you.
Hello @JerryChang , I am also facing this issue in r36.3.
I just removed the vi5_channel_error_recover op as recommended here, our tests are in progress.
Do you have any updates on the subject?
Thank you
hello amanelli,
here’re patches for r35.5.0 (and also r35.6.0) to fix the failure caused by tegra_channel_error_recover().
for instance,
0001-kernel-camera-remove-csi-event-sync-for-recover.patch (2.3 KB)
0002-vi5_fops-fix-mem-leak.patch (4.3 KB)
just double confirm the release version, did you meant jetson-linux-r3560 or jetson-linux-r363?
could you please check the release tag for confirmation, $ cat /etc/nv_tegra_release
please also gather the complete error logs for reference.
BTW,
please file another new discussion thread if that’s an issue with JP-6.0/r36.3
thanks
