Hi ,
I want to pass CAN signals through my .cpp code on Jetson TX2.
What are the specific paths in which source API’s for CAN protocol is present on Jetson TX2?
Kindly help
Hi ,
Kindly help
For using CAN source code, you can start looking into this path:
kernel/nvidia/drivers/net/can/mttcan/native/m_ttcan_linux.c
And then the flow is sequential module wise.
Please let us know if you are looking for something else.
Thanks & Regards,
Sandipan
Hi Sandipan,
Thanks for your response.
I am unable to find the mttcan folder within - /lib/modules/4.4.38-tegra/kernel/drivers/net/can/
The files present within the CAN folder are - can-dev.ko , slcan.ko , vcan.ko and USB(folder).
I am unable to find the file - m_ttcan_linux.c
I am not facing any error when I run the commands :-
$ sudo modprobe can
$ sudo modprobe mttcan
Kindly help.
Thanks,
Pratosha
Hi Pratosha,
If you are able to do modprobe successfully, thn required modules must be present in your target’s lib/modules directory.
Can you check lib/modules//modules.order
Also for more clarity these files can be refered:
lib/modules//modules.alias
lib/modules//modules.builtin
lib/modules//modules.dep
For m_ttcan_linux.c source file:
it must be present in your source code directory.
Please let us know which version of release code-line is being used at your setup. So it will be easier to point out the proper path.
Thanks & Regards,
Sandipan
Thanks & Regards,
Sandipan
Hi Sandipan,
Thanks for your support.
The kernel version on the jetson TX2 is - 4.4.38-tegra using 16.04 ubuntu.
The above files are present.
I have searched for this file in the file system and home directory.
Yet unable to find .
Is there any repository to be installed for CAN setup to access m_ttcan_linux.c?
Kindly help.
Regards,
Pratosha
It is strange that m_ttcan_linux.c source is not present on your repository.
can you try with the following steps and let us know if it helps:
Try to build and use this.
There you should find m_ttcan_linux.c at this path:
<New_directory>/public_release/kernel/t18x/drivers/net/can/mttcan/m_ttcan_linux.c
Hope this helps.
Thanks & Regards,
Sandipan
Hi Sandipan,
Yes I have installed the sources folder from the link - https://developer.nvidia.com/embedded/dlc/l4t-sources-28-1
And i found the file m_ttcan_linux.c from the path /sources/kernel/t18x/drivers/net/can/mttcan/native/m_ttcan_linux.c
Thanks again.
