No frame from IMX415 on orin devkit
I have an orin devkit with jetpack 5.1.2/jetlinux 35.4.1 (latest) and 3 attached cameras:
  • IMX492 (4 lanes) as /dev/video0 → capture working
  • IMX492 (4 lanes) as /dev/video1 → capture working
  • IMX415 (2 lanes) as /dev/video2 → I2C OK, but capture hanging
$ v4l2-ctl --set-fmt-video=width=3840,height=2160,pixelformat=RG10 --set-ctrl sensor_mode=0,bypass_mode=0 --stream-mmap -d2
^C
looking at dmesg, I see an error message I have already encountered (Capture not working on second camera):
(NULL device *): vi_capture_control_message: NULL VI channel received
The fix was to ensure that “vc-id” was set to zero in the device tree.
I checked my device tree, and it seems just fine:
  • device tree dumped from /proc/device-tree:
    fs_dts.txt (452.5 KB)
  • device tree dumped from /boot/dtb/kernel_tegra234-p3701-0000-as-p3701-0004-p3737-0000.dtb:
    dtb_dts.txt (455.7 KB)
I enabled some log in the tegra code and pasted it below. I don’t see anything obviously wrong:
[   56.731901] tegra-camrtc-capture-vi tegra-capture-vi: tegra_channel_get_selection: type: 0x1, target: 0x0, flags: 0x0, left: 0, top: 0, width: 3840, height: 2160
[   56.732075] tegra-camrtc-capture-vi tegra-capture-vi: __tegra_channel_set_frame_size vi-output, vc_mipi 32-001a: alain, 3840x2160 -> 3840x2160
[   56.732083] vc_mipi 32-001a: camera_common_try_fmt: size 3840 x 2160
[   56.732089] vc_mipi 32-001a: camera_common_s_fmt(12303) size 3840 x 2160
[   56.732092] vc_mipi 32-001a: camera_common_try_fmt: size 3840 x 2160
[   56.732098] video4linux video2: tegra_channel_update_format: Resolution= 3840x2160 bytesperline=7680
[   56.732134] tegra-camrtc-capture-vi tegra-capture-vi: tegra_channel_get_selection: type: 0x2, target: 0x0, flags: 0x0, left: 0, top: 0, width: 3840, height: 2160
[   56.749349] vc_mipi 32-001a: camera_common_mclk_enable: enable MCLK with 24000000 Hz
[   56.749617] vc_mipi 32-001a: camera_common_dpd_disable: csi 4
[   56.750130] tegra-camrtc-capture-vi tegra-capture-vi: vi_capture_init++
[   56.750258] tegra194-vi5 13e40000.host1x:vi0@15c00000: chan flags 4163
[   56.750260] tegra194-vi5 13e40000.host1x:vi0@15c00000: chan mask ffffffffffffffff
[   56.750261] tegra194-vi5 13e40000.host1x:vi0@15c00000: queue depth 4
[   56.750262] tegra194-vi5 13e40000.host1x:vi0@15c00000: request size 384
[   56.750263] tegra194-vi5 13e40000.host1x:vi0@15c00000: csi_stream_id 4
[   56.750265] tegra194-vi5 13e40000.host1x:vi0@15c00000: vi unit id 0
[   56.750266] tegra194-vi5 13e40000.host1x:vi0@15c00000: vi2 chan mask ffffffffffffffff
[   56.756075] tegra194-vi5 13e40000.host1x:vi0@15c00000: 0 GoS tables configured.
