Hi Experts,
I am porting a driver of a bridge chipset (without I2C communication, pseudo-named toto) which has been working perfectly in Jetpack-4.5.1 to Jetpack 5.0.2 with modification only in dtsi:
#include <dt-bindings/media/camera.h>
#include "dt-bindings/clock/tegra194-clock.h"
tegra-capture-vi {
num-channels = <2>;
ports {
#address-cells = <1>;
#size-cells = <0>;
vi_port0: port@0 {
reg = <0>;
toto_vi_in0: endpoint {
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&toto_csi_out0>;
vi_port1: port@1 {
reg = <1>;
adv7280_vi_in0: endpoint {
port-index = <4>;
bus-width = <1>;
remote-endpoint = <&adv7280_csi_out0>;
host1x@13e00000 {
nvcsi@15a00000 {
num-channels = <2>;
#size-cells = <0>;
csi_chan0: channel@0 {
reg = <0x0>;
ports {
#size-cells = <0>;
csi_chan0_port0: port@0 {
reg = <0>;
toto_csi_in0: endpoint@0 {
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&toto_out0>;
csi_chan0_port1: port@1 {
reg = <1>;
toto_csi_out0: endpoint@1 {
remote-endpoint = <&toto_vi_in0>;
csi_chan1: channel@1 {
reg = <0x1>;
discontinuous_clk = "no";
ports {
#size-cells = <0>;
csi_chan1_port0: port@0 {
reg = <0>;
adv7280_csi_in0: endpoint@2 {
port-index = <4>;
bus-width = <1>;
remote-endpoint = <&adv7280_out0>;
csi_chan1_port1: port@1 {
reg = <1>;
adv7280_csi_out0: endpoint@3 {
remote-endpoint = <&adv7280_vi_in0>;
i2c@31e0000 {
status = "okay";
#size-cells = <0>;
mcp23008_27: gpio@27 {
compatible = "microchip,mcp23008";
gpio-controller;
#gpio-cells = <2>;
reg = <0x27>;
status = "okay";
interrupt-parent = <&tegra_aon_gpio>;
interrupts = <320 IRQ_TYPE_EDGE_FALLING>;
irq-gpios = <&tegra_aon_gpio 320 GPIO_ACTIVE_HIGH>;
reset-gpios = <&tegra_main_gpio 438 GPIO_ACTIVE_HIGH>;
interrupt-controller;
#interrupt-cells=<2>;
microchip,irq-mirror;
microchip,irq-active-high;
mcp23008_27_output_low {
status = "disabled";
mcp23008_27_output_high {
gpio-hog;
output-high;
gpios = <1 0 2 0 3 0>;
label = "ioexp_adv_3v3_en", "ioexp_adv_reset", "ioexp_sony_reset";
toto_a@10 {
compatible = "sony,toto";
/* I2C device address */
reg = <0x10>;
/* V4L2 device node location */
devnode = "video0";
/* Physical dimensions of sensor */
physical_w = "1.944";
physical_h = "1.097";
sensor_model = "toto";
use_sensor_mode_id = "false";
/* Define any required hw resources needed by driver */
/* ie. clocks, io pins, power sources */
avdd-reg = "vana";
iovdd-reg = "vif";
dvdd-reg = "vdig";
/* mclk-index indicates the index of the */
/* mclk-name with in the clock-names array */
clocks = <&bpmp_clks TEGRA194_CLK_EXTPERIPH1>,
<&bpmp_clks TEGRA194_CLK_PLLP_OUT0>;
clock-names = "extperiph1", "pllp_grtba";
status = "okay";
mclk = "extperiph1";
clock-frequency = <24000000>;
vana-supply = <&p3509_vdd_3v3_cvb>;
vdig-supply = <&p3509_vdd_sys_en>;
reset-gpios = <&mcp23008_27 3 GPIO_ACTIVE_LOW>;
mode0 {
mclk_khz = "24000";
num_lanes = "4";
phy_mode = "DPHY";
dpcm_enable = "false";
cil_settletime = "0";
active_w = "1920";
active_h = "1080";
mode_type = "yuv";
pixel_phase = "uyvy";
pixel_t = "yuv_uyvy16";
dynamic_pixel_bit_depth = "16";
csi_pixel_bit_depth = "16";
readout_orientation = "0";
line_length = "1920";
inherent_gain = "1";
mclk_multiplier = "30";
pix_clk_hz = "742500000";
gain_factor = "10";
min_gain_val = "10";/* 1DB*/
max_gain_val = "160";/* 16DB*/
step_gain_val = "1";
default_gain = "10";
min_hdr_ratio = "1";
max_hdr_ratio = "1";
framerate_factor = "1000000";
min_framerate = "1816577";/*1.816577 */
max_framerate = "60000000";/*60fps*/
step_framerate = "1";
default_framerate = "60000000";/*60fps*/
exposure_factor = "1000000";
min_exp_time = "34";/* us */
max_exp_time = "550385";/* us */
step_exp_time = "1";
default_exp_time = "33334";/* us */
embedded_metadata_height = "0";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
toto_out0: endpoint {
status = "okay";
port-index = <0>; /* CSI A */
bus-width = <4>;
remote-endpoint = <&toto_csi_in0>;
adv7280_e@20 {
compatible = "adi,adv7280-m";
reg = <0x20>;
devnode = "video1";
physical_w = "4.713";
physical_h = "3.494";
sensor_model = "adv7280-m";
// clocks = <&bpmp_clks TEGRA194_CLK_EXTPERIPH1>,
// <&bpmp_clks TEGRA194_CLK_PLLP_OUT0>;
// clock-names = "extperiph1", "pllp_grtba";
// mclk = "extperiph1";
// refclk_hz = <28636363>;
// linux,phandle = <0x118>;
// phandle = <0x118>;
reset-gpios = <&mcp23008_27 2 GPIO_ACTIVE_LOW>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
adv7280_out0: endpoint {
port-index = <4>; /* CSI E */
bus-width = <1>;
remote-endpoint = <&adv7280_csi_in0>;
tcp: tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
* Physical settings to calculate max ISO BW
* num_csi_lanes = <>;
* Total number of CSI lanes when all cameras are active
* max_lane_speed = <>;
* Max lane speed in Kbit/s
* min_bits_per_pixel = <>;
* Min bits per pixel
* vi_peak_byte_per_pixel = <>;
* Max byte per pixel for the VI ISO case
* vi_bw_margin_pct = <>;
* Vi bandwidth margin in percentage
* max_pixel_rate = <>;
* Max pixel rate in Kpixel/s for the ISP ISO case
* isp_peak_byte_per_pixel = <>;
* Max byte per pixel for the ISP ISO case
* isp_bw_margin_pct = <>;
* Isp bandwidth margin in percentage
num_csi_lanes = <4>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <10>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
