I am facing an issue similar to:
and others. In many cases, the solutions were different for the same error messages, so my case may be different.
My setup:
Jetson AGX Xavier, Jetpack 5.1.1
Custom carrier board (device-tree attached below, can provide some more info if required)
Camera: IMX462 sensor with GMSL serdes
ISP camera overrides (can provide if requested)
Full device-tree:
full.dts.txt (299.6 KB)
Partial device-tree with just camera subsystem:
tegra194-agx-eimx462-8cam.dtsi.txt (24.7 KB)
ecam_cuxvr_mode.dtsi.txt (8.5 KB)
I have updated nvargus-daemon.service to enable all debug messages and boost clocks. See attached bash scripts to confirm this: enable_sys_debug_logs.sh, max_isp_clk.sh
nvargus-daemon.service.txt (575 Bytes)
max_isp_clk.sh.txt (655 Bytes)
enable_sys_debug_logs.sh.txt (380 Bytes)
vi clock rate is: 998400000
isp clock rate is: 1190400000
nvcsi clock rate is: 400000000
emc clock rate is: 2133000000
I have also installed the RTCPU debug firmware: Camera failed with log:VIFALC_TDSTATE on Jetpack5.0.2 - #4 by JerryChang
I have verified that all 4 cameras are detected (when 4 out of 8 are connected):
e.g. in dmesg for video0 (i.e. eimx462 31-0043)…
[ 11.907111] [IMX462]: probing v4l2 sensor.
[ 11.907234] Current SIO ports is A
[ 11.907331] no of mipi lanes 2
[ 11.907425] eimx462 31-0043: Issuing CHIP reset for Deserializer ...
[ 12.232909] eimx462 31-0043: SIOA Port I2C translated successfully
[ 12.233154] eimx462 31-0043: reset_mcu ..... function
[ 12.512739] eimx462 31-0043: Same firmware in MCU & text file - (1_2_CU20_6_1_1_0_b56697c). Skipping FW Update...
[ 12.714217] configuring SIOA serializer successful
[ 12.820559] eimx462 31-0043: configuring Deserializer Successful
[ 12.937246] eimx462 31-0043: Num of Controls - 9
[ 12.990769] eimx462 31-0043: cam_init 1928MCU CMD ID CAM INIT Success !!
[ 13.005848] eimx462 31-0043: tegracam sensor driver:eimx462_v2.0.6
[ 13.005857] e-imx462: cam_probe : Use_sensor_mode_id = 1
[ 13.036934] Frame rate data : 0
[ 13.043570] eimx462 31-0043: cam_fill_string_ctrl[418] Set!
[ 13.065850] Frame rate data : 10485760
[ 13.073716] tegra-camrtc-capture-vi tegra-capture-vi: subdev eimx462 31-0043 bound
[ 13.074998] eimx462 31-0043: ser_status=21
[ 13.103371] loop: module loaded
[ 13.182730] eimx462 31-0043: Detected IMX462 sensor
In v4l2-ctl:
user@tegra-ubuntu:~$ v4l2-ctl --list-devices
NVIDIA Tegra Video Input Device (platform:tegra-camrtc-ca):
/dev/media0
vi-output, eimx462 31-0043 (platform:tegra-capture-vi:2):
/dev/video0
vi-output, eimx462 33-0043 (platform:tegra-capture-vi:4):
/dev/video2
/dev/video3
vi-output, eimx462 32-0043 (platform:tegra-capture-vi:5):
/dev/video1
First, I checked v4l2-compliance with video0. Result:
Codec ioctls (Input 0):
test VIDIOC_(TRY_)ENCODER_CMD: OK (Not Supported)
test VIDIOC_G_ENC_INDEX: OK (Not Supported)
test VIDIOC_(TRY_)DECODER_CMD: OK (Not Supported)
Buffer ioctls (Input 0):
fail: v4l2-test-buffers.cpp(715): q.create_bufs(node, 1, &fmt) != EINVAL
test VIDIOC_REQBUFS/CREATE_BUFS/QUERYBUF: FAIL
test VIDIOC_EXPBUF: OK
test Requests: OK (Not Supported)
Total for tegra-video device /dev/video0: 45, Succeeded: 44, Failed: 1, Warnings: 0
Then, I tested the following V4L2 pipeline with video0:
v4l2-ctl -v width=1920,height=1080,pixelformat=‘GB12’ --set-ctrl=bypass_mode=0 -c sensor_mode=0 --stream-mmap -d 0 --stream-to=video0.raw
Result in dmesg (see attached dmesg.log for full)
[ 3323.477088] mode settings - 0
[ 3323.490752] [RCE] VM0 deactivating.VM0 activating.NVCSILP clock rate = 204000000 Hz.
