son.le
February 2, 2023, 3:47pm
1
Hi
I would like to make CAN bus work the Xavier NX dev kit. I use the Jetpack 5.02 default from NVIDIA and I have tried to follow instructions:
Enabling CAN on Nvidia Jetson Xavier Developer Kit | by Ramin Nabati | Medium
I saw the can0 interface is up:
ip -s -d link show can0
9: can0: <NOARP,UP,LOWER_UP,ECHO> mtu 16 qdisc pfifo_fast state UP mode DEFAULT group default qlen 10
link/can promiscuity 0 minmtu 0 maxmtu 0
can state ERROR-ACTIVE (berr-counter tx 0 rx 0) restart-ms 0
bitrate 1000000 sample-point 0.735
tq 29 prop-seg 12 phase-seg1 12 phase-seg2 9 sjw 1
mttcan: tseg1 2…255 tseg2 0…127 sjw 1…127 brp 1…511 brp-inc 1
mttcan: dtseg1 1…31 dtseg2 0…15 dsjw 1…15 dbrp 1…15 dbrp-inc 1
clock 34000000
re-started bus-errors arbit-lost error-warn error-pass bus-off
0 0 0 0 0 0 numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535
RX: bytes packets errors dropped overrun mcast
0 0 0 0 0 0
TX: bytes packets errors dropped carrier collsns
0 0 0 0 0 0
But when trying to test the can bus can0, it shows nothing:
candump can0 &
[1] 2784
root@ubuntu:/home/lts# cansend can0 5A1#1122334455667788
root@ubuntu:/home/lts# ip -s -d link show can0
9: can0: <NO-CARRIER,NOARP,UP,ECHO> mtu 16 qdisc pfifo_fast state DOWN mode DEFAULT group default qlen 10
can state BUS-OFF (berr-counter tx 248 rx 0) restart-ms 0
clock 34000000
0 0 0 1 1 1 numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535
24 3 0 0 0 0
0 0 0 0 0 0
I have tried to use CAN tester to send to Xavier NX CAN, but it does not receive.
I have tested CAN loop back mode (internal loopback), and it works perfectly.
I wonder if the CAN bus could work on the XAVIER NX dev kit with Jetpack 5.02? if yes, why my Xavier NX CAN bus does not work?
Thanks a lot in advance.
Hi @son.le
I haven’t used the CAN bus on the Xavier NX with JetPack 5.0.2, but in the past when I have used it I had issues because there was a blacklisted module.
Maybe it can be worth a try to do the same to see if something similar is happening:
Remove the file /etc/modprobe.d/blacklist-mttcan.conf
if it exists, or even comment it’s content.
Regards,
Roberto Gutierrez,
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com/
son.le
February 2, 2023, 5:36pm
3
Dear Roberto
I have tried to follow advice and in the /etc/modprobe.d/ it has only file:
denylist-mttcan.conf
and the file content: blacklist mttcan
I have removed the file (denylist-mttcan.conf)
but the result still the same: CAN0 can not TX?RX to/from CAN tester.
Is there any reason that Xavier NX Jetpack 5.02 default image could prevent CAN bus working?
So is “lsmod” showing up mttcan or not?
son.le
February 3, 2023, 9:00am
6
Dear
I have checked lsmod, it shows mttcan:
lsmod | grep can
can_raw 28672 2
can 28672 1 can_raw
mttcan 65536 0
can_dev 32768 1 mttcan
I have tested internal loop back, it works perfectly, thus I think it does not have problem with CAN driver.
LOOP BACK MODE:
ip link set can0 type can bitrate 1000000 loopback on
ip link set up can0
[1]+ Exit 1 candump can0
root@ubuntu:/home/lts# candump can0 &
[1] 2517
clock 34000000
0 0 0 0 0 0
0 0 0 0 0 0
can0 5A1 [8] 11 22 33 44 55 66 77 88
root@ubuntu:/home/lts# lsmod | grep can
mttcan 65536 0
can_raw 28672 1
Only that when using the CAN tester, it shows nothing.
kayccc
February 8, 2023, 1:27am
7
system
Closed
March 7, 2023, 5:38am
9