max_pixel_rate = <240000>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
* The general guideline for naming badge_info contains 3 parts, and is as follows,
* The first part is the camera_board_id for the module; if the module is in a FFD
* platform, then use the platform name for this part.
* The second part contains the position of the module, ex. "rear" or "front".
* The third part contains the last 6 characters of a part number which is found
* in the module's specsheet from the vendor.
modules {
cam_module0: module0 {
badge = "jakku_FCB_mipi";
position = "left";
orientation = "1";
cam_module0_drivernode0: drivernode0 {
pcl_id = "v4l2_sensor";
devname = "toto 8-0010";
proc-device-tree = "/proc/device-tree/i2c@31e0000/toto_a@10";
cam_module1: module1 {
status = "okay";
badge = "jakku_ANA_mipi";
position = "right";
orientation = "1";
cam_module1_drivernode0: drivernode0 {
devname = "adv7280m 8-0020";
proc-device-tree = "/proc/device-tree/i2c@31e0000/adv7280_e@20";
and got following error :
[ 147.752421] toto 8-0010: toto_power_on: power on
[ 150.495786] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 150.496064] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 150.500562] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 150.500761] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 150.500982] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 150.502210] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 150.511798] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 153.055565] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 153.055866] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 153.056490] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 153.056663] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 153.056863] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 153.057011] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 153.057453] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 155.615426] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 155.615699] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 155.616510] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 155.616676] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 155.616958] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 155.617137] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 155.617570] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 158.175240] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 158.175522] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 158.176498] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 158.176657] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 158.176884] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 158.177039] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 158.177453] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 160.735114] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 160.735375] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 160.736589] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 160.736792] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 160.736995] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 160.737144] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 160.737627] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 163.294976] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 163.295234] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 163.296548] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 163.296732] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 163.296957] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 163.297122] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 163.297671] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 165.822903] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 165.823155] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 165.824556] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 165.824721] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 165.824947] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 165.825113] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 165.825627] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 165.847487] toto 8-0010: toto_power_off: power off
I then boosted the clocks as below :
rtr@ubuntu:~/Workspace$ sudo ./max_clock.sh
vi clock rate is:460800000
isp clock rate is:576000000
emc clock rate is:1866000000
nvcsi clock rate is:314000000
And enabled the tracing:
trace-on()
local BASE="/sys/kernel/debug"
local tracing_base="${BASE}/tracing"
echo 1 > "${tracing_base}/tracing_on"
echo 30720 > "${tracing_base}/buffer_size_kb"
echo 1 > "${tracing_base}/events/tegra_rtcpu/enable"
echo 1 > "${tracing_base}/events/freertos/enable"
echo 2 > "${BASE}/camrtc/log-level"
echo 1 > "${tracing_base}/events/camera_common/enable"
echo > "${tracing_base}/trace"
echo "Run cat ${tracing_base}/trace to show the trace"
trace-on
which gave :
rtr@ubuntu:~/Workspace$ sudo cat /sys/kernel/debug/tracing/trace
# tracer: nop
# entries-in-buffer/entries-written: 227/227 #P:4
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/0:2-87 [000] .... 224.462473: rtcpu_string: tstamp:7805133114 id:0x04010000 str:"VM0 deactivating."
