Hi, I have a setup with a Mellanox SX1036 Ethernet switch and 2 servers, each with Mellanox ConnectX-2 HCA cards. Each HCA card has one of its (Ethernet) network ports connected to a port on the SX1036 switch, and are configured to 10 Gbps – links are up and running. I’d like to use “iperf” to do some network performance testing. So, I’ve installed iperf on both servers and am ready to go. I was hoping that someone could point me to good examples of using “iperf” with a similar setup, i.e. servers with Mellanox HCAs communicating through a Mellanox switch. Thanks!
Branko,
Thanks so much for the question. Let me see who I can get to jump on this for you.
Good question deserves a good answer:
i would start with recomending using MellanoxOFED2.0 http://www.mellanox.com/page/products_dyn?product_family=26&mtag=linux_sw_drivers - the guys in the shop have been working very hard on performance improvements for ipoib and Ethernet as well.
you can also use the tuning guide http://www.mellanox.com/related-docs/prod_software/Performance_Tuning_Guide_for_Mellanox_Network_Adapters_v1.7.pdf and further tight things up.
here are few recommended steps for tuning and measuring with iperf/netperf:
- Set IPoIB to run in datagram mode
echo datagram > /sys/class/net/ibX/mode
Set the HCA Port IRQ Affinity
Disable IRQ Balancer service (enabled by default on RH/OEL):
chkconfig irqbalance off
/etc/init.d/irqbalance stop
- Use Mellanox script to distribute the IRQ vectors among the “close” cores.
For example:
/usr/sbin/set_irq_affinity_bynode.sh X mlx4-ib-
/usr/sbin/set_irq_affinity_bynode.sh X mlx4-comp
- Where “X” is the node close to the HCA being tested:
cat /sys/class/net/ibN/device/numa_node
And “Y” is the port number (1st port is 1, 2nd port is 2).
Pin the application processes on the same node.
To get the list of the cores of the on node X, run:
cat /sys/devices/system/node/nodeX/cpulist
For example:
cat /sys/devices/system/node/node1/cpulist
8-15
- Then pin the application using taskset utility, for example:
taskset –c 0,1,2,3,4,5,6,7 iperf –s
taskset –c 0,1,2,3,4,5,6,7 iperf –l 64k –P 8
Note that some applications provide command line flags for core pinning, for example:
netperf –T
- IPv4 sysctl Modifications:
sysctl -w net.ipv4.tcp_timestamps=0
sysctl -w net.ipv4.tcp_sack=0
sysctl -w net.core.netdev_max_backlog=250000
sysctl -w net.core.rmem_max=16777216
sysctl -w net.core.wmem_max=16777216
sysctl -w net.core.rmem_default=16777216
sysctl -w net.core.wmem_default=16777216
sysctl -w net.core.optmem_max=16777216
sysctl -w net.ipv4.tcp_mem="16777216 16777216 16777216“
sysctl -w net.ipv4.tcp_rmem="4096 87380 16777216“
sysctl -w net.ipv4.tcp_wmem="4096 65536 16777216“
sysctl -w net.ipv4.tcp_low_latency=1
i hope it helps. good luck!
Thanks very much for your detailed response Yairi! Much appreciated and very useful information!