[ 3323.490762] [RCE] tegra_nvcsi_stream_set_config(vm0, stream=2, csi=2)
[ 3323.490767] [RCE] MIPI clock = 750000 kHz, tHS-SETTLE = 0, tCLK-SETTLE = 0
[ 3323.490793] [RCE] ===== NVCSI Stream Configuration =====
[ 3323.490796] [RCE] stream_id: PP 2, csi_port: PORT C
[ 3323.490800] [RCE] Brick: PHY 1, Mode: D-PHY
[ 3323.490803] [RCE] Partition: CIL A, LP bypass: Enabled, Lanes: 2
[ 3323.490806] [RCE] Clock information:
[ 3323.490829] [RCE] MIPI clock rate: 750.00 MHz
[ 3323.490834] [RCE] T_HS settle: 0, T_CLK settle: 0
[ 3323.490837] [RCE] ======================================
[ 3323.490841] [RCE] tegra_nvcsi_stream_open(vm0, stream=2, csi=2)
[ 3323.490845] [RCE] nvcsi_reset_data_lanes: NVCSI_PHY_1_NVCSI_CIL_A_SW_RESET_0 = 00000003
[ 3323.490849] [RCE] nvcsi_reset_data_lanes: NVCSI_PHY_1_NVCSI_CIL_B_SW_RESET_0 = 00000000
[ 3323.490854] [RCE] nvcsi_reset_lane_merger: NVCSI_PHY_1_LM_SW_RESET_0 = 00000001
[ 3323.490858] [RCE] nvcsi_reset_lane_merger: NVCSI_PHY_1_LM_SW_RESET_0 = 00000000
[ 3323.490875] [RCE] nvcsi_calc_ths_settle ths_settle 19
[ 3323.490878] [RCE] nvcsi_calc_ths_settle ths_settle 19
[ 3323.490882] [RCE] nvcsi_calc_tclk_settle tclk_settle 33
[ 3323.490890] [RCE] nvcsi_reset_data_lanes: NVCSI_PHY_1_NVCSI_CIL_A_SW_RESET_0 = 00000000
[ 3323.490894] [RCE] nvcsi_reset_data_lanes: NVCSI_PHY_1_NVCSI_CIL_B_SW_RESET_0 = 00000000
[ 3323.611114] eimx462 31-0043: cam_stream_config 633ISP GET CMD Status Succesfull !!
[ 3323.798410] eimx462 31-0043: cam_stream_on 1106MCU Stream On Success !!
[ 3324.062852] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[ 3324.063179] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 3324.064442] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 3324.064642] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 3324.064837] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 3324.064983] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 1
[ 3324.065483] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 3324.462836] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 3324.463504] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 3324.463716] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 3324.463932] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 3324.464127] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 1
[ 3324.464611] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 3324.862841] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 3324.863499] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 3324.863689] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 3324.863909] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 3324.864073] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 1
[ 3324.864598] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 3325.262809] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 3325.263498] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 3325.263675] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 3325.263924] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 3338.464015] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 1
[ 3338.464585] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 3338.473066] eimx462 31-0043: cam_stream_off 1178 MCU Get CMD Stream off Success !!
[ 3338.473087] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 3338.473324] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
Result from trace (full trace in attached sys_trace.log)
v4l2-ctl-7064 [001] .... 3323.456059: tegra_channel_open: vi-output, eimx462 31-0043
v4l2-ctl-7064 [001] .... 3323.462525: tegra_channel_set_power: eimx462 31-0043 : 0x1
v4l2-ctl-7064 [001] .... 3323.462541: camera_common_s_power: status : 0x1
v4l2-ctl-7064 [001] .... 3323.462890: tegra_channel_set_power: 13e10000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-7064 [001] .... 3323.462893: csi_s_power: enable : 0x1
v4l2-ctl-7064 [001] .... 3323.463403: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt c4
v4l2-ctl-7064 [001] .... 3323.470697: tegra_channel_set_stream: enable : 0x1
v4l2-ctl-7064 [001] .... 3323.472230: tegra_channel_set_stream: 13e10000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-7064 [001] .... 3323.472232: csi_s_stream: enable : 0x1
v4l2-ctl-7064 [001] .... 3323.472895: tegra_channel_set_stream: eimx462 31-0043 : 0x1
kworker/2:3-124 [002] .... 3323.490742: rtcpu_string: tstamp:105005791419 id:0x04010000 str:"VM0 activating."