gst-plugin-scan-2727 [002] .... 243.559538: tegra_channel_open: vi-output, toto 8-0010
gst-plugin-scan-2727 [002] .... 243.559779: tegra_channel_close: vi-output, toto 8-0010
gst-plugin-scan-2727 [002] .... 243.559800: tegra_channel_open: vi-output, adv7280 8-0020
gst-plugin-scan-2727 [002] .... 243.559854: tegra_channel_close: vi-output, adv7280 8-0020
gst-launch-1.0-2726 [003] .... 243.756229: tegra_channel_open: vi-output, toto 8-0010
gst-launch-1.0-2726 [003] .... 243.756483: tegra_channel_close: vi-output, toto 8-0010
gst-launch-1.0-2726 [003] .... 243.756502: tegra_channel_open: vi-output, adv7280 8-0020
gst-launch-1.0-2726 [003] .... 243.756555: tegra_channel_close: vi-output, adv7280 8-0020
gst-launch-1.0-2726 [003] .... 243.775976: tegra_channel_open: vi-output, toto 8-0010
v4l2src0:src-2729 [000] .... 243.786121: tegra_channel_set_power: toto 8-0010 : 0x1
v4l2src0:src-2729 [000] .... 243.786137: camera_common_s_power: status : 0x1
v4l2src0:src-2729 [000] .... 243.793769: tegra_channel_set_power: 13e10000.host1x:nvcsi@15a00000- : 0x1
v4l2src0:src-2729 [000] .... 243.793774: csi_s_power: enable : 0x1
v4l2src0:src-2729 [000] .... 243.794253: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
v4l2src0:src-2729 [001] .... 243.800795: tegra_channel_set_stream: enable : 0x1
v4l2src0:src-2729 [001] .... 243.802035: tegra_channel_set_stream: 13e10000.host1x:nvcsi@15a00000- : 0x1
v4l2src0:src-2729 [001] .... 243.802042: csi_s_stream: enable : 0x1
v4l2src0:src-2729 [001] .... 243.802450: tegra_channel_set_stream: toto 8-0010 : 0x1
kworker/0:2-87 [000] .... 243.834292: rtcpu_string: tstamp:8409960756 id:0x04010000 str:"VM0 activating."
kworker/0:2-87 [000] .... 243.834297: rtcpu_vinotify_event: tstamp:8410407045 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:269122587904 data:0xcd9ce50010000000
kworker/0:2-87 [000] .... 243.834298: rtcpu_vinotify_event: tstamp:8410407193 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:269122599680 data:0x0000000031000001
kworker/0:2-87 [000] .... 243.834299: rtcpu_vinotify_event: tstamp:8410407355 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:269122654784 data:0xcd9ce20010000000
kworker/0:2-87 [000] .... 243.834300: rtcpu_vinotify_event: tstamp:8410407495 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:269122666720 data:0x0000000031000002
vi-output, ev95-2732 [000] .... 246.496609: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/0:2-87 [000] .... 246.634232: rtcpu_vinotify_event: tstamp:8497213469 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:271907952928 data:0xcd9ce50010000000
kworker/0:2-87 [000] .... 246.634236: rtcpu_vinotify_event: tstamp:8497213617 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:271907964704 data:0x0000000031000001
kworker/0:2-87 [000] .... 246.690271: rtcpu_vinotify_event: tstamp:8498908998 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:271955165952 data:0xcd9ce20010000000
kworker/0:2-87 [000] .... 246.690275: rtcpu_vinotify_event: tstamp:8498909147 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:271955177856 data:0x0000000031000002
vi-output, ev95-2732 [000] .... 249.312661: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/0:2-87 [000] .... 249.378371: rtcpu_vinotify_event: tstamp:8583002714 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:274647758848 data:0xcd9ce50010000000
kworker/0:2-87 [000] .... 249.378375: rtcpu_vinotify_event: tstamp:8583002863 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:274647770592 data:0x0000000031000001
kworker/0:2-87 [000] .... 249.378375: rtcpu_vinotify_event: tstamp:8583680885 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:274675949120 data:0xcd9ce20010000000
kworker/0:2-87 [000] .... 249.378376: rtcpu_vinotify_event: tstamp:8583681035 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:274675961024 data:0x0000000031000002
vi-output, ev95-2732 [000] .... 251.872479: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/0:2-87 [000] .... 251.910208: rtcpu_vinotify_event: tstamp:8663027228 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:277207572544 data:0xcd9ce50010000000
kworker/0:2-87 [000] .... 251.910213: rtcpu_vinotify_event: tstamp:8663027390 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:277207584320 data:0x0000000031000001
kworker/0:2-87 [000] .... 251.966191: rtcpu_vinotify_event: tstamp:8663667752 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:277237327488 data:0xcd9ce20010000000
kworker/0:2-87 [000] .... 251.966195: rtcpu_vinotify_event: tstamp:8663667897 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:277237339424 data:0x0000000031000002
vi-output, ev95-2732 [000] .... 254.432693: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/0:2-87 [000] .... 254.494185: rtcpu_vinotify_event: tstamp:8742746606 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:279767666976 data:0xcd9ce50010000000
kworker/0:2-87 [000] .... 254.494189: rtcpu_vinotify_event: tstamp:8742746768 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:279767678752 data:0x0000000031000001
kworker/0:2-87 [000] .... 254.494190: rtcpu_vinotify_event: tstamp:8743763966 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:279795848192 data:0xcd9ce20010000000
kworker/0:2-87 [000] .... 254.494191: rtcpu_vinotify_event: tstamp:8743764115 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:279795860832 data:0x0000000031000002
vi-output, ev95-2732 [000] .... 256.992683: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/0:2-87 [000] .... 257.014210: rtcpu_vinotify_event: tstamp:8822771512 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:282327627584 data:0xcd9ce50010000000