[   56.756080] tegra194-vi5 13e40000.host1x:vi0@15c00000: vi_capture_ivc_send_control: sending chan_id 64 msg_id 30
[   56.756540] tegra194-vi5 13e40000.host1x:vi0@15c00000: vi_capture_ivc_send_control: response chan_id 64 msg_id 17
[   56.756833] tegra194-vi5 13e40000.host1x:vi0@15c00000: vi_capture_request: sending chan_id 0 msg_id 1 buf:0
[   56.756839] tegra194-vi5 13e40000.host1x:vi0@15c00000: vi_capture_request: sending chan_id 0 msg_id 1 buf:1
[   56.756842] tegra194-vi5 13e40000.host1x:vi0@15c00000: vi_capture_request: sending chan_id 0 msg_id 1 buf:2
[   56.756844] tegra194-vi5 13e40000.host1x:vi0@15c00000: vi_capture_request: sending chan_id 0 msg_id 1 buf:3
[   56.757214] tegra_channel_set_stream: on=1
[   56.757216] tegra194-vi5 13e40000.host1x:vi0@15c00000: vi_capture_status: waiting for status, timeout:5000 ms
[   56.757219]   vi_channel_id[]: 0 0 0
[   56.757221]   port[]: 4 255 255
[   56.757222]   virtual_channel: 0
[   56.757224]   timeout: 0
[   56.757225]   stride_align: 1
[   56.757226]   preferred_stride: 0
[   56.757228]   width_align: 1
[   56.757229]   height_align: 1
[   56.757230]   size_align: 1
[   56.757232]   valid_ports: 1
[   56.757233]   total_ports: 1
[   56.757234]   numlanes: 2
[   56.757235]   io_id: 0
[   56.757236]   num_subdevs: 2
[   56.757238]   sequence: 0
[   56.757239]   bypass 0, write isp 1, lowlat 0, state 1
[   56.757240]   vnc_id[]: 0 0 0
[   56.757242]   link_status 1, is_slvsec 0, is_interlaced 0
[   56.757243]   num_channels 3
[   56.757245]   num_subdevs 0
[   56.757246]   bypass 0
[   56.760257] bwmgr API not supported
[   56.770053] tegra194-vi5 13e40000.host1x:vi0@15c00000: vi_capture_ivc_send_control: sending chan_id 0 msg_id 64
[   56.770216] tegra194-vi5 13e40000.host1x:vi0@15c00000: vi_capture_ivc_send_control: response chan_id 0 msg_id 65
[   56.770220] tegra194-vi5 13e40000.host1x:vi0@15c00000: vi_capture_ivc_send_control: sending chan_id 0 msg_id 54
[   56.770466] tegra194-vi5 13e40000.host1x:vi0@15c00000: vi_capture_ivc_send_control: response chan_id 0 msg_id 55
[   56.770475] vc_mipi 32-001a: vc_core_set_format(): Set format 0x300f (RG10)
[   56.770674] vc_mipi 32-001a: vc_core_try_format(): Try format 0x300f (RG10, format: 0x2b)
[   56.770678] vc_mipi 32-001a: vc_update_image_size_from_mode(): Update image size from mode0 (l: 0, t: 0, w: 3840, h: 2160)
[   56.770989] vc_mipi 32-001a: vc_update_tegra_image_size: 3840 x 2160, line_length=7768
[   56.770990] vc_mipi 32-001a: vc_update_tegra_image_size: set line_length 0 replaced with 7768
[   56.770992] vc_mipi 32-001a: vc_update_tegra_image_size: 0, 0, 3840, 2160, 7768, 808535890, 1
[   56.771000] vc_mipi 32-001a: vc_start_streaming:422 alain: 200 200
[   56.771004] i2c 32-0010: vc_mod_set_mode(): Set module mode: 0 (lanes: 2, format: RG10, type: STREAM)
[   56.771260] i2c 32-0010: vc_mod_set_power(): Set module power: down
[   56.771535] i2c 32-0010: vc_mod_set_power(): Set module power: up
[   57.172124] vc_mipi 32-001a: vc_start_streaming:427, alain: 0, reset=1
[   57.172132] vc_mipi 32-001a: vc_start_streaming:430, alain reset 487