kworker/2:3-124 [002] .... 3323.490745: rtcpu_string: tstamp:105005883206 id:0x04010000 str:"NVCSILP clock rate = 204000000 Hz.
kworker/2:3-124 [002] .... 3323.490757: rtcpu_string: tstamp:105005980457 id:0x04010000 str:"tegra_nvcsi_stream_set_config(vm0, stream=2, csi"
kworker/2:3-124 [002] .... 3323.490760: rtcpu_string: tstamp:105005980571 id:0x04010000 str:"=2)
kworker/2:3-124 [002] .... 3323.490764: rtcpu_string: tstamp:105005981111 id:0x04010000 str:"MIPI clock = 750000 kHz, tHS-SETTLE = 0, tCLK-SE"
kworker/2:3-124 [002] .... 3323.490765: rtcpu_string: tstamp:105005981213 id:0x04010000 str:"TTLE = 0
kworker/2:3-124 [002] .... 3323.490791: rtcpu_string: tstamp:105005981528 id:0x04010000 str:"===== NVCSI Stream Configuration =====
kworker/2:3-124 [002] .... 3323.490795: rtcpu_string: tstamp:105005981847 id:0x04010000 str:"stream_id: PP 2, csi_port: PORT C
kworker/2:3-124 [002] .... 3323.490799: rtcpu_string: tstamp:105005982170 id:0x04010000 str:"Brick: PHY 1, Mode: D-PHY
kworker/2:3-124 [002] .... 3323.490802: rtcpu_string: tstamp:105005982548 id:0x04010000 str:"Partition: CIL A, LP bypass: Enabled, Lanes: 2
kworker/2:3-124 [002] .... 3323.490806: rtcpu_string: tstamp:105005982758 id:0x04010000 str:"Clock information:
kworker/2:3-124 [002] .... 3323.490809: rtcpu_string: tstamp:105005983163 id:0x04010000 str:"MIPI clock rate: 750.00 MHz
kworker/2:3-124 [002] .... 3323.490833: rtcpu_string: tstamp:105005983479 id:0x04010000 str:"T_HS settle: 0, T_CLK settle: 0
kworker/2:3-124 [002] .... 3323.490836: rtcpu_string: tstamp:105005983763 id:0x04010000 str:"======================================
kworker/2:3-124 [002] .... 3323.490839: rtcpu_string: tstamp:105005987059 id:0x04010000 str:"tegra_nvcsi_stream_open(vm0, stream=2, csi=2)
kworker/2:3-124 [002] .... 3323.490843: rtcpu_string: tstamp:105005987841 id:0x04010000 str:"nvcsi_reset_data_lanes: NVCSI_PHY_1_NVCSI_CIL_A_"
kworker/2:3-124 [002] .... 3323.490844: rtcpu_string: tstamp:105005987942 id:0x04010000 str:"SW_RESET_0 = 00000003
kworker/2:3-124 [002] .... 3323.490847: rtcpu_string: tstamp:105005988431 id:0x04010000 str:"nvcsi_reset_data_lanes: NVCSI_PHY_1_NVCSI_CIL_B_"
kworker/2:3-124 [002] .... 3323.490848: rtcpu_string: tstamp:105005988532 id:0x04010000 str:"SW_RESET_0 = 00000000
kworker/2:3-124 [002] .... 3323.490852: rtcpu_string: tstamp:105005989173 id:0x04010000 str:"nvcsi_reset_lane_merger: NVCSI_PHY_1_LM_SW_RESET"
kworker/2:3-124 [002] .... 3323.490853: rtcpu_string: tstamp:105005989271 id:0x04010000 str:"_0 = 00000001
kworker/2:3-124 [002] .... 3323.490856: rtcpu_string: tstamp:105005995454 id:0x04010000 str:"nvcsi_reset_lane_merger: NVCSI_PHY_1_LM_SW_RESET"
kworker/2:3-124 [002] .... 3323.490857: rtcpu_string: tstamp:105005995553 id:0x04010000 str:"_0 = 00000000
kworker/2:3-124 [002] .... 3323.490860: rtcpu_string: tstamp:105005996069 id:0x04010000 str:"nvcsi_calc_ths_settle ths_settle 19
kworker/2:3-124 [002] .... 3323.490877: rtcpu_string: tstamp:105005996417 id:0x04010000 str:"nvcsi_calc_ths_settle ths_settle 19
kworker/2:3-124 [002] .... 3323.490881: rtcpu_string: tstamp:105005996757 id:0x04010000 str:"nvcsi_calc_tclk_settle tclk_settle 33
kworker/2:3-124 [002] .... 3323.490888: rtcpu_string: tstamp:105005997321 id:0x04010000 str:"nvcsi_reset_data_lanes: NVCSI_PHY_1_NVCSI_CIL_A_"
kworker/2:3-124 [002] .... 3323.490889: rtcpu_string: tstamp:105005997420 id:0x04010000 str:"SW_RESET_0 = 00000000
kworker/2:3-124 [002] .... 3323.490892: rtcpu_string: tstamp:105005997918 id:0x04010000 str:"nvcsi_reset_data_lanes: NVCSI_PHY_1_NVCSI_CIL_B_"
kworker/2:3-124 [002] .... 3323.490893: rtcpu_string: tstamp:105005998016 id:0x04010000 str:"SW_RESET_0 = 00000000
kworker/2:3-124 [002] .... 3323.490898: rtcpu_vinotify_event: tstamp:105006229012 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3360189755904 data:0xcd9ce50010000000
kworker/2:3-124 [002] .... 3323.490898: rtcpu_vinotify_event: tstamp:105006229152 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3360189761376 data:0x0000000031000001
kworker/2:3-124 [002] .... 3323.490900: rtcpu_vinotify_event: tstamp:105006229306 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3360189820192 data:0xcd9ce20010000000