kworker/0:2-87 [000] .... 257.014214: rtcpu_vinotify_event: tstamp:8822771660 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:282327639360 data:0x0000000031000001
kworker/0:2-87 [000] .... 257.070133: rtcpu_vinotify_event: tstamp:8823788583 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:282357823968 data:0xcd9ce20010000000
kworker/0:2-87 [000] .... 257.070137: rtcpu_vinotify_event: tstamp:8823788731 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:282357835904 data:0x0000000031000002
vi-output, ev95-2732 [000] .... 259.552689: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/0:2-87 [000] .... 259.590116: rtcpu_vinotify_event: tstamp:8902796171 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:284887606816 data:0xcd9ce50010000000
kworker/0:2-87 [000] .... 259.590124: rtcpu_vinotify_event: tstamp:8902796333 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:284887618592 data:0x0000000031000001
kworker/0:2-87 [000] .... 259.646140: rtcpu_vinotify_event: tstamp:8903813477 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:284918486336 data:0xcd9ce20010000000
kworker/0:2-87 [000] .... 259.646143: rtcpu_vinotify_event: tstamp:8903813627 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:284918498304 data:0x0000000031000002
vi-output, ev95-2732 [002] .... 262.112745: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/0:2-87 [000] .... 262.166135: rtcpu_vinotify_event: tstamp:8982820646 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:287447868768 data:0xcd9ce50010000000
kworker/0:2-87 [000] .... 262.166140: rtcpu_vinotify_event: tstamp:8982820794 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:287447880512 data:0x0000000031000001
kworker/0:2-87 [000] .... 262.166141: rtcpu_vinotify_event: tstamp:8983644104 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:287476571936 data:0xcd9ce20010000000
kworker/0:2-87 [000] .... 262.166142: rtcpu_vinotify_event: tstamp:8983644252 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:287476583872 data:0x0000000031000002
vi-output, ev95-2732 [002] .... 264.671645: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/0:2-87 [000] .... 264.690147: rtcpu_vinotify_event: tstamp:9062743644 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:290007634784 data:0xcd9ce50010000000
kworker/0:2-87 [000] .... 264.690152: rtcpu_vinotify_event: tstamp:9062743791 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:290007646560 data:0x0000000031000001
kworker/0:2-87 [000] .... 264.746080: rtcpu_vinotify_event: tstamp:9063761004 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:290037021376 data:0xcd9ce20010000000
kworker/0:2-87 [000] .... 264.746084: rtcpu_vinotify_event: tstamp:9063761186 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:290037033280 data:0x0000000031000002
vi-output, ev95-2732 [002] .... 267.232698: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/0:2-87 [000] .... 267.266015: rtcpu_vinotify_event: tstamp:9142768505 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:292567774016 data:0xcd9ce50010000000
kworker/0:2-87 [000] .... 267.266024: rtcpu_vinotify_event: tstamp:9142768653 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:292567785760 data:0x0000000031000001
kworker/0:2-87 [000] .... 267.322043: rtcpu_vinotify_event: tstamp:9143785769 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:292597349632 data:0xcd9ce20010000000
kworker/0:2-87 [000] .... 267.322047: rtcpu_vinotify_event: tstamp:9143785917 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:292597361568 data:0x0000000031000002
vi-output, ev95-2732 [002] .... 269.791881: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/0:2-87 [000] .... 269.841985: rtcpu_vinotify_event: tstamp:9222793129 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:295127427744 data:0xcd9ce50010000000
kworker/0:2-87 [000] .... 269.841989: rtcpu_vinotify_event: tstamp:9222793277 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:295127439520 data:0x0000000031000001
kworker/0:2-87 [000] .... 269.841990: rtcpu_vinotify_event: tstamp:9223810248 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:295157650816 data:0xcd9ce20010000000
kworker/0:2-87 [000] .... 269.841990: rtcpu_vinotify_event: tstamp:9223810396 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:295157662752 data:0x0000000031000002
vi-output, ev95-2732 [000] .... 272.351806: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/0:2-87 [000] .... 272.417924: rtcpu_vinotify_event: tstamp:9302817808 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:297687840576 data:0xcd9ce50010000000
kworker/0:2-87 [000] .... 272.417928: rtcpu_vinotify_event: tstamp:9302817957 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:297687852352 data:0x0000000031000001
kworker/0:2-87 [000] .... 272.417929: rtcpu_vinotify_event: tstamp:9303655872 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:297716948480 data:0xcd9ce20010000000
kworker/0:2-87 [000] .... 272.417930: rtcpu_vinotify_event: tstamp:9303656018 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:297716960416 data:0x0000000031000002
vi-output, ev95-2732 [003] .... 274.911650: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/0:2-87 [000] .... 274.937885: rtcpu_vinotify_event: tstamp:9382740632 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:300247520608 data:0xcd9ce50010000000
kworker/0:2-87 [000] .... 274.937888: rtcpu_vinotify_event: tstamp:9382740778 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:300247532352 data:0x0000000031000001