[   57.172168] vc_mipi 32-001a: vc_start_streaming:437, alain reset low
[   57.172231] vc_mipi 32-001a: vc_sen_set_roi(): Set sensor roi: (left: 0, top: 0, width: 3840, height: 2160)
[   57.173550] vc_mipi 32-001a: vc_start_streaming:443, alain: 0
[   57.173553] vc_mipi 32-001a: vc_sen_set_exposure(): Set sensor exposure: 10000 us
[   57.174505] vc_mipi 32-001a: vc_start_streaming:445, alain: 0
[   57.174508] vc_mipi 32-001a: vc_sen_set_gain(): Set sensor gain: 0
[   57.174933] vc_mipi 32-001a: vc_start_streaming:448, alain: 0
[   57.174936] vc_mipi 32-001a: vc_sen_set_blacklevel(): Set sensor black level: 50
[   57.175407] vc_mipi 32-001a: vc_start_streaming:450, alain: 0
[   57.175410] vc_mipi 32-001a: vc_sen_start_stream(): Start streaming
[   57.175989] vc_mipi 32-001a: vc_start_streaming:453, alain: 0
[   61.919786] tegra194-vi5 13e40000.host1x:vi0@15c00000: capture status timed out
[   61.919795] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 5000 ms
[   61.920056] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[   61.920332] tegra194-vi5 13e40000.host1x:vi0@15c00000: vi_capture_ivc_send_control: sending chan_id 0 msg_id 20
[   61.921340] tegra194-vi5 13e40000.host1x:vi0@15c00000: vi_capture_ivc_send_control: response chan_id 0 msg_id 21
[   61.921386] tegra194-vi5 13e40000.host1x:vi0@15c00000: vi_capture_shutdown--
[   61.921394] (NULL device *): vi_capture_control_message: NULL VI channel received
[   61.921601] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=4, csi_port=4
[   61.921873] (NULL device *): vi_capture_control_message: NULL VI channel received
[   61.922078] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 4 vc- 0
[   61.922360] tegra-camrtc-capture-vi tegra-capture-vi: vi_capture_init++
[   61.922415] tegra194-vi5 13e40000.host1x:vi0@15c00000: chan flags 4163
[   61.922417] tegra194-vi5 13e40000.host1x:vi0@15c00000: chan mask ffffffffffffffff
[   61.922419] tegra194-vi5 13e40000.host1x:vi0@15c00000: queue depth 4
[   61.922420] tegra194-vi5 13e40000.host1x:vi0@15c00000: request size 384
[   61.922421] tegra194-vi5 13e40000.host1x:vi0@15c00000: csi_stream_id 4
[   61.922423] tegra194-vi5 13e40000.host1x:vi0@15c00000: vi unit id 0
[   61.922424] tegra194-vi5 13e40000.host1x:vi0@15c00000: vi2 chan mask ffffffffffffffff
[   61.922443] tegra194-vi5 13e40000.host1x:vi0@15c00000: 0 GoS tables configured.
[   61.922445] tegra194-vi5 13e40000.host1x:vi0@15c00000: vi_capture_ivc_send_control: sending chan_id 65 msg_id 30
[   61.922523] tegra194-vi5 13e40000.host1x:vi0@15c00000: vi_capture_ivc_send_control: response chan_id 65 msg_id 17
[   61.922537] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[   61.922835] tegra_channel_set_stream: on=0
[   61.922841]   vi_channel_id[]: 0 0 0
[   61.922845]   port[]: 4 255 255
[   61.922848]   virtual_channel: 0
[   61.922850]   timeout: 0
[   61.922853]   stride_align: 1
[   61.922855]   preferred_stride: 0
[   61.922858]   width_align: 1
[   61.922860]   height_align: 1
[   61.922862]   size_align: 1
[   61.922864]   valid_ports: 1
[   61.922867]   total_ports: 1
[   61.922869]   numlanes: 2
[   61.922871]   io_id: 0