kworker/2:3-124 [002] .... 3323.490901: rtcpu_vinotify_event: tstamp:105006229440 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3360189825760 data:0x0000000031000002
kworker/2:3-124 [002] .... 3324.050736: rtcpu_vinotify_event: tstamp:105023757255 cch:0 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:3360751487808 data:0x0000000000000012
kworker/2:3-124 [002] .... 3324.050739: rtcpu_vinotify_event: tstamp:105023757395 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3360751487808 data:0x0000000800000000
kworker/2:3-124 [002] .... 3324.050741: rtcpu_vinotify_event: tstamp:105023757547 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3360751517504 data:0x0000000000000001
kworker/2:3-124 [002] .... 3324.050742: rtcpu_vinotify_event: tstamp:105023757679 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:3360751518784 data:0x0000000008020001
vi-output, eimx-7066 [000] .... 3324.063165: tegra_channel_capture_frame: sof:3360.751517504
vi-output, eimx-7066 [000] .... 3324.063169: tegra_channel_capture_frame: eof:3360.781813408
vi-output, eimx-7066 [000] .... 3324.065279: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt c4
kworker/2:3-124 [002] .... 3324.106739: rtcpu_vinotify_event: tstamp:105024522986 cch:0 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:3360781806144 data:0x0000000000000022
kworker/2:3-124 [002] .... 3324.106742: rtcpu_vinotify_event: tstamp:105024523142 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x44 frame:0 vi_tstamp:3360781806144 data:0x0000200001000000
kworker/2:3-124 [002] .... 3324.106743: rtcpu_vinotify_event: tstamp:105024523296 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:3360781813760 data:0x0000000001020001
kworker/2:3-124 [002] .... 3324.106744: rtcpu_vinotify_event: tstamp:105024523438 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:3360781806144 data:0x0000000800000000
kworker/2:3-124 [002] .... 3324.106745: rtcpu_vinotify_event: tstamp:105024523592 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3360781886752 data:0xcd9ce50010000000
kworker/2:3-124 [002] .... 3324.106746: rtcpu_vinotify_event: tstamp:105024523723 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3360781892320 data:0x0000000031000003
kworker/2:3-124 [002] .... 3324.106747: rtcpu_vinotify_event: tstamp:105024523881 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3360784656480 data:0xcd9ce50010000000
kworker/2:3-124 [002] .... 3324.106748: rtcpu_vinotify_event: tstamp:105024524012 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3360784661952 data:0x0000000031000001
kworker/2:3-124 [002] .... 3324.106749: rtcpu_vinotify_event: tstamp:105024821394 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3360784733152 data:0xcd9ce20010000000
kworker/2:3-124 [002] .... 3324.106750: rtcpu_vinotify_event: tstamp:105024821530 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3360784738944 data:0x0000000031000002
kworker/2:3-124 [002] .... 3324.442724: rtcpu_vinotify_event: tstamp:105036089585 cch:0 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:3361149671296 data:0x0000000000000012
kworker/2:3-124 [002] .... 3324.442727: rtcpu_vinotify_event: tstamp:105036089725 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3361149671296 data:0x0000000800000000
kworker/2:3-124 [002] .... 3324.442728: rtcpu_vinotify_event: tstamp:105036089876 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3361149814432 data:0x0000000000000001
kworker/2:3-124 [002] .... 3324.442729: rtcpu_vinotify_event: tstamp:105036090009 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:3361149815680 data:0x0000000008020001
vi-output, eimx-7066 [000] .... 3324.462820: tegra_channel_capture_frame: sof:3361.149814432
vi-output, eimx-7066 [000] .... 3324.462823: tegra_channel_capture_frame: eof:3361.181791904
vi-output, eimx-7066 [000] .... 3324.464449: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt c4
kworker/2:3-124 [002] .... 3324.498794: rtcpu_vinotify_event: tstamp:105036996482 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:3361181791296 data:0x0000000004370002