kworker/0:2-87 [000] .... 274.993903: rtcpu_vinotify_event: tstamp:9383757866 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:300277636032 data:0xcd9ce20010000000
kworker/0:2-87 [000] .... 274.993908: rtcpu_vinotify_event: tstamp:9383758014 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:300277647968 data:0x0000000031000002
vi-output, ev95-2732 [000] .... 277.471541: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/0:2-87 [000] .... 277.513830: rtcpu_vinotify_event: tstamp:9462765318 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:302807231328 data:0xcd9ce50010000000
kworker/0:2-87 [000] .... 277.513834: rtcpu_vinotify_event: tstamp:9462765466 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:302807243104 data:0x0000000031000001
kworker/0:2-87 [000] .... 277.573818: rtcpu_vinotify_event: tstamp:9463782503 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:302836924032 data:0xcd9ce20010000000
kworker/0:2-87 [000] .... 277.573822: rtcpu_vinotify_event: tstamp:9463782653 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:302836936000 data:0x0000000031000002
vi-output, ev95-2732 [000] .... 280.031652: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/0:2-87 [000] .... 280.093818: rtcpu_vinotify_event: tstamp:9542790134 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:305367233504 data:0xcd9ce50010000000
kworker/0:2-87 [000] .... 280.093822: rtcpu_vinotify_event: tstamp:9542790284 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:305367245280 data:0x0000000031000001
kworker/0:2-87 [000] .... 280.093824: rtcpu_vinotify_event: tstamp:9543807302 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:305398940576 data:0xcd9ce20010000000
kworker/0:2-87 [000] .... 280.093825: rtcpu_vinotify_event: tstamp:9543807460 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:305398952480 data:0x0000000031000002
vi-output, ev95-2732 [000] .... 282.591661: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/0:2-87 [000] .... 282.617739: rtcpu_vinotify_event: tstamp:9622814584 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:307927314880 data:0xcd9ce50010000000
kworker/0:2-87 [000] .... 282.617743: rtcpu_vinotify_event: tstamp:9622814732 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:307927326656 data:0x0000000031000001
kworker/0:2-87 [000] .... 282.673772: rtcpu_vinotify_event: tstamp:9623668968 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:307957366784 data:0xcd9ce20010000000
kworker/0:2-87 [000] .... 282.673777: rtcpu_vinotify_event: tstamp:9623669116 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:307957379424 data:0x0000000031000002
vi-output, ev95-2732 [001] .... 285.151631: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/0:2-87 [000] .... 285.197708: rtcpu_vinotify_event: tstamp:9702737592 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:310487323968 data:0xcd9ce50010000000
kworker/0:2-87 [000] .... 285.197711: rtcpu_vinotify_event: tstamp:9702737740 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:310487335744 data:0x0000000031000001
kworker/0:2-87 [000] .... 285.253684: rtcpu_vinotify_event: tstamp:9703754960 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:310516891200 data:0xcd9ce20010000000
kworker/0:2-87 [000] .... 285.253688: rtcpu_vinotify_event: tstamp:9703755111 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:310516903136 data:0x0000000031000002
vi-output, ev95-2732 [002] .... 287.711769: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/0:2-87 [000] .... 287.777655: rtcpu_vinotify_event: tstamp:9782762270 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:313047403328 data:0xcd9ce50010000000
kworker/0:2-87 [000] .... 287.777660: rtcpu_vinotify_event: tstamp:9782762421 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:313047415104 data:0x0000000031000001
kworker/0:2-87 [000] .... 287.777661: rtcpu_vinotify_event: tstamp:9783779554 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:313075998944 data:0xcd9ce20010000000
kworker/0:2-87 [000] .... 287.777662: rtcpu_vinotify_event: tstamp:9783779702 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:313076010880 data:0x0000000031000002
vi-output, ev95-2732 [003] .... 290.271545: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/0:2-87 [000] .... 290.297640: rtcpu_vinotify_event: tstamp:9862786838 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:315607272288 data:0xcd9ce50010000000
kworker/0:2-87 [000] .... 290.297644: rtcpu_vinotify_event: tstamp:9862786987 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:315607284064 data:0x0000000031000001
kworker/0:2-87 [000] .... 290.357581: rtcpu_vinotify_event: tstamp:9863804196 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:315635859008 data:0xcd9ce20010000000
kworker/0:2-87 [000] .... 290.357585: rtcpu_vinotify_event: tstamp:9863804348 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:315635870976 data:0x0000000031000002
vi-output, ev95-2732 [001] .... 292.831620: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/0:2-87 [000] .... 292.893576: rtcpu_vinotify_event: tstamp:9942811686 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:318167159200 data:0xcd9ce50010000000
kworker/0:2-87 [000] .... 292.893579: rtcpu_vinotify_event: tstamp:9942811835 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:318167170944 data:0x0000000031000001
kworker/0:2-87 [000] .... 292.893580: rtcpu_vinotify_event: tstamp:9943561785 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:318193937696 data:0xcd9ce20010000000
