Hi NVIDIA team,
I have one DGX Spark and would like to run both Aerial Testbed 1.1 and AODT on the same system.
According to the documentation:
- Aerial Testbed 1.1 / Aerial CUDA-Accelerated RAN 26-1 requires CUDA 13.1.1.
- AODT 1.5 requires CUDA 12.9 only.
What is the recommended way to run both workloads on the same DGX Spark?
Do I need to switch the CUDA version between 13.1.1 and 12.9 every time I switch between Aerial Testbed and AODT, or is there a supported way to keep both CUDA versions installed and run each application with its required version, for example through containers or separate CUDA toolkit installations?