kworker/2:3-124 [002] .... 3324.498798: rtcpu_vinotify_event: tstamp:105036996622 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:3361181791744 data:0x0000000000000000
kworker/2:3-124 [002] .... 3324.498799: rtcpu_vinotify_event: tstamp:105036996777 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:3361181794208 data:0x0000000002020001
kworker/2:3-124 [002] .... 3324.498800: rtcpu_vinotify_event: tstamp:105036996910 cch:0 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:3361181791904 data:0x0000000000000022
kworker/2:3-124 [002] .... 3324.498801: rtcpu_vinotify_event: tstamp:105036997066 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:3361181791904 data:0x0000000800000000
kworker/2:3-124 [002] .... 3324.498802: rtcpu_vinotify_event: tstamp:105036997199 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:3361181799424 data:0x0000000000020001
kworker/2:3-124 [002] .... 3324.498803: rtcpu_vinotify_event: tstamp:105036997350 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3361183786976 data:0xcd9ce50010000000
kworker/2:3-124 [002] .... 3324.498804: rtcpu_vinotify_event: tstamp:105036997482 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3361183792480 data:0x0000000031000001
kworker/2:3-124 [002] .... 3324.498805: rtcpu_vinotify_event: tstamp:105036997631 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3361183846816 data:0xcd9ce20010000000
kworker/2:3-124 [002] .... 3324.498806: rtcpu_vinotify_event: tstamp:105036997762 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3361183852384 data:0x0000000031000002
kworker/2:3-124 [002] .... 3324.834705: rtcpu_vinotify_event: tstamp:105048453158 cch:0 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:3361549657376 data:0x0000000000000012
kworker/2:3-124 [002] .... 3324.834709: rtcpu_vinotify_event: tstamp:105048453299 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3361549657376 data:0x0000000800000000
kworker/2:3-124 [002] .... 3324.834711: rtcpu_vinotify_event: tstamp:105048453451 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3361549800512 data:0x0000000000000001
kworker/2:3-124 [002] .... 3324.834739: rtcpu_vinotify_event: tstamp:105048453584 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:3361549801792 data:0x0000000008020001
vi-output, eimx-7066 [000] .... 3324.862818: tegra_channel_capture_frame: sof:3361.549800512
vi-output, eimx-7066 [000] .... 3324.862822: tegra_channel_capture_frame: eof:3361.581778016
vi-output, eimx-7066 [000] .... 3324.864415: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt c4
vi-output, eimx-7066 [000] .... 3338.062353: tegra_channel_capture_frame: sof:3374.749338464
vi-output, eimx-7066 [000] .... 3338.062357: tegra_channel_capture_frame: eof:3374.781316000
vi-output, eimx-7066 [000] .... 3338.064377: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt c4
kworker/2:3-124 [002] .... 3338.074198: rtcpu_vinotify_event: tstamp:105460913339 cch:0 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:3374749195328 data:0x0000000000000012
kworker/2:3-124 [002] .... 3338.074201: rtcpu_vinotify_event: tstamp:105460913483 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3374749195328 data:0x0000000800000000
kworker/2:3-124 [002] .... 3338.074205: rtcpu_vinotify_event: tstamp:105461220927 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3374749338464 data:0x0000000000000001
kworker/2:3-124 [002] .... 3338.074206: rtcpu_vinotify_event: tstamp:105461221065 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:3374749339744 data:0x0000000008020001
kworker/2:3-124 [002] .... 3338.074208: rtcpu_vinotify_event: tstamp:105462159917 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:3374781315392 data:0x0000000004370002
kworker/2:3-124 [002] .... 3338.074209: rtcpu_vinotify_event: tstamp:105462160056 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:3374781315840 data:0x0000000000000000
kworker/2:3-124 [002] .... 3338.074211: rtcpu_vinotify_event: tstamp:105462160209 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:3374781318304 data:0x0000000002020001