kworker/0:2-87 [000] .... 292.893580: rtcpu_vinotify_event: tstamp:9943561932 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:318193949632 data:0x0000000031000002
vi-output, ev95-2732 [000] .... 295.391759: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/0:2-87 [000] .... 295.413546: rtcpu_vinotify_event: tstamp:10022734709 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:320726971072 data:0xcd9ce50010000000
kworker/0:2-87 [000] .... 295.413554: rtcpu_vinotify_event: tstamp:10022734855 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:320726982848 data:0x0000000031000001
kworker/0:2-87 [000] .... 295.469515: rtcpu_vinotify_event: tstamp:10023751874 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:320751924320 data:0xcd9ce20010000000
kworker/0:2-87 [000] .... 295.469524: rtcpu_vinotify_event: tstamp:10023752022 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:320751936256 data:0x0000000031000002
vi-output, ev95-2732 [003] .... 297.951715: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/0:2-87 [000] .... 297.989444: rtcpu_vinotify_event: tstamp:10102759287 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:323287236224 data:0xcd9ce50010000000
kworker/0:2-87 [000] .... 297.989447: rtcpu_vinotify_event: tstamp:10102759435 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:323287248000 data:0x0000000031000001
kworker/0:2-87 [000] .... 298.045487: rtcpu_vinotify_event: tstamp:10103776581 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:323312090208 data:0xcd9ce20010000000
kworker/0:2-87 [000] .... 298.045491: rtcpu_vinotify_event: tstamp:10103776738 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:323312102144 data:0x0000000031000002
vi-output, ev95-2732 [003] .... 300.511762: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/0:2-87 [000] .... 300.565445: rtcpu_vinotify_event: tstamp:10182784055 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:325847111488 data:0xcd9ce50010000000
kworker/0:2-87 [000] .... 300.565449: rtcpu_vinotify_event: tstamp:10182784217 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:325847123296 data:0x0000000031000001
kworker/0:2-87 [000] .... 300.565450: rtcpu_vinotify_event: tstamp:10183801254 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:325875032096 data:0xcd9ce20010000000
kworker/0:2-87 [000] .... 300.565451: rtcpu_vinotify_event: tstamp:10183801402 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:325875044032 data:0x0000000031000002
vi-output, ev95-2732 [001] .... 303.071742: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/0:2-87 [000] .... 303.141422: rtcpu_vinotify_event: tstamp:10262808600 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:328407365952 data:0xcd9ce50010000000
kworker/0:2-87 [000] .... 303.141426: rtcpu_vinotify_event: tstamp:10262808748 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:328407377728 data:0x0000000031000001
kworker/0:2-87 [000] .... 303.141428: rtcpu_vinotify_event: tstamp:10263503337 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:328432067328 data:0xcd9ce20010000000
kworker/0:2-87 [000] .... 303.141429: rtcpu_vinotify_event: tstamp:10263503483 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:328432079264 data:0x0000000031000002
vi-output, ev95-2732 [003] .... 305.631729: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/0:2-87 [000] .... 305.661346: rtcpu_vinotify_event: tstamp:10342731463 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:330966984352 data:0xcd9ce50010000000
kworker/0:2-87 [000] .... 305.661351: rtcpu_vinotify_event: tstamp:10342731624 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:330966996160 data:0x0000000031000001
kworker/0:2-87 [000] .... 305.717360: rtcpu_vinotify_event: tstamp:10343748883 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:330991793536 data:0xcd9ce20010000000
kworker/0:2-87 [000] .... 305.717364: rtcpu_vinotify_event: tstamp:10343749033 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:330991805440 data:0x0000000031000002
vi-output, ev95-2732 [003] .... 308.191744: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/0:2-87 [000] .... 308.237314: rtcpu_vinotify_event: tstamp:10422756243 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:333526725152 data:0xcd9ce50010000000
kworker/0:2-87 [000] .... 308.237318: rtcpu_vinotify_event: tstamp:10422756394 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:333526736928 data:0x0000000031000001
kworker/0:2-87 [000] .... 308.293321: rtcpu_vinotify_event: tstamp:10423773452 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:333552820352 data:0xcd9ce20010000000
kworker/0:2-87 [000] .... 308.293325: rtcpu_vinotify_event: tstamp:10423773614 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:333552832288 data:0x0000000031000002
vi-output, ev95-2732 [003] .... 310.751682: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/0:2-87 [000] .... 310.813318: rtcpu_vinotify_event: tstamp:10502780797 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:336086916768 data:0xcd9ce50010000000
kworker/0:2-87 [000] .... 310.813323: rtcpu_vinotify_event: tstamp:10502780947 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:336086928544 data:0x0000000031000001
kworker/0:2-87 [000] .... 310.813324: rtcpu_vinotify_event: tstamp:10503798172 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:336111888032 data:0xcd9ce20010000000
kworker/0:2-87 [000] .... 310.813325: rtcpu_vinotify_event: tstamp:10503798321 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:336111899968 data:0x0000000031000002