[   61.922873]   num_subdevs: 2
[   61.922876]   sequence: 0
[   61.922879]   bypass 0, write isp 1, lowlat 0, state 0
[   61.922881]   vnc_id[]: 0 0 0
[   61.922884]   link_status 1, is_slvsec 0, is_interlaced 0
[   61.922887]   num_channels 3
[   61.922889]   num_subdevs 0
[   61.922892]   bypass 0
[   61.922906] vc_mipi 32-001a: vc_sen_stop_stream(): Stop streaming
[   61.973543] vc_mipi 32-001a: vc_stop_streaming:474, alain reset gpio 487
[   61.973579] vc_mipi 32-001a: vc_stop_streaming:481, alain reset hi
[   61.973589] tegra194-vi5 13e40000.host1x:vi0@15c00000: vi_capture_control_send_message: NVCSI stream is already closed for this VI channel
[   61.976552] bwmgr API not supported
[   61.986745] tegra194-vi5 13e40000.host1x:vi0@15c00000: vi_capture_ivc_send_control: sending chan_id 0 msg_id 20
[   61.987538] tegra194-vi5 13e40000.host1x:vi0@15c00000: vi_capture_ivc_send_control: response chan_id 0 msg_id 21
[   61.987608] tegra194-vi5 13e40000.host1x:vi0@15c00000: vi_capture_shutdown--
[   61.987628] vc_mipi 32-001a: camera_common_dpd_enable: csi 4
[   61.987634] vc_mipi 32-001a: camera_common_mclk_disable: disable MCLK
I tried maxing out the clocks but that didn’t help and camera still hangs:
sudo su
echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee  /sys/kernel/debug/bpmp/debug/clk/isp/rate
cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
Last, I tried capturing a trace:
$ sudo su
# echo 1 > /sys/kernel/debug/tracing/tracing_on
# echo 30720 > /sys/kernel/debug/tracing/buffer_size_kb
# echo 1 > /sys/kernel/debug/tracing/events/tegra_rtcpu/enable
# echo 1 > /sys/kernel/debug/tracing/events/freertos/enable
# echo 2 > /sys/kernel/debug/camrtc/log-level
# echo 1 > /sys/kernel/debug/tracing/events/camera_common/enable
# echo > /sys/kernel/debug/tracing/trace
^D
^C
Below is the trace I’m getting:
nvidia@sdj-orindk-02:~/misc$ sudo cat /sys/kernel/debug/tracing/trace
# tracer: nop
# entries-in-buffer/entries-written: 36/36   #P:8
#                                _-----=> irqs-off
#                               / _----=> need-resched
#                              | / _---=> hardirq/softirq
#                              || / _--=> preempt-depth
#                              ||| /     delay
#           TASK-PID     CPU#  ||||   TIMESTAMP  FUNCTION
     kworker/2:2-120     [002] ....   753.988979: rtcpu_string: tstamp:24181865135 id:0x04010000 str:"VM0 deactivating."
        v4l2-ctl-2971    [000] ....   778.106666: tegra_channel_open: vi-output, vc_mipi 32-001a
        v4l2-ctl-2971    [000] ....   778.123376: tegra_channel_set_power: vc_mipi 32-001a : 0x1
        v4l2-ctl-2971    [000] ....   778.123389: camera_common_s_power: status : 0x1
        v4l2-ctl-2971    [000] ....   778.123680: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x1
        v4l2-ctl-2971    [000] ....   778.123682: csi_s_power: enable : 0x1
        v4l2-ctl-2971    [000] ....   778.124280: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt c4
     kworker/2:2-120     [002] ....   778.128560: rtcpu_string: tstamp:24937543142 id:0x04010000 str:"VM0 activating."