kworker/2:3-124 [002] .... 3338.074212: rtcpu_vinotify_event: tstamp:105462160341 cch:0 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:3374781316000 data:0x0000000000000022
kworker/2:3-124 [002] .... 3338.074213: rtcpu_vinotify_event: tstamp:105462160496 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:3374781316000 data:0x0000000800000000
kworker/2:3-124 [002] .... 3338.074214: rtcpu_vinotify_event: tstamp:105462160645 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:3374781323520 data:0x0000000000020001
kworker/2:3-124 [002] .... 3338.074215: rtcpu_vinotify_event: tstamp:105462160795 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3374783738816 data:0xcd9ce50010000000
kworker/2:3-124 [002] .... 3338.074217: rtcpu_vinotify_event: tstamp:105462160927 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3374783744320 data:0x0000000031000001
kworker/2:3-124 [002] .... 3338.074218: rtcpu_vinotify_event: tstamp:105462161076 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3374783798976 data:0xcd9ce20010000000
kworker/2:3-124 [002] .... 3338.074219: rtcpu_vinotify_event: tstamp:105462161209 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3374783804544 data:0x0000000031000002
v4l2-ctl-7064 [001] .... 3338.321880: tegra_channel_close: vi-output, eimx462 31-0043
vi-output, eimx-7066 [001] .... 3338.462362: tegra_channel_capture_frame: sof:3375.149324320
vi-output, eimx-7066 [001] .... 3338.462366: tegra_channel_capture_frame: eof:3375.181301792
vi-output, eimx-7066 [001] .... 3338.464380: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt c4
v4l2-ctl-7064 [000] .... 3338.465425: tegra_channel_set_stream: enable : 0x0
v4l2-ctl-7064 [000] .... 3338.465428: tegra_channel_set_stream: eimx462 31-0043 : 0x0
kworker/2:3-124 [002] .... 3338.466193: rtcpu_vinotify_event: tstamp:105473418518 cch:0 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:3375149181184 data:0x0000000000000012
kworker/2:3-124 [002] .... 3338.466196: rtcpu_vinotify_event: tstamp:105473418658 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3375149181184 data:0x0000000800000000
kworker/2:3-124 [002] .... 3338.466198: rtcpu_vinotify_event: tstamp:105473418809 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3375149324320 data:0x0000000000000001
kworker/2:3-124 [002] .... 3338.466199: rtcpu_vinotify_event: tstamp:105473418977 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:3375149325568 data:0x0000000008020001
kworker/2:3-124 [002] .... 3338.466200: rtcpu_vinotify_event: tstamp:105474429720 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:3375181301216 data:0x0000000004370002
kworker/2:3-124 [002] .... 3338.466201: rtcpu_vinotify_event: tstamp:105474429856 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:3375181301632 data:0x0000000000000000
kworker/2:3-124 [002] .... 3338.466202: rtcpu_vinotify_event: tstamp:105474430008 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:3375181304064 data:0x0000000002020001
kworker/2:3-124 [002] .... 3338.466203: rtcpu_vinotify_event: tstamp:105474430140 cch:0 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:3375181301760 data:0x0000000000000022
kworker/2:3-124 [002] .... 3338.466204: rtcpu_vinotify_event: tstamp:105474430293 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:3375181301792 data:0x0000000800000000
kworker/2:3-124 [002] .... 3338.466205: rtcpu_vinotify_event: tstamp:105474432338 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:3375181309312 data:0x0000000000020001
v4l2-ctl-7064 [001] .... 3338.473077: tegra_channel_set_stream: 13e10000.host1x:nvcsi@15a00000- : 0x0
v4l2-ctl-7064 [001] .... 3338.473082: csi_s_stream: enable : 0x0
v4l2-ctl-7064 [001] .... 3338.475345: tegra_channel_set_power: eimx462 31-0043 : 0x0
v4l2-ctl-7064 [001] .... 3338.475360: camera_common_s_power: status : 0x0
v4l2-ctl-7064 [001] .... 3338.475371: tegra_channel_set_power: 13e10000.host1x:nvcsi@15a00000- : 0x0
v4l2-ctl-7064 [001] .... 3338.475373: csi_s_power: enable : 0x0
kworker/2:3-124 [002] .... 3344.737934: rtcpu_string: tstamp:105669059283 id:0x04010000 str:"VM0 deactivating."