vi-output, ev95-2732 [003] .... 313.311717: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/0:2-87 [000] .... 313.333234: rtcpu_vinotify_event: tstamp:10582805457 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:338646905280 data:0xcd9ce50010000000
kworker/0:2-87 [000] .... 313.333237: rtcpu_vinotify_event: tstamp:10582805603 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:338646917792 data:0x0000000031000001
kworker/0:2-87 [000] .... 313.393332: rtcpu_vinotify_event: tstamp:10583522109 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:338672668128 data:0xcd9ce20010000000
kworker/0:2-87 [000] .... 313.393336: rtcpu_vinotify_event: tstamp:10583522255 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:338672680064 data:0x0000000031000002
vi-output, ev95-2732 [003] .... 315.871577: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/0:2-87 [000] .... 315.913304: rtcpu_vinotify_event: tstamp:10662728368 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:341206669440 data:0xcd9ce50010000000
kworker/0:2-87 [000] .... 315.913308: rtcpu_vinotify_event: tstamp:10662728514 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:341206681216 data:0x0000000031000001
kworker/0:2-87 [000] .... 315.969206: rtcpu_vinotify_event: tstamp:10663745737 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:341231460576 data:0xcd9ce20010000000
kworker/0:2-87 [000] .... 315.969210: rtcpu_vinotify_event: tstamp:10663745885 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:341231472512 data:0x0000000031000002
vi-output, ev95-2732 [001] .... 318.431736: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/0:2-87 [000] .... 318.489153: rtcpu_vinotify_event: tstamp:10742753212 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:343766879840 data:0xcd9ce50010000000
kworker/0:2-87 [000] .... 318.489157: rtcpu_vinotify_event: tstamp:10742753360 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:343766891584 data:0x0000000031000001
kworker/0:2-87 [000] .... 318.489159: rtcpu_vinotify_event: tstamp:10743770536 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:343792030880 data:0xcd9ce20010000000
kworker/0:2-87 [000] .... 318.489187: rtcpu_vinotify_event: tstamp:10743770685 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:343792042848 data:0x0000000031000002
vi-output, ev95-2732 [003] .... 320.991726: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/0:2-87 [000] .... 321.009123: rtcpu_vinotify_event: tstamp:10822777744 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:346326495904 data:0xcd9ce50010000000
kworker/0:2-87 [000] .... 321.009128: rtcpu_vinotify_event: tstamp:10822777892 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:346326507680 data:0x0000000031000001
kworker/0:2-87 [000] .... 321.065153: rtcpu_vinotify_event: tstamp:10823795172 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:346350764928 data:0xcd9ce20010000000
kworker/0:2-87 [000] .... 321.065296: rtcpu_vinotify_event: tstamp:10823795331 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:346350777600 data:0x0000000031000002
vi-output, ev95-2732 [001] .... 323.551677: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/0:2-87 [000] .... 323.585100: rtcpu_vinotify_event: tstamp:10902802618 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:348886635328 data:0xcd9ce50010000000
kworker/0:2-87 [000] .... 323.585104: rtcpu_vinotify_event: tstamp:10902802766 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:348886647104 data:0x0000000031000001
kworker/0:2-87 [000] .... 323.641145: rtcpu_vinotify_event: tstamp:10903466141 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:348910877056 data:0xcd9ce20010000000
kworker/0:2-87 [000] .... 323.641150: rtcpu_vinotify_event: tstamp:10903466291 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:348910888992 data:0x0000000031000002
vi-output, ev95-2732 [001] .... 326.110762: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/0:2-87 [000] .... 326.161078: rtcpu_vinotify_event: tstamp:10982725501 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:351446514240 data:0xcd9ce50010000000
kworker/0:2-87 [000] .... 326.161083: rtcpu_vinotify_event: tstamp:10982725662 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:351446526688 data:0x0000000031000001
kworker/0:2-87 [000] .... 326.161084: rtcpu_vinotify_event: tstamp:10983742626 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:351471530912 data:0xcd9ce20010000000
kworker/0:2-87 [000] .... 326.161086: rtcpu_vinotify_event: tstamp:10983742791 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:351471542848 data:0x0000000031000002
vi-output, ev95-2732 [001] .... 328.671535: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/0:2-87 [000] .... 328.737047: rtcpu_vinotify_event: tstamp:11062749993 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:354006974816 data:0xcd9ce50010000000
kworker/0:2-87 [000] .... 328.737051: rtcpu_vinotify_event: tstamp:11062750140 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:354006986592 data:0x0000000031000001
kworker/0:2-87 [000] .... 328.737052: rtcpu_vinotify_event: tstamp:11063767297 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:354031810944 data:0xcd9ce20010000000
kworker/0:2-87 [000] .... 328.737053: rtcpu_vinotify_event: tstamp:11063767445 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:354031822912 data:0x0000000031000002
vi-output, ev95-2732 [000] .... 331.231681: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/0:2-87 [000] .... 331.256999: rtcpu_vinotify_event: tstamp:11142774856 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:356566555968 data:0xcd9ce50010000000