        v4l2-ctl-2971    [002] ....   778.131171: tegra_channel_set_stream: enable : 0x1
        v4l2-ctl-2971    [002] ....   778.144034: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x1
        v4l2-ctl-2971    [002] ....   778.144036: csi_s_stream: enable : 0x1
        v4l2-ctl-2971    [002] ....   778.144465: tegra_channel_set_stream: vc_mipi 32-001a : 0x1
     kworker/2:2-120     [002] ....   778.184557: rtcpu_vinotify_event: tstamp:24938174671 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:798005723200 data:0x359d580010000000
     kworker/2:2-120     [002] ....   778.184558: rtcpu_vinotify_event: tstamp:24938174829 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:798005729728 data:0x0000000031000001
     kworker/2:2-120     [002] ....   778.184558: rtcpu_vinotify_event: tstamp:24938174985 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:798005775520 data:0x359d550010000000
     kworker/2:2-120     [002] ....   778.184558: rtcpu_vinotify_event: tstamp:24938175117 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:798005782176 data:0x0000000031000002
     kworker/2:2-120     [002] ....   778.184560: rtcpu_nvcsi_intr: tstamp:24938683002 class:GLOBAL type:PHY_INTR0 phy:2 cil:0 st:0 vc:0 status:0x00000044
 vi-output, vc_m-2973    [001] ....   783.322558: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt c4
     kworker/2:2-120     [002] ....   783.392513: rtcpu_vinotify_event: tstamp:25100394899 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:803198156160 data:0x359d580010000000
     kworker/2:2-120     [002] ....   783.392515: rtcpu_vinotify_event: tstamp:25100395042 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:803198198848 data:0x0000000031000001
     kworker/2:2-120     [002] ....   783.392516: rtcpu_vinotify_event: tstamp:25100395196 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:803198216416 data:0x359d550010000000
     kworker/2:2-120     [002] ....   783.392516: rtcpu_vinotify_event: tstamp:25100395330 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:803198276800 data:0x0000000031000002
        v4l2-ctl-2971    [002] ....   783.683120: tegra_channel_close: vi-output, vc_mipi 32-001a
 vi-output, vc_m-2973    [001] ....   788.442512: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt c4
        v4l2-ctl-2971    [002] ....   788.443088: tegra_channel_set_stream: enable : 0x0
        v4l2-ctl-2971    [002] ....   788.443154: tegra_channel_set_stream: vc_mipi 32-001a : 0x0
     kworker/2:2-120     [002] ....   788.488478: rtcpu_nvcsi_intr: tstamp:25259957608 class:GLOBAL type:PHY_INTR0 phy:2 cil:0 st:0 vc:0 status:0x00000001
     kworker/2:2-120     [002] ....   788.488480: rtcpu_nvcsi_intr: tstamp:25259957966 class:GLOBAL type:PHY_INTR1 phy:2 cil:0 st:0 vc:0 status:0x00000120
        v4l2-ctl-2971    [002] ....   788.493860: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x0
        v4l2-ctl-2971    [002] ....   788.493863: csi_s_stream: enable : 0x0
        v4l2-ctl-2971    [003] ....   788.508419: tegra_channel_set_power: vc_mipi 32-001a : 0x0
        v4l2-ctl-2971    [003] ....   788.508429: camera_common_s_power: status : 0x0
        v4l2-ctl-2971    [003] ....   788.508471: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x0
        v4l2-ctl-2971    [003] ....   788.508474: csi_s_power: enable : 0x0
     kworker/2:2-120     [002] ....   788.544470: rtcpu_nvcsi_intr: tstamp:25261978373 class:GLOBAL type:PHY_INTR0 phy:2 cil:0 st:0 vc:0 status:0x00180000
     kworker/2:2-120     [002] ....   793.808616: rtcpu_string: tstamp:25426488673 id:0x04010000 str:"VM0 deactivating."
is there anything wrong showing in this trace?
I’m running out of ideas. Any recommendation how to proceed?
Thanks,
Alain
hello alain.gautherot,
port bindings looks correct. but there shows PHY interrupts in the VI tracing logs.
for example,
the error code 0x1 means there’s LP sequence error detected on clock lane.
0x120 shows one bit error detected on the data lane, and also data lane FIFO overflow.
those are errors related to sensor configuration.
ok, I think I figured some issue in the DTS. I thought it was configured in 2 lanes, but other parts said 4.
also, lane polarity needs to be set to “0” for AGX Orin.
after correcting these, I can see frames back.