sys_trace.log (113.0 KB)
dmesg.log (24.3 KB)
Finally I tried the following gst argus pipeline with video1 (just to make sure it’s not just an issue with one camera):
GST_DEBUG=3 gst-launch-1.0 -v nvarguscamerasrc sensor-id=1 sensor-mode=0 ! “video/x-raw(memory:NVMM), width=(int)1920,height=(int)1080, format=(string)NV12, framerate=30/1” ! nvv4l2h265enc ! “video/x-h265, stream-format=(string)byte-stream” ! h265parse ! matroskamux ! queue ! filesink location=video0.mkv
Console result from gst-debug:
Setting pipeline to PAUSED ...
Opening in BLOCKING MODE
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
/GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/nvv4l2h265enc:nvv4l2h265enc0.GstPad:src: caps = video/x-h265, stream-format=(string)byte-stream, alignment=(string)au, profile=(string)NULL, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, chroma-site=(string)mpeg2
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:src: caps = video/x-h265, stream-format=(string)byte-stream, alignment=(string)au, profile=(string)NULL, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, chroma-site=(string)mpeg2
/GstPipeline:pipeline0/GstH265Parse:h265parse0.GstPad:sink: caps = video/x-h265, stream-format=(string)byte-stream, alignment=(string)au, profile=(string)NULL, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, chroma-site=(string)mpeg2
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:sink: caps = video/x-h265, stream-format=(string)byte-stream, alignment=(string)au, profile=(string)NULL, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, chroma-site=(string)mpeg2
Redistribute latency...
/GstPipeline:pipeline0/nvv4l2h265enc:nvv4l2h265enc0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 31.622776; Exposure Range min 450000, max 400000000;
GST_ARGUS: 1920 x 1080 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 31.622776; Exposure Range min 450000, max 400000000;
GST_ARGUS: 1280 x 720 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 31.622776; Exposure Range min 450000, max 400000000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 31.622776; Exposure Range min 450000, max 400000000;
GST_ARGUS: Running with following settings:
Camera index = 1
Camera mode = 0
Output Stream W = 1920 H = 1080
seconds to Run = 0
Frame Rate = 29.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
Execution ended after 0:00:01.312667880
Setting pipeline to NULL ...
Result in dmesg:
[ 4471.446131] fuse: init (API version 7.32)
[ 4472.278745] [RCE] VM0 deactivating.VM0 activating.NVCSILP clock rate = 204000000 Hz.
[ 4472.839161] falcon 154c0000.nvenc: Direct firmware load for nvhost_nvenc070.fw failed with error -2
[ 4472.839368] falcon 154c0000.nvenc: Falling back to sysfs fallback for: nvhost_nvenc070.fw
[ 4472.841888] falcon 154c0000.nvenc: looking for firmware in subdirectory
[ 4472.927007] falcon 15a80000.nvenc1: Direct firmware load for nvhost_nvenc070.fw failed with error -2
[ 4472.927245] falcon 15a80000.nvenc1: Falling back to sysfs fallback for: nvhost_nvenc070.fw
[ 4472.930076] falcon 15a80000.nvenc1: looking for firmware in subdirectory
[ 4473.181684] Frame rate data : 125829120
[ 4473.196600] mode settings - 0
[ 4473.202719] [RCE] tegra_nvcsi_stream_tpg_disable(vm0, stream=5, vc=1)
[ 4473.202747] [RCE] tegra_nvcsi_stream_tpg_disable: channel 1 is already disabled
[ 4473.329166] eimx462 32-0043: cam_stream_config 633ISP GET CMD Status Succesfull !!