kworker/0:2-87 [000] .... 331.257003: rtcpu_vinotify_event: tstamp:11142775004 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:356566567744 data:0x0000000031000001
kworker/0:2-87 [000] .... 331.313040: rtcpu_vinotify_event: tstamp:11143792035 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:356592093792 data:0xcd9ce20010000000
kworker/0:2-87 [000] .... 331.313044: rtcpu_vinotify_event: tstamp:11143792184 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:356592105728 data:0x0000000031000002
vi-output, ev95-2732 [000] .... 333.790888: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/0:2-87 [000] .... 333.833002: rtcpu_vinotify_event: tstamp:11222799617 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:359126395040 data:0xcd9ce50010000000
kworker/0:2-87 [000] .... 333.833006: rtcpu_vinotify_event: tstamp:11222799780 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:359126406816 data:0x0000000031000001
kworker/0:2-87 [000] .... 333.833008: rtcpu_vinotify_event: tstamp:11223469316 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:359150978720 data:0xcd9ce20010000000
kworker/0:2-87 [000] .... 333.833009: rtcpu_vinotify_event: tstamp:11223469466 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:359150990656 data:0x0000000031000002
vi-output, ev95-2732 [000] .... 336.350872: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/0:2-87 [000] .... 336.408937: rtcpu_vinotify_event: tstamp:11302722289 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:361686411424 data:0xcd9ce50010000000
kworker/0:2-87 [000] .... 336.408940: rtcpu_vinotify_event: tstamp:11302722434 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:361686423200 data:0x0000000031000001
kworker/0:2-87 [000] .... 336.408941: rtcpu_vinotify_event: tstamp:11303739583 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:361714782304 data:0xcd9ce20010000000
kworker/0:2-87 [000] .... 336.408942: rtcpu_vinotify_event: tstamp:11303739732 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:361714794240 data:0x0000000031000002
vi-output, ev95-2732 [000] .... 338.910696: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/0:2-87 [000] .... 338.932902: rtcpu_vinotify_event: tstamp:11382747067 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:364246360000 data:0xcd9ce50010000000
kworker/0:2-87 [000] .... 338.932912: rtcpu_vinotify_event: tstamp:11382747215 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:364246371776 data:0x0000000031000001
kworker/0:2-87 [000] .... 338.988883: rtcpu_vinotify_event: tstamp:11383764317 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:364271483584 data:0xcd9ce20010000000
kworker/0:2-87 [000] .... 338.988891: rtcpu_vinotify_event: tstamp:11383764465 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:364271495488 data:0x0000000031000002
vi-output, ev95-2732 [000] .... 341.471902: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/0:2-87 [000] .... 341.508831: rtcpu_vinotify_event: tstamp:11462771713 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:366806329728 data:0xcd9ce50010000000
kworker/0:2-87 [000] .... 341.508840: rtcpu_vinotify_event: tstamp:11462771875 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:366806341472 data:0x0000000031000001
kworker/0:2-87 [000] .... 341.564843: rtcpu_vinotify_event: tstamp:11463789094 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:366831642048 data:0xcd9ce20010000000
kworker/0:2-87 [000] .... 341.564847: rtcpu_vinotify_event: tstamp:11463789266 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:366831653984 data:0x0000000031000002
vi-output, ev95-2732 [000] .... 344.030556: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/0:2-87 [000] .... 344.084840: rtcpu_vinotify_event: tstamp:11542796319 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:369366469632 data:0xcd9ce50010000000
kworker/0:2-87 [000] .... 344.084844: rtcpu_vinotify_event: tstamp:11542796481 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:369366481376 data:0x0000000031000001
kworker/0:2-87 [000] .... 344.084845: rtcpu_vinotify_event: tstamp:11543481516 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:369391369088 data:0xcd9ce20010000000
kworker/0:2-87 [000] .... 344.084846: rtcpu_vinotify_event: tstamp:11543481664 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:369391381056 data:0x0000000031000002
vi-output, ev95-2732 [000] .... 346.590780: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/0:2-87 [000] .... 346.660879: rtcpu_vinotify_event: tstamp:11622719379 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:371926372960 data:0xcd9ce50010000000
kworker/0:2-87 [000] .... 346.660883: rtcpu_vinotify_event: tstamp:11622719527 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:371926384768 data:0x0000000031000001
kworker/0:2-87 [000] .... 346.660885: rtcpu_vinotify_event: tstamp:11623736645 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:371951964736 data:0xcd9ce20010000000
kworker/0:2-87 [000] .... 346.660886: rtcpu_vinotify_event: tstamp:11623736795 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:371951976672 data:0x0000000031000002
vi-output, ev95-2732 [002] .... 349.152101: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/0:2-87 [000] .... 349.188766: rtcpu_vinotify_event: tstamp:11702744164 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:374486239136 data:0xcd9ce50010000000
What could be the root causem please ?
Thanks in advance and best regards,
K.