[ 4473.516085] eimx462 32-0043: cam_stream_on 1106MCU Stream On Success !!
[ 4473.538647] [RCE] tegra_nvcsi_stream_set_config(vm0, stream=5, csi=6)
[ 4473.538656] [RCE] MIPI clock = 750000 kHz, tHS-SETTLE = 0, tCLK-SETTLE = 0
[ 4473.538679] [RCE] ===== NVCSI Stream Configuration =====
[ 4473.538685] [RCE] stream_id: PP 5, csi_port: PORT G
[ 4473.538689] [RCE] Brick: PHY 3, Mode: D-PHY
[ 4473.538693] [RCE] Partition: CIL A, LP bypass: Enabled, Lanes: 2
[ 4473.538698] [RCE] Clock information:
[ 4473.538701] [RCE] MIPI clock rate: 750.00 MHz
[ 4473.538727] [RCE] T_HS settle: 0, T_CLK settle: 0
[ 4473.538731] [RCE] ======================================
[ 4473.538735] [RCE] tegra_nvcsi_stream_open(vm0, stream=5, csi=6)
[ 4473.538739] [RCE] nvcsi_reset_data_lanes: NVCSI_PHY_3_NVCSI_CIL_A_SW_RESET_0 = 00000003
[ 4473.538745] [RCE] nvcsi_reset_data_lanes: NVCSI_PHY_3_NVCSI_CIL_B_SW_RESET_0 = 00000000
[ 4473.538749] [RCE] nvcsi_reset_lane_merger: NVCSI_PHY_3_LM_SW_RESET_0 = 00000001
[ 4473.538754] [RCE] nvcsi_reset_lane_merger: NVCSI_PHY_3_LM_SW_RESET_0 = 00000000
[ 4473.538774] [RCE] nvcsi_calc_ths_settle ths_settle 19
[ 4473.538778] [RCE] nvcsi_calc_ths_settle ths_settle 19
[ 4473.538782] [RCE] nvcsi_calc_tclk_settle tclk_settle 33
[ 4473.538787] [RCE] nvcsi_reset_data_lanes: NVCSI_PHY_3_NVCSI_CIL_A_SW_RESET_0 = 00000000
[ 4473.538792] [RCE] nvcsi_reset_data_lanes: NVCSI_PHY_3_NVCSI_CIL_B_SW_RESET_0 = 00000000
[ 4474.239655] eimx462 32-0043: cam_stream_off 1178 MCU Get CMD Stream off Success !!
[ 4474.270638] [RCE] tegra_nvcsi_stream_tpg_disable(vm0, stream=5, vc=1)
[ 4474.270650] [RCE] tegra_nvcsi_stream_tpg_disable: error: stream 5 is configured for phy input
[ 4474.270661] [RCE] tegra_nvcsi_stream_close(vm0, stream=5, csi=6)
[ 4474.270666] [RCE] nvcsi_reset_data_lanes: NVCSI_PHY_3_NVCSI_CIL_A_SW_RESET_0 = 00000003
[ 4474.270671] [RCE] nvcsi_reset_data_lanes: NVCSI_PHY_3_NVCSI_CIL_B_SW_RESET_0 = 00000000
[ 4474.270677] [RCE] nvcsi_reset_lane_merger: NVCSI_PHY_3_LM_SW_RESET_0 = 00000001
Result from nvargus-daemon logs: see attached nvargus-daemon.log. (It is long and I am unsure if it provides correct/useful information.)
nvargus-daemon.log (129.8 KB)
Important: I have verified the camera driver and this device tree HAVE worked with Jetpack 4.6 (with minimal changes). So I know that the hardware itself is correct. But the problem must be in changes required for Jetpack 5.
Would you please be able to help debug this issue? I am able to collect some oscilloscope readings during the next 3-4 days if required.
Thank you in advance.
